89 with 1jz/gs6-37 trans
1 reply to this topic
#1 Ipjkcu
Ipjkcu
  • 52 posts
Posted 24 November 2018 - 03:13 PM
https://youtu.be/T-LWTIFY6D0
Quick walk-around. Many things left to do but it's runs and rips. Stock 1jz & ecu topmount turbo 30/76..82 AR rear exit. Stock 380cc injectors, stock fuel lines 450 pump. 05 bme 330i 6spd trans. Aftermarket flywheel / adapter plate. Stock bmw clutch pressure plate.  Changed clutch master to a 7/8. Clutch holds well until over around 320 wtq, based of knowledge from bmw guys and power numbers of 1jz. So I am limited to 13 to 14.5 of boost. Depending on outside Temps.. Clutch upgrade coming soon as long as revision to trans tunnel. And exhaust. Possible cage install. End goals daily driven autocross monster.
#2 Rick50
Rick50
  • 95 posts
Posted 27 January 2019 - 05:56 AM
Nice job
