Ok, how do i open the rear hatch?
11 replies to this topic
#1 Preludedude
Preludedude
  • 3,026 posts
Posted 14 May 2019 - 12:47 PM
My hatch has always been a pain in the butt....The passenger side never wants to open...So when I pull the release handle, the driver side becomes loose, but the passenger is always stuck. I have to tug on the release handle beside the seat multiple times before it will open....
I figured the cable has stretched, and not doing its job....
NOW the hatch will not open at all.
What do I need to do now that the release handle isnt working?   Once I get inside, I will adjust the cable as I have read on here before....
#2 Crazy larry
Crazy larry
  • 2,050 posts
  • Interests:Cool Cars
Posted 14 May 2019 - 01:19 PM
silicone spray lube could help
87 Atlantic blue v-8   89 Fiji blue unmolested stock low mileage.  Daily driver 87 Black. 88 white Drift car..SOLD
#3 Preludedude
Preludedude
  • 3,026 posts
Posted 14 May 2019 - 04:20 PM
Yes I figured I need to use some...
BUT for now, I need to figure out how to get the hatch open
#4 vbrad511
vbrad511
  • 8,338 posts
Posted 14 May 2019 - 04:59 PM
Key not working? If it does, you can pull the carpet/trim over the mechanism and, if I remember right, you can adjust each release separately. It'll take some looking at to figure out, but I'm pretty sure it's do-able.
#5 Preludedude
Preludedude
  • 3,026 posts
Posted 14 May 2019 - 05:01 PM
Nope, key isnt working either...
#6 ucw458
ucw458
  • 11,591 posts
Posted 14 May 2019 - 06:02 PM
Been there.  Did this on Louswheel's car.  Crawl through the trunk and take off the rear carpeted cover.  Then you can manually release the hatch while pushing up on it with your back.  Then adjust the latches/cable.
My 87
#7 Preludedude
Preludedude
  • 3,026 posts
Posted 14 May 2019 - 06:30 PM
Where do I manually release it at? This will be fun since there is a fuel cell back there...
#8 ucw458
ucw458
  • 11,591 posts
Posted 15 May 2019 - 12:09 AM
Once you get the cover off you will see where the cable connects to the latches.  Push that to the side to release.
My 87
#9 importwarrior
  • 18,311 posts
Posted 15 May 2019 - 04:52 AM
you might need to actually adjust the hatch itself. it might
need to be pushed towards the front of the car ???
I read somewhere where jimmy A, had adjusted his by loosening
the mounting brackets on roof. and having someone pushed it and
holding it while he tightened the brackets back up.
over time it tends to move a little.
#10 TexasQuest
  • 8,951 posts
Posted 15 May 2019 - 10:16 PM
Sounds like the hatch door itself needs to be re-adjusted
88 Fiji Blue -TSi
#11 Preludedude
Preludedude
  • 3,026 posts
Posted 16 May 2019 - 07:43 PM
So I got it open.  It was simple.   I removed the privacy cover.  And fortunately I don't have the carpeted cover over the tail lights.   So the latches were exposed.   I just reached and tugged on the metal bar by hand and it released.
I adjusted the cable/spring so it opens fine now.
Edited by Preludedude, 16 May 2019 - 07:44 PM.
#12 croquest87
  • 1,628 posts
Posted 16 May 2019 - 07:54 PM
Had to climb in the back of my 89 bunch of times to open it lol  Will have to look at that one of these days and fix it for good.
