Fuseable links
10 replies to this topic
#1 Rapom
Rapom
  • 113 posts
Posted 10 September 2019 - 06:43 PM
Quick question... anyone know how many the starquest (89) has? And what colors? Going to order from Dad tonight/replace all
#2 croquest87
  • 1,744 posts
Posted 10 September 2019 - 07:41 PM
There is a fusible link box by the battery.  And also one inside the distribution box towards left rear that l know of.
Colors need to be properly selected for proper amps and for each one.
Also should be one black from battery terminal to the little small distribution plastic box. Just look at yours and order accordingly.
Colors are  Green Red Brown    and Black one(no spade connector on this  it's a little loop on each end that goes over bolt).
While in there  make sure to clean all grounds.
Ground #11 under the battery(very important)
Also ground behind distribution box.  Grounds all over the place  make sure they are super clean. All connections also.
Edited by croquest87, 10 September 2019 - 07:43 PM.
#3 Rapom
Rapom
  • 113 posts
Posted 10 September 2019 - 07:52 PM
Mine are all missing or bypassed i have no reference otherwise i would have looked. Srry should have said that.
#4 croquest87
  • 1,744 posts
Posted 10 September 2019 - 07:55 PM
Also ground behind distribution box. Hell grounds all over the place  make sure they are super clean. All connections also.
Highly suggest  you read through your FSM and get a hold of SOS manuals if you can. Starfighterpilot who made these up gets  into details w pictures and many topics regarding these cars)  never talked to him or knew him  but admired his knowledge and attention to detail and humor.
#5 Rapom
Rapom
  • 113 posts
Posted 10 September 2019 - 08:18 PM
Guess im just ordering a crap load... ive got all new batt cables and quad aut? Lol ground cables with the 100a ebay alt. Any wire i can see is getting quad aut cable. Done messing around
#6 markhansenconquest
markhansenconquest
  • 3,641 posts
Posted 11 September 2019 - 08:35 AM
Use dielectric grease on all connections to keep them. clean and working longer.......all the fumes from charging battery makes them get corroded............
#7 TexasQuest
  • 9,079 posts
Posted 11 September 2019 - 12:20 PM
All the ones covered behind the battery are green I believe.
88 Fiji Blue -TSi
#8 croquest87
  • 1,744 posts
Posted 11 September 2019 - 01:21 PM
Relocating your battery to the trunk is a good idea if you feel motivated or good sealed battery
#9 TexasQuest
  • 9,079 posts
Posted 12 September 2019 - 01:41 PM
If you can find one there is a fuse link cover that some mighty max trucks had that fits our cars. It helps protect the exposed fuse links next to the battery.
88 Fiji Blue -TSi
#10 JAinsworth
JAinsworth
  • 16,922 posts
Posted 30 September 2019 - 05:15 AM
Fuse Links
MB510807 Black, with loops on ends (1 fuse per car)
MB262158 Brown, (1 fuse per car) (0.3)
MB037668 Green, (4 fuses per car) (0.5)
MB037669 Red, (2 fuses per car) (0.8)
The last number on each one is the gauge.
Jimmy
#11 Rapom
Rapom
  • 113 posts
Posted 02 October 2019 - 11:30 AM
Thanks Jim! This needs archived now
