for all you EDIS freaks that need a Tach
54 replies to this topic
#41 importwarrior
  • 17,918 posts
Posted 05 October 2014 - 07:55 AM
any questions please feel free to contact me.
i just did this process yesterday and it was nice to see the Tach working again.
i used heat shrink and electric tape and soldered everything.
also you could use liquid electrical tape? not sure if that is what it is called.
#42 psu_Crash
psu_Crash
  • 7,011 posts
Posted 05 October 2014 - 10:34 AM
I often use this stuff on the bare metal connections, let it sit for a minute and then heat shrink over it. Creates a nice water and corrosion proof seal.
http://www.usplastic...CFbPm7AodUzAAng
My Feedback Link
#43 importwarrior
  • 17,918 posts
Posted 05 October 2014 - 12:32 PM
good information here on how these diodes do what they do.
http://www.evilmadsc...o-zener-diodes/
#44 DJpowerHaus
DJpowerHaus
  • 2,407 posts
  • Interests:If that has a Spoon engine, mine's got a Shovel.
Posted 31 March 2016 - 02:50 PM
Rise of the living dead post....
Would this work with 4 coil inputs and 4 1N4004?
:: Project 0G ::
www.ProjectZeroG.com
#45 importwarrior
  • 17,918 posts
Posted 31 March 2016 - 06:48 PM
Usually one zener diode only. You need 1 regular diode for every 2 cylinders when running edis.
So 2 for 4 banger 3 for 6 and 4 for 8 cylinder.
Use the 1 watt diodes and 1watt zener diode.
Be 100% sure to cover any exposed leads and or wires.
Heat shrink them all.
Example of V8 setup.
#46 DJpowerHaus
DJpowerHaus
  • 2,407 posts
Posted 01 April 2016 - 09:52 AM
I've got a Megasquirt (DIYPNP) with 4 channels, 4 coils.
Tach outpot is also 12v square wave and doesn't want to turn the tach so this is my backup plan.
Also found this: http://www.autosport...t/tach-adapter/
:: Project 0G ::
#47 importwarrior
  • 17,918 posts
Posted 01 April 2016 - 01:26 PM
it is easy to build and less than 10 bucks for parts.
easy as can be! little solder and heat shrink and your good to go. done in minutes.
#48 Woody
Woody
  • 355 posts
  • Interests:Starions
Posted 11 June 2018 - 07:59 AM
I have a small query about this amazing thread.
I'm running 4x LS2 coils and want to know which wire I install the diodes off. My setup is like this.
I assume I install a diode off each ignition out wire? Thanks
Edited by Woody, 11 June 2018 - 07:59 AM.
www.sweetfrostings.com.au
#49 scott87star
scott87star
  • 4,907 posts
Posted 11 June 2018 - 08:49 AM
Yes.
#50 Woody
Woody
  • 355 posts
Posted 14 June 2018 - 07:54 AM
Thank you muchly for your reply. I will report back with the results in a week. :)
#51 importwarrior
  • 17,918 posts
Posted 15 June 2018 - 07:01 AM
If your EDIS or COP ( Coil On Plug) it is the same process when soldering the diodes together.
just that the EDIS uses only 2 diodes and 1 Zener diode.
COP Uses 4 diodes and 1 Zener diode. One for each COP Ignition Out.
The Black Stripe on the Zener Diode and the Silver stripe on the diodes need to face each other when you solder them together.
#52 importwarrior
  • 17,918 posts
Posted 15 June 2018 - 07:04 AM
For the COIL On Plug
#53 Woody
Woody
  • 355 posts
Posted 15 June 2018 - 09:12 AM
Thanks guys. Thats exactly what I was planning on doing. I understand the reverse current stuff. I think it's such a cool hack. I already bought the diodes for installation this weekend. Just might take me a week to get the new coils running.
#54 psu_Crash
psu_Crash
  • 7,011 posts
Posted 15 June 2018 - 08:11 PM
Good stuff IW.
FYI
If you are running a standalone though such as megasquirt you can just remove the resistor in line with the tach and run the square wave tach signal from the ECU straight to the tach. I've had several different tach feed circuits through the years that I won't get into now.
Ever had issues with the diode setup? Mine was somewhat intermittent in that configuration
Edited by psu_Crash, 15 June 2018 - 08:13 PM.
My Feedback Link
#55 Woody
Woody
  • 355 posts
Posted 17 June 2018 - 07:57 AM
I don't think we can get the Haltech to do what our tachos need
