questtuner82 Posted November 23, 2013 Report Share Posted November 23, 2013 Check out the specs on these. Nice rims, same bolt pattern as ours and backspace is perfect. Going to post pics later when I pull mine out of storage. Link to comment Share on other sites More sharing options...
tankbob Posted November 23, 2013 Report Share Posted November 23, 2013 19s on a starquest tho? Link to comment Share on other sites More sharing options...
questtuner82 Posted November 24, 2013 Author Report Share Posted November 24, 2013 Tires are 225/30/19 front and 245/40/19 which is only an inch taller than oem Link to comment Share on other sites More sharing options...
importwarrior Posted November 24, 2013 Report Share Posted November 24, 2013 what is the offset? what size spacers will you need? Link to comment Share on other sites More sharing options...
questtuner82 Posted November 24, 2013 Author Report Share Posted November 24, 2013 I believe the offset is different for front and rear I think what I read is offset was 35 but I'll check again. I need to test fit mine yet. Link to comment Share on other sites More sharing options...
D_Venable Posted November 24, 2013 Report Share Posted November 24, 2013 (edited) You'll need spacers for sure if it's 35mm offset, even for the front your gonna want to run at least a 20mm spacer, otherwise it'll look way too sunk in, if it even clear the strut body. Our stock 16x7's have an offset of +18mm Edited November 24, 2013 by D_Venable Link to comment Share on other sites More sharing options...
questtuner82 Posted November 25, 2013 Author Report Share Posted November 25, 2013 Ok so I checked all the specs on the hyundai genesis wheels and you need a 1" spacer to put them in stock spec quest location backspace is as followed front 6" and rear is 5.75" so 1" will give you a 1/4" wider stance with these rims Link to comment Share on other sites More sharing options...
questtuner82 Posted November 25, 2013 Author Report Share Posted November 25, 2013 Also these genesis 19" rims are super light. The rim itself weighs 12 lbs for the fronts and 14 lbs for the rears Link to comment Share on other sites More sharing options...
importwarrior Posted November 25, 2013 Report Share Posted November 25, 2013 12 and 14 lbs seems not right for a 19 inch wheel. i would like to see one on a scale. Link to comment Share on other sites More sharing options...
questtuner82 Posted November 25, 2013 Author Report Share Posted November 25, 2013 They aren't aluminium and they aren't alloy I can't remember what they are made of but they are light. U can pick them up with one finger and not strain urself Link to comment Share on other sites More sharing options...
importwarrior Posted November 26, 2013 Report Share Posted November 26, 2013 Very cool. Link to comment Share on other sites More sharing options...
KT Posted November 29, 2013 Report Share Posted November 29, 2013 These wheels don't have any lip. They will look out of place on a Quest. Link to comment Share on other sites More sharing options...
BC_99 Posted November 30, 2013 Report Share Posted November 30, 2013 (edited) They aren't aluminium and they aren't alloy I can't remember what they are made of but they are light. U can pick them up with one finger and not strain urself Im sorry, but I have to call BS on that statement. There are only a few things that would be lighter than aluminum alloys that could be used on automotive wheels and none of them make any financial sense to use. Magnesium, titanium, or a composite like carbon fiber or kevlar are a couple that come to mind. here in this article it states that they are machined aluminum. http://www.jsonline.com/business/2014-hyundai-genesis-a-mixed-bag-of-luxury-style-performance-b9984583z1-221873811.html cut from the article:"Braking is good from four-wheel discs brakes, with traction and stability control. The sedan also features 19-inch tires on machined aluminum wheels with a fancy 10-spoke design." BC_99 Edited November 30, 2013 by BC_99 Link to comment Share on other sites More sharing options...
patra_is_here Posted December 3, 2013 Report Share Posted December 3, 2013 Tires are 225/30/19 front and 245/40/19 which is only an inch taller than oem yeah and OEM is too tall to begin with Link to comment Share on other sites More sharing options...
patra_is_here Posted December 3, 2013 Report Share Posted December 3, 2013 I believe the offset is different for front and rear I think what I read is offset was 35 but I'll check again. I need to test fit mine yet. 35 is too high for anything that would be on a SQ. zero or less if you don't want to run spacers. 1 Link to comment Share on other sites More sharing options...
jszucs Posted December 3, 2013 Report Share Posted December 3, 2013 Also these genesis 19" rims are super light. The rim itself weighs 12 lbs for the fronts and 14 lbs for the rears Yeah even as skiny mini as they are, not being forged, and not being to thick there is no way they are getting that light..... I would maybe give them 18-20# range and that's a major maybe. Link to comment Share on other sites More sharing options...
questtuner82 Posted December 9, 2013 Author Report Share Posted December 9, 2013 First of all these are not genesis sedan rims they r genesis coupe r spec rims and they are a composite magnesium they are 19x8.5 front and 19x9.5 rear they are the 5 star doubles and are polished to a near chrome look. And the back spacing on these are close but again I did state that they need a 1" spacer to fit our cars properly. I'm going to make a photobucket acct and post pics soon. And tires are 235/30/19 in the front and 255/35/19 in the rear. I miss posted the tire size. And go on a tire size calculator site and u will see that the tire size is actually about 3/4 of an inch shorter than the factory size on our cars but are wider Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted December 10, 2013 Report Share Posted December 10, 2013 pics on a quest ? 1 Link to comment Share on other sites More sharing options...
questtuner82 Posted December 11, 2013 Author Report Share Posted December 11, 2013 Cars in storage right now but I'll get pics soon Link to comment Share on other sites More sharing options...
patra_is_here Posted December 16, 2013 Report Share Posted December 16, 2013 255/35/19 is 1.5 inches TALLER than stock 245/45/16 for the rear (assuming you are comparing to SHP 9") the 235/30 is a about .25" SHORTER than stock 205/55/16, but stock is tall IMHO. Link to comment Share on other sites More sharing options...
BC_99 Posted December 16, 2013 Report Share Posted December 16, 2013 (edited) Again calling BS http://www.topspeed.com/cars/hyundai/2010-hyundai-genesis-coupe-r-spec-ar70402.html cut from this article on the 2010 Genesis Coupe R-spec "The Genesis R-Spec comes with Track-tuned suspension, 19-inch gunmetal-finish alloy wheels.." No where did I find any information on any magnesium rims on any Genesis coupe or sedan, R-spec or otherwise, from the factory. Im guessing that is because magnesium is a very dangerous metal to use for wheels or car parts in general. It isn't commonly used anymore in OEM application automotives. It has a lower ignition temperature point than most other metals and it supposedly oxygenates itself as it burns, meaning, once it is on fire it will continue to burn even when little oxygen is present. It will continue to burn underwater for a short while and water spraying on it actually can make it worse. Hence, if a vehicle catches fire with magnesium wheels, the firemen have a harder time putting it out because the water he is spraying on it makes it worse. You tube magnesium fires and see for yourself. Keep in mind that in most of the videos you see, they use a piece of magnesium ribbon, not a big chunk of magnesium. I burned a small chunk years ago and learned enough about it to stay away from using it on any car I own. BC_99 Edited December 16, 2013 by BC_99 Link to comment Share on other sites More sharing options...
questtuner82 Posted December 16, 2013 Author Report Share Posted December 16, 2013 It doesn't state what the "alloy" compound is. And they still make a magnesium alloy rim for many applications. (Although they are mostly aftermarket) and mine aren't the factory gunmetal color as they were plastic media blasted and polished to a near chrome look. And as for tire size these fit perfect under my car that is cambered and lowered approximately 2" Link to comment Share on other sites More sharing options...
BC_99 Posted December 17, 2013 Report Share Posted December 17, 2013 That was my point, no description I could find anywhere, made any mention of magnesium. I understand that some aftermarket companys still use magnesium and magnesium alloys for wheels, but a major manufacturer very likely wouldn't, based on cost versus aluminum alloys and couldn't because of the liability of putting such a potentially volatile substance into production. I am just really wanting to know where you got the information on them being magnesium. I would still love to see pictures on the car all the same. I am guessing these are the wheels.. https://www.google.com/search?q=genesis+coupe+r+spec+wheels&tbm=isch&tbo=u&source=univ&sa=X&ei=_Z6vUrTeBpTKsQTphoHACw&ved=0CEcQsAQ&biw=1600&bih=775#facrc=_&imgdii=_&imgrc=iDRM0SprlZ16EM%3A%3BeMb4laGqsHOQiM%3Bhttp%253A%252F%252Fwingsofamerica.net%252Fwp-content%252Fimg%252F2013%252F11%252F2013-hyundai-genesis-coupe-black-rims-a2013-hyundai-genesis-r-spec-coupe-wheels-photo-13-7fw6u5bt.jpg%3Bhttp%253A%252F%252Fwingsofamerica.net%252F2013-hyundai-genesis-r-spec-coupe-wheels-photo-13.html%3B1000%3B1500 BC_99 Link to comment Share on other sites More sharing options...
patra_is_here Posted December 17, 2013 Report Share Posted December 17, 2013 those wheels still seem like the wrong offset. dude post a pic of them on your car Link to comment Share on other sites More sharing options...
patra_is_here Posted December 17, 2013 Report Share Posted December 17, 2013 you're gonna need like an inch at least on the front to look decent. and at least 60mm on the rear!!! Link to comment Share on other sites More sharing options...
