Metric-man Posted September 19, 2011 Report Share Posted September 19, 2011 What do you use to recharge the washable air filter on your car ? Some people say WD-40 others say engine oil or transmission fluid While still others ask the question why mess with a resuable filter just use a paper filter? And some will question why can't you afford the correct oil ? So what do you use or don't use is the question here. Link to comment Share on other sites More sharing options...
Burton Posted September 19, 2011 Report Share Posted September 19, 2011 I just buy the proper oil. I'm sure there's something that works just as well, but I stick with what is called for by the manufacturer, even if it does cost a couple extra bucks. I don't know if the washable filters offer as much benefit as they claim, but I've seen noticeable performance and gas mileage improvements with them so I have to say they are deffinately better than just a OEM style filter. Of course, no matter what filter you use, the biggest thing is making sure you wash/replace your filter regularly. A filter with bad airflow is no good whatever filter it is. Link to comment Share on other sites More sharing options...
Metric-man Posted September 19, 2011 Author Report Share Posted September 19, 2011 I just buy the proper oil. I'm sure there's something that works just as well, but I stick with what is called for by the manufacturer, even if it does cost a couple extra bucks. I don't know if the washable filters offer as much benefit as they claim, but I've seen noticeable performance and gas mileage improvements with them so I have to say they are deffinately better than just a OEM style filter. Of course, no matter what filter you use, the biggest thing is making sure you wash/replace your filter regularly. A filter with bad airflow is no good whatever filter it is. And some will question why can't you afford the correct oil ? Check Link to comment Share on other sites More sharing options...
Caliber308 Posted September 20, 2011 Report Share Posted September 20, 2011 (edited) I use a washable Cone Air filter....But have never had the need yet to wash it. I ran a K&N on my 1st Gen Mas set up...Didn't care for it. All this oil spraying on the Air filter makes me suspect as to the "real" air flow your getting. In all the years, and all the High Performance cars I've owned. I never sprayed a Air filter with oil. Bill Edited September 20, 2011 by Caliber308 Link to comment Share on other sites More sharing options...
Metric-man Posted September 20, 2011 Author Report Share Posted September 20, 2011 I use a washable Cone Air filter....But have never had the need yet to wash it. I ran a K&N on my 1st Gen Mas set up...Didn't care for it. All this oil spraying on the Air filter makes me suspect as to the "real" air flow your getting. In all the years, and all the High Performance cars I've owned. I never sprayed a Air filter with oil. Bill Aren't you supposed to oil them after you clean them, oh you never cleaned one.. Bill if you have 1000 miles or more using the filter or have had it sitting on the vehicle for 6 months or more you should clean it and re oil it. The air filter element and its paring with oil goes way back so much that it can seriously be referred as OLD SCHOOL Bill did you ever see the 50's Plymouths? Their filters sat in motor oil and are known as oil bath filters. I'm pretty sure you cannot use motor oil on a K&N or a foam filter, but it is a petrolatum derivative. Link to comment Share on other sites More sharing options...
holeysocks Posted September 21, 2011 Report Share Posted September 21, 2011 Marvel Mystery Oil Link to comment Share on other sites More sharing options...
JAinsworth Posted September 21, 2011 Report Share Posted September 21, 2011 I use the K&N Recharge kit. Link to comment Share on other sites More sharing options...
Metric-man Posted September 21, 2011 Author Report Share Posted September 21, 2011 (edited) Marvel Mystery Oil Where did you hear that from ? Have you used it ? Does it work ? I've been looking at the DSMS sheets for both the K&N filter oil and Marvel Mystery Oil It seems to have all the same ingredients except MM has a winter green scent; of course you're never to breath either one, because they are made from naphtha, paraffinic benzene, and mineral oil base. I've used MM in my gas tank to help preserve my injectors from the corn squeezins (ethanol) that they adulterate our gasoline with now. But I've read it is not compatable with methanol. Edited September 22, 2011 by Metric-man Link to comment Share on other sites More sharing options...
holeysocks Posted September 21, 2011 Report Share Posted September 21, 2011 (edited) Works just fine! also use it on Lawn Mower filters...Wal Mart has it Edited September 21, 2011 by holeysocks Link to comment Share on other sites More sharing options...
DryBear Posted September 21, 2011 Report Share Posted September 21, 2011 You could try the AEM Dryflow filter - doesn't use any oil at all. Link to comment Share on other sites More sharing options...
Caliber308 Posted September 22, 2011 Report Share Posted September 22, 2011 You could try the AEM Dryflow filter - doesn't use any oil at all. Len, I use a APC cone Air Filter. It also doesn't require oiling. Bill Link to comment Share on other sites More sharing options...
