ECU reset
When to reset/ how
3 replies to this topic
#1 markp
markp
  • 92 posts
  • Interests:Customizing cars
Posted 19 January 2019 - 07:33 PM
If u make a change to exhaust system or change  , injectors, intake air flow,” any change” does your computer remember the old way it was running and get confused w/ the new changes u did for a while and run ruff. Should u reset computer to start fresh.? If so what’s the best way to reset I have heard all kinds of ways to reset ,pull neg off battery,pull pos.off first . Pull fuses , remove left front tire turn on key 3 times , which one is right and does it reset instantly to normal operation or do u have to  Cruise around for a while
#2 rcm
rcm
    rcm
  • 2,203 posts
    muscle cars.
Posted 19 January 2019 - 07:38 PM
Our computers are not that smart.You only pull negative to clear codes.
#3 TexasQuest
  • 9,118 posts
Posted 20 January 2019 - 12:17 AM
No. Our ecu's are so old they aren't even eprom chipped.
88 Fiji Blue -TSi
#4 freebird
freebird
  • 2,931 posts
  • Interests:time is of no moment, but only what your doing
Posted 27 January 2019 - 04:54 PM
Keep battery hooked up. Turn car on it&rsquo;s roof. Shake aggressively 3 times (if shake 4 then you will have to start all over so b careful)
Put back on its wheels wind it up a bit, then let it go!
Reset and manual tune! Better than new!
I usually add nitrous oxide at this point so my and your results may vary.
