Starquest Property Taxes Killing Me
19 replies to this topic
#1 jonboyb
jonboyb
  • 2,582 posts
  • Interests:Not saving money
Posted 18 June 2019 - 11:34 AM
My 84 Flatty has been dormant for a couple years while I built a house and got moved in, and did a full overhaul under the hood.  Went to tag office today to get tag reinstated and heard the inevitable.  "Sir you owe 2 years of back taxes to reinstate".  Ok,,....how much.  That'll be $2.22 sir :lol:
87 Valencia Quest - MPI MSII
84 Mezzon Gold Dodge Conquest - Timecapsule
16 Durango RT - Modded
19 Ecoboost F-150....Cause TT is Better than a V8
#2 pcristquester
pcristquester
  • 2,453 posts
Posted 18 June 2019 - 02:33 PM
if it were here in Cali, would have needed to add a couple or few zero's
#3 jonboyb
jonboyb
  • 2,582 posts
Posted 18 June 2019 - 03:36 PM
Happily reside in GA ;)  Rumor has it my county outside Metro Atlanta about to ditch 25 year old emission requirement too.  That would be awesome although all my SQs are exempt
#4 87redcat
87redcat
    10 years and counting...
  • 3,909 posts
Posted 18 June 2019 - 03:41 PM
Gotta love no inspection or emissions
#5 DieHARDmitsu.
DieHARDmitsu.
  • 1,869 posts
  • Interests:Star Orion
Posted 18 June 2019 - 05:28 PM
Here in FLauRidau...we ain't got none ah those... ;)
#6 Josh '88
Josh '88
  • 3,031 posts
Posted 18 June 2019 - 06:07 PM
Got any pics of the underhood overhaul?
Blue 88, 108k, stock
Red 88, 161k, 207hp/292tq, 14G@18PSI
Blue 88 MPI, 186k, 306hp/412tq (old turbo setup)
My pics of SQC Meets, CLICK HERE
#7 techboy
techboy
  • 3,328 posts
Posted 18 June 2019 - 10:47 PM
Too funny!!
#8 jinx
jinx
  • 1,936 posts
Posted 18 June 2019 - 11:55 PM
$2.22 ???   part it out. That'll teach 'em
#9 jonboyb
jonboyb
  • 2,582 posts
Posted 19 June 2019 - 06:05 AM
It's always been pristine underhood Josh.  Rear main was starting to seep a little and timing set was due, so Pagemo and I decided to just yank engine a do full overhaul on gaskets/seals and check clearances throughout.  At 117k miles but everything checked out like a brand new build...lol.  Other than the missing foam on AC line and paint on the OVCP, she's pretty clean.  Only change I've made since day one is the polished VC and Accel coil undehood.  AC, cruise, and everything else still works like a champ too (knocks wood).  Turbo went on previous owner like 15 years ago and they had it built into a small 16g best I can tell by the wheel (I know, nuts in a non-IC car) but at stock boost levels I have no A/F ratio problems, and the car has never seen more than stock.
Edited by jonboyb, 19 June 2019 - 06:11 AM.
#10 jonboyb
jonboyb
  • 2,582 posts
Posted 19 June 2019 - 06:40 AM
And this is the day it came off the auto transport truck from Los Angeles over 10 years ago....what a pile :lol:
#11 Bad2Rass
Bad2Rass
  • 439 posts
Posted 19 June 2019 - 11:50 AM
Love it... I can't wait to see how insane mine will be after 10 years... lol.
88- Starion- AEM Tru Boost Garret 60-1, 24PSI Tial wastegate, 3" Mandrel Exhaust, OVCP with Greddy Type-S B.O.V., GM MAS translator, a 284 Cam, Pauter rods, arp hardware, ross pistons, GATHERING MPI GOODIES!!!
88- Starion- Stock auto trans white
81 Dodge D50-Daily - Weber carb
93 Mercedes Benz 500SL- Stock
04 Montero Full Size- Family Mobile
2011 Lancer Ralliart awd turbo- Daily Driver- Stock for now SOLD
1990 Eagle Talon awd turbo- 16g safc maft. SOLD
#12 jonboyb
jonboyb
  • 2,582 posts
Posted 19 June 2019 - 12:01 PM
LOL...that's right, you didn't turn your vanity tag in :lol:
#13 Josh '88
Josh '88
  • 3,031 posts
Posted 19 June 2019 - 09:11 PM
Still looks sharp, Jon. I was wondering how it could look any better, lol.
#14 jonboyb
jonboyb
  • 2,582 posts
Posted 20 June 2019 - 09:16 AM
I've got to find a vendor for high temp foam to replace the wrap on that AC line for sure.  Stupid working AC :lol:  I have removed cats and secondary air system so I guess I have to change my description to heavily modified now ;)
Edited by jonboyb, 20 June 2019 - 09:17 AM.
#15 ucw458
ucw458
  • 11,581 posts
Posted 20 June 2019 - 03:49 PM
It will be difficult to find foam rubber insulation of the same thickness.  Most you will find will be much thicker.  I wouldn't go the split tube route.  It works ok but the taped seam doesn't always hold well and falls off.  The solid tube stuff lasts longer but you have to disconnect the pipe.  Another option I have used alot is foam tape or cork tape.  Both are easy to find.  Cork tape is a tar impregnated cork strip.  Older cars used that.  It's good stuff, formable and will stick to itself.  But those options wont look stock.
Other than appearance, not having that foam wont make the AC stop working.  The line may condense moisture from the air like the outside of a glass of icewater.  But that's all that will happen.
My 87
#16 jonboyb
jonboyb
  • 2,582 posts
Posted 24 June 2019 - 06:54 AM
Just an eyesore of course on the AC.  Grainger sells an "Aeroflex elasotomeric" pipe insulation that's rated to 300 degrees F.  It's also super cheap on the order of $5 per 6' stick.  Not split though and no way I'm pulling a line on a working R12 system, but I may split it an use steel ties.  Even the factory insulation has one if you look behind the turbo heat shield.  Would certainly look better than it does now....lol.  Figured I'd orient the split on the bottom....that way invisible and any potential condensation has a gravity outlet versus pooling in the insulation.
Edited by jonboyb, 24 June 2019 - 06:56 AM.
#17 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,394 posts
Posted 24 June 2019 - 09:13 AM
junk...you should just park it over here and i'll take care of it for you ;)
          MOPAR POWERED
#18 jonboyb
jonboyb
  • 2,582 posts
Posted 24 June 2019 - 10:21 AM
The only junk is that polished valvecover....some rapscallion by the name of Harry sold it to me (had to use old timey words so Harry understands) :lol:
Edited by jonboyb, 24 June 2019 - 10:52 AM.
#19 pure_insanity
pure_insanity
    comfotably content
  • 7,022 posts
Posted 08 July 2019 - 10:58 AM
damn, your taxes are cheaper than mine.  even way out here, my taxes for the last two yrs are going to be about 20.00$
I hope your property taxes will be cheaper than mine. they went up so bad this year I'm actually going to appeal it.
some good mpi info that may help someone.
mpi stuff
life is like a roll of toilet paper. the closer you get to the end-the faster it goes.
#20 jonboyb
jonboyb
  • 2,582 posts
Posted 09 July 2019 - 02:21 PM
Already appealed mine in the new house....it was BAD.  But my total bill at the tag office was $12.22 ($10 tag fee) :D
Edited by jonboyb, 09 July 2019 - 02:22 PM.
