101PROPOSE Posted January 9, 2009 Report Share Posted January 9, 2009 (edited) hello members, i have finally received the sample mk1 camgear. this gear has new machined steel outter gear(not modified stock replacement gear) and billet anodized(red or blue) finish aluminum inner piece with six big stainless steel allen bolts. i will be installing this gear and testing it out on my 87 starion. can anyone tell me if there is an easy way to remove the stock gear and install this gear without going through removing the chain cover off and etc? i will start the GP once i test fit and make sure there is no issues. check out the pics below and if you have any questions about the gear, please let me know. thanks, 101 http://www.101propose.com/star/GEAR1.JPG http://www.101propose.com/star/GEAR2.JPG http://www.101propose.com/star/GEAR3.JPG http://www.101propose.com/star/GEAR4.JPG http://www.101propose.com/star/GEAR5.JPG Edited January 9, 2009 by 101PROPOSE Quote Link to comment Share on other sites More sharing options...
BrazilBoy Posted January 9, 2009 Report Share Posted January 9, 2009 Looks awesome!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
toofast Posted January 9, 2009 Report Share Posted January 9, 2009 If everything goes right with it,that will be the next thing i get keep up the good work Quote Link to comment Share on other sites More sharing options...
NWStarionModder Posted January 9, 2009 Report Share Posted January 9, 2009 hello members, i have finally received the sample mk1 camgear. this gear has new machined steel outter gear(not modified stock replacement gear) and billet anodized(red or blue) finish aluminum inner piece with six big stainless steel allen bolts. i will be installing this gear and testing it out on my 87 starion. can anyone tell me if there is an easy way to remove the stock gear and install this gear without going through removing the chain cover off and etc? i will start the GP once i test fit and make sure there is no issues. check out the pics below and if you have any questions about the gear, please let me know. thanks, 101 http://www.101propose.com/star/GEAR1.JPG http://www.101propose.com/star/GEAR2.JPG http://www.101propose.com/star/GEAR3.JPG http://www.101propose.com/star/GEAR4.JPG http://www.101propose.com/star/GEAR5.JPG If you can put a small piece of something down in so the chain stays on and the tensioners dont move to much, the chain should stay in place and theres a bolt that needs to come off I believe then the gear comes out with a little nudge, the idea is to not let the chain fall out of place! Should be able to do it with only the valve cover off. Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted January 9, 2009 Report Share Posted January 9, 2009 Use an impact wrench to get the old gear off, torque wrench to put the new one on. Kane Quote Link to comment Share on other sites More sharing options...
JohnnyWadd Posted January 10, 2009 Report Share Posted January 10, 2009 i would like on for one of these Quote Link to comment Share on other sites More sharing options...
black86tsi Posted January 10, 2009 Report Share Posted January 10, 2009 now i know why people say that you are hard on a paycheck Quote Link to comment Share on other sites More sharing options...
spoolinturbo Posted January 12, 2009 Report Share Posted January 12, 2009 dangit, that one looks better then the adj. one i got now =/ Quote Link to comment Share on other sites More sharing options...
101PROPOSE Posted January 13, 2009 Author Report Share Posted January 13, 2009 (edited) hello members, today i took off the valve cover and tried to remove the stock cam sprocket but no good. taking the big mounting bolt wasnt a problem but taking the gear off the chain was hard. when i pulled up the chain, there was barely enough space to move the chain over a tooth but not enough to slide out the gear. there is a little metal piece right below the gear, looks like it is holding the gear up in place when the mounting bolt is off. can i take this off? has anyone done this without removing the chain cover and etc..? thanks, 101 http://www.101propose.com/star/MK1-CAMTEST1.JPG Edited January 13, 2009 by 101PROPOSE Quote Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted January 13, 2009 Report Share Posted January 13, 2009 You should be able to tilt the gear a bit and remove the gear, but if u need more slack you can slide a long flathead inbetween the timing chain and depress the tensioner to give you more slack in the chain. Hope this helps. Quote Link to comment Share on other sites More sharing options...
101PROPOSE Posted January 15, 2009 Author Report Share Posted January 15, 2009 You should be able to tilt the gear a bit and remove the gear, but if u need more slack you can slide a long flathead inbetween the timing chain and depress the tensioner to give you more slack in the chain. Hope this helps. CaliConquestAlex, ' thanks for the tip! tilting the gear helped alot removing the stock gear. mk1 gear bolted right on perfectly without any issues. i will put everything back and start her up tomorrow. thanks, 101 http://www.101propose.com/star/GEARTEST1.jpg Quote Link to comment Share on other sites More sharing options...
Jetspd150 Posted January 15, 2009 Report Share Posted January 15, 2009 That thing looks hot!!!! Good work 101. CaliConquestAlex, ' thanks for the tip! tilting the gear helped alot removing the stock gear. mk1 gear bolted right on perfectly without any issues. i will put everything back and start her up tomorrow. thanks, 101 http://www.101propose.com/star/GEARTEST1.jpg Quote Link to comment Share on other sites More sharing options...
pitboss Posted January 20, 2009 Report Share Posted January 20, 2009 Not sure if this will matter but you want to try and do this at TDC. Might not matter here though. Quote Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted January 20, 2009 Report Share Posted January 20, 2009 Probably easier to do it at TDC, but it shouldn't be a requirement. Since the dowel synchronizes the cam gear with the cam, it shouldn't matter. With the dowel pin on top at TDC, it's much easier to remove the cam gear, IMO. Quote Link to comment Share on other sites More sharing options...
MAZINGAQUEST87TSI Posted January 21, 2009 Report Share Posted January 21, 2009 hi.. have a question about this... the previous tiiming gear made it by 101 is no good? or any reason for a new desing? thanks! Quote Link to comment Share on other sites More sharing options...
101PROPOSE Posted January 22, 2009 Author Report Share Posted January 22, 2009 hi.. have a question about this... the previous tiiming gear made it by 101 is no good? or any reason for a new desing? thanks! MAZINGAQUEST87TSI, previous ones i have sold on ebay are made here based on the same specs(but with a little different design) as this new one and the new ones are being mass-produced by a factory in overseas. thanks, 101 Quote Link to comment Share on other sites More sharing options...
101PROPOSE Posted January 22, 2009 Author Report Share Posted January 22, 2009 Not sure if this will matter but you want to try and do this at TDC. Might not matter here though. pitboss, i do agree with you but i marked the chain, distributor and everything else before i took off the stock gear so everything went fine. thanks, 101 Quote Link to comment Share on other sites More sharing options...
101PROPOSE Posted January 22, 2009 Author Report Share Posted January 22, 2009 sorry for the late update on testing out the new gear. i have been busy and finally put everything back but just noticed dead battery. i will charge it up and try it again. thanks, 101 Quote Link to comment Share on other sites More sharing options...
superscan811 Posted February 7, 2009 Report Share Posted February 7, 2009 Hi, just wondering what is happening with this GP as I am interested in purchasing a couple of these Adjustable Cam Gears... Cheers. Quote Link to comment Share on other sites More sharing options...
Technology Posted February 7, 2009 Report Share Posted February 7, 2009 Good question. Just to note, maybe it was already pointed out, that with any adjustment to the cam timing, you will have to reset your ignition timing. Not a problem, but anyone who gets this will want to do that. Quote Link to comment Share on other sites More sharing options...
101PROPOSE Posted February 12, 2009 Author Report Share Posted February 12, 2009 Hi, just wondering what is happening with this GP as I am interested in purchasing a couple of these Adjustable Cam Gears... Cheers. sorry for the delay. i havent had a chance. i still need to get a new battery and test it out asap. i will start this GP once i get the confirmation that the gears are ready to ship(15-30 days). thanks, 101 Quote Link to comment Share on other sites More sharing options...
tsiconquest88 Posted February 14, 2009 Report Share Posted February 14, 2009 How much? Quote Link to comment Share on other sites More sharing options...
101PROPOSE Posted April 18, 2009 Author Report Share Posted April 18, 2009 How much? tsiconquest88, sorry for the late reply. i just got the shipment in. but i still have not tested the one i installed on my 87. i will charge the battery and take a video clip. also figure out the GP prices and start the GP shortly. thanks, 101 http://www.101propose.com/gp/MK1-STAR-ACG1.JPG http://www.101propose.com/gp/MK1-STAR-ACG2.JPG Quote Link to comment Share on other sites More sharing options...
101PROPOSE Posted April 21, 2009 Author Report Share Posted April 21, 2009 finally charged the battery and tested the mk1 adjustable camgear. here is a video clip. it rattles alot as i barely have the downpipe on the turbo without the o2 sensor with one nut holding it and nothing after the dp. thanks, 101 MK1 ADJUSTABLE CAMGEAR VIDEO CLIP Quote Link to comment Share on other sites More sharing options...
Komeuppance Posted April 21, 2009 Report Share Posted April 21, 2009 finally charged the battery and tested the mk1 adjustable camgear. here is a video clip. it rattles alot as i barely have the downpipe on the turbo without the o2 sensor with one nut holding it and nothing after the dp. thanks, 101 MK1 ADJUSTABLE CAMGEAR VIDEO CLIP Haha... I think you just wanted to show us how the engine sounds without an exhaust. -Robert Quote Link to comment Share on other sites More sharing options...
