The Missouri Project
tsi_tom\\\\s restoration
299 replies to this topic
#281 importwarrior
  • 18,244 posts
Posted 20 May 2018 - 02:27 PM
I thought that had more to do than just abs???
#282 tsi_tom
tsi_tom
  • 2,270 posts
Posted 27 May 2018 - 11:54 AM
How to depin the round connector
Get a dental pick and bend the end straight
Approach from the blade side and insert as follows
Then pull the wires out the back
The blades look like this.  They lock in the square opening on the back.  I looked for awhile but couldn't find a replacement for these.  I think they are made by Furukawa.
Ohms of the pulse generator
Edited by tsi_tom, 27 May 2018 - 12:03 PM.
Engine
20 over forged pistons
Stock injection system
#283 tsi_tom
tsi_tom
  • 2,270 posts
Posted 27 May 2018 - 12:01 PM
I got my wheels out today and washed them.  This picture is before washing them.  I haven't touched them since I had them refinished at Wheel Collision Center because I believe they have a polishing compound on them and I wanted wash that off.
I took each wheel and washed them and then set them against the garage to dry.  Then I took each one and dried them. As I finished the last one I looked back and noticed that weights fell off.  Wheel Collision Center mounted and balanced these tires on rims they refinished.
The bad thing is that I don't know which rim they fell off of. Now each rim needs to go and be checked
Edited by tsi_tom, 27 May 2018 - 12:02 PM.
Engine
#284 tsi_tom
tsi_tom
  • 2,270 posts
Posted 16 June 2018 - 10:14 AM
I'm having trouble with the radiator overflow coolant not being pulled back into the radiator.  I'm going to try this:
https://conceptzperf...roh_p_26309.php
I hope it is long enough!
Engine
#285 mbruneaux
mbruneaux
  • 1,431 posts
Posted 16 June 2018 - 05:50 PM
Keep up the good work!
Canterbury, CT
1998 BMW 528i 5 Speed because the Suburban gets 10 MPG
#286 Preludedude
Preludedude
  • 2,832 posts
Posted 16 June 2018 - 06:00 PM
I had the same problem.  I just needed a new hose since the old one was brittle and not sealing well on the nipple at the cap
#287 tsi_tom
tsi_tom
  • 2,270 posts
Posted 16 June 2018 - 07:50 PM
Which hose did you go with?
Engine
#288 tsi_tom
tsi_tom
  • 2,270 posts
Posted 16 June 2018 - 07:52 PM
Thank you!
Engine
#289 Preludedude
Preludedude
  • 2,832 posts
Posted 16 June 2018 - 08:39 PM
I bought some new black hose at the hardware store and cut it to the right length.   Let me know how your new hose works out.  I think some colored hose would look nicer.....
#290 tsi_tom
tsi_tom
  • 2,270 posts
Posted 16 June 2018 - 09:31 PM
How did the 180 degree turn work out?
Engine
#291 techboy
techboy
  • 3,273 posts
Posted 16 June 2018 - 10:04 PM
That's a,nice find there Tom, b/c that 180 degree turn does make it a tricky replacement.
Edited by techboy, 16 June 2018 - 10:04 PM.
#292 tsi_tom
tsi_tom
  • 2,270 posts
Posted 16 June 2018 - 10:16 PM
I hope it works!
Engine
#293 importwarrior
  • 18,244 posts
Posted 17 June 2018 - 10:29 AM
You could always use the 180 bend part of that hose and get a brass hose barb coupler and cut hose to length.
#294 TexasQuest
  • 8,844 posts
Posted 18 June 2018 - 11:10 AM
Thanks for the link. I ordered a blue one lol :P
88 Fiji Blue -Tsi
 JohnnyWadd, on 04 March 2010 - 10:01 PM, said:
#295 psu_Crash
psu_Crash
  • 7,116 posts
Posted 18 June 2018 - 06:46 PM
Great attention to detail Tom!
One of these years I need to get rid of the mountain dew overflow bottle that was supposed to be "temporary" lol
It ain't broke so I don't fix it lol
My Feedback Link
#296 tsi_tom
tsi_tom
  • 2,270 posts
Posted 18 June 2018 - 07:10 PM
That's not a bad idea.  Is it a 2 liter bottle?
Engine
#297 kev
kev
    Moderator
  • 4,953 posts
Posted 20 June 2018 - 08:08 AM
I changed the routing of the coolant overflow hose on my car.   The overflow tank was designed to be on the passenger side, which is where it resides on the early models.  So I ran my hose to from the radiator towards the passenger side and then down under the core support with a much more generous bend and back to the slop tank mounted in the factory location.  I turned the cap on the slop tank 90 degrees to align the nipple to the hose as I routed it.  Not sure if I have a good pic handy but can take one.   The sharp 180 degree bend right at the radiator is the problem.   I donít see the reason why it needs to be routed on top of the core support upper member.
#298 tsi_tom
tsi_tom
  • 2,270 posts
Posted 20 June 2018 - 09:57 AM
I wonder if the antifreeze will be pulled back into the radiator with that longer length?
Engine
#299 kev
kev
    Moderator
  • 4,953 posts
Posted 20 June 2018 - 10:55 AM
Iíll let you know in two weeks haha.   What is the length of the stock line?
#300 tsi_tom
tsi_tom
  • 2,270 posts
Posted 20 June 2018 - 09:32 PM
Last year the radiator developed a small leak on the top of the tank.  I took it to Greg's Radiator in Plymouth Meeting, Pa.
The radiator was very thin around the top hose.  He had to add a ring to support it.
Radiator is all back together. That was a job!
Occasionally the radiator would not pull the antifreeze back into the radiator from the overflow tank.  I wanted to use the factory hose but they are NLA.  I searched for another and found this one https://conceptzperf...roh_p_26309.php
Bad original hose
CZP Silicone radiator overflow hose for the Nissan 300ZX Z32 and factory hose
Awesome it is long enough!
IDs look good and the fit is very nice on the nipples :)
OD Size of the factory overflow hose
OD of the CZP Silicone radiator overflow hose for the Nissan 300ZX Z32
The 180 degree turn
Installed
Now here is a problem.  My hood has never shut great because of an accident long ago.  What I  had to do is get the bend on the 180 sitting in the relief close to the cap.  If I have it like this the hood closes ok.
Hose was contacting the weather strip
We'll see how this goes. The hose can be routed other ways but I'm trying the stock approach first.
Engine
