Lowering springs
15 replies to this topic
#1 croquest87
  • 641 posts
Posted 14 May 2018 - 05:36 AM
Looking for set of lowering springs.Have brand new set of stock strutts for the rear and kyb inserts for the front and would like to drop her some but not to much more like 1"-1 1/2" or so  or good recommendation on a set w proven quality. Thank you
#2 87redcat
87redcat
    10 years and counting...
  • 3,638 posts
Posted 14 May 2018 - 06:40 AM
I have a set of ST lowering springs on my 87 with mk1 older rear struts and tokiko front inserts. Using mk1s adj camber plates front and rear. Lowers it about an inch. Without the camber plates you would get more. Maybe a 1/2 to 1" more max. They ride a little stiff cause they are not progressive springs.
Eibach springs are progressive and you'll get about the same in lowering. Smoother ride.
Dont know about mk1s lowering springs.
And you have D2 coil overs (if you can find them cause they are out of production)
And a new company Legiom Motorsports, offering coil overs what apear to be comparable to D2s.
#3 Preludedude
Preludedude
  • 2,452 posts
Posted 14 May 2018 - 07:16 AM
Cosmo available also.
#4 TexasQuest
  • 8,537 posts
Posted 14 May 2018 - 09:33 AM
KSport still has coilovers
88 Fiji Blue -Tsi
#5 Ptracy262
Ptracy262
  • 35 posts
Posted 14 May 2018 - 10:10 AM
I have a set of Cosmo dual spring coil overs brand new in box if want pics just let me know,  I think I was asking 150.00.
#6 croquest87
  • 641 posts
Posted 14 May 2018 - 10:37 AM
Sure thing pm me thank you
#7 croquest87
  • 641 posts
Posted 14 May 2018 - 11:46 AM
Pmd  you back thank you
#8 croquest87
  • 641 posts
Posted 14 May 2018 - 04:59 PM
Just bought some adjustable d2 cosmo coilovers from Ptracy262. Called the manufacturer and guy l talked with said that only thing that needs moded is the nut that holds the front insert in needs ground down some so sleave fits over it. Any other input from guys that installed them before is much apreciated thank you.
#9 Preludedude
Preludedude
  • 2,452 posts
Posted 14 May 2018 - 05:44 PM
With my Cosmos, I had to drill out the hole on the aluminum top hat so it slid over the strut.   Just make the hole bigger.
#10 croquest87
  • 641 posts
Posted 14 May 2018 - 06:05 PM
Maybe that's what this guy was referring to l couldn't understand him very good was speaking in heavy Asian accent.Thank you Preludedude
Edited by croquest87, 14 May 2018 - 06:08 PM.
#11 MotoCam360
MotoCam360
    Motocam360
  • 2,044 posts
Posted 14 May 2018 - 06:33 PM
I have a set of green ST springs I could part with (front and rear)
Tim
My Feedback Link
#12 croquest87
  • 641 posts
Posted 14 May 2018 - 07:46 PM
Thank you for your offer l just bought some Cosmo d2s from one of the members here in post above.
#13 TexasQuest
  • 8,537 posts
Posted 15 May 2018 - 06:17 PM
Wait D2 makes Cosmo stuff? I thought Cosmo was it's own brand from Canada?
88 Fiji Blue -Tsi
#14 croquest87
  • 641 posts
Posted 15 May 2018 - 06:59 PM
Never mind they are Cosmo coilovers.l don't think d2s. Lol
Here they are!
Coilovers starquest https://imgur.com/a/GpsBHut
#15 psu_Crash
psu_Crash
  • 6,990 posts
Posted 15 May 2018 - 08:09 PM
I was about to correct you. Cosmo and D2 are not the same. Cosmo are just coilovers. D2 is a full system and MUCH nicer ;)
My Feedback Link
#16 Preludedude
Preludedude
  • 2,452 posts
Posted 15 May 2018 - 08:31 PM
And stiffer.   If thats what people want....some wouldn't consider it nicer.
In my 9 yrs here, I've seen used sets for sale because people didn't like the ride......
