1UZFE swap build and collective information thread.
51 replies to this topic
#41 jmswltn
jmswltn
  • 68 posts
Posted 01 August 2016 - 08:47 PM
Not much to report summer is my busy time at work so I don't get as much time with this as I'd like.
I got the megasquirt mounted and wired to the dual 22 pin weatherpacks and have been inactively building the diagram for the engine side.
I was getting burned out so I have been throttling back on the project to catch back up with life stuff.. Did get another toy that has been hindering my progress
I'm thinking I am going to go with a floor mounted pedal system to keep the clutter in the engine bay down a little bit.. that and I have no idea how I'm going to set it up without a power booster.
#42 jmswltn
jmswltn
  • 68 posts
Posted 17 November 2016 - 08:20 AM
Perhaps it's time to catch up..
The rack swap was a success for the most part I did have to cut down the tie rod adjuster sleeves.
I had to take this all apart
to get to this
and these powder coated.
No image of it right now but installed a full set up GNT bushings
https://www.google.c...ZEsCzzojXWQ1qZg
I took this
sandblasted it in my roughneck sandblasting barrel (patent pending)
cleaned, etched, primed and painted the engine bay
wrapped all my pipes
made a brake booster bracket from original piece
radiator fan shroud
#43 jmswltn
jmswltn
  • 68 posts
Posted 17 November 2016 - 08:36 AM
radiator and hood latch support bar
test fitting intercooler
drive shaft made
first start
no video here
intercooler pipe fabbing
dyno run:
I can't upload a link to it sorry
but for now I'm sitting at 303 and 343tq at 5lbs
because of my narrow piping for the up pipes I start choking around 5200 rpm
#44 WNCStarion
WNCStarion
  • Newbies
  • 6 posts
Posted 16 June 2017 - 11:57 AM
Interesting thread. I signed up for this site when I got my first Starion and now that I'm at 3 and am doing my own 1UZFE VVT-i swap, I thought I'd check out the site again. Imagine my amusement to see another 1UZFE.
I like that you're going whole hog right out the gate with the turbo stuff.
I have a thread going over here: https://forums.somet...hreadid=3821866
#45 88351wtsi
88351wtsi
  • 965 posts
  • Interests:My kids, music, and cars, not always in that order.
Posted 16 June 2017 - 07:02 PM
Looking good. What brake booster and master cylinder are you using?
1988 Conquests
His:  Durban maroon with 351w
#46 jmswltn
jmswltn
  • 68 posts
Posted 19 July 2017 - 09:13 PM
I'm using the generic ebay 7 inch dual diaphragm unit reworked to use our master
#47 importwarrior
  • 18,244 posts
Posted 20 July 2017 - 05:26 AM
have more pics of the booster master cylinder you used?
#48 speedyquest
speedyquest
  • 4,085 posts
Posted 20 July 2017 - 10:24 AM
The build is looking great man. I am pretty much fully finished with my rack swap on my car as well and I wanted to mention two things.
1) You asked if anyone could verify that when you swap over to a rack, do you need to support or mount the end of the steering column? Well in my view the answer is a solid yes. Without doing that you will not only get movement in your steering joints, but you also create a situation where your steering column could move around quite a bit and in an emergency situation where you are really putting force into it you could break something. I'm curious what you ended up doing, I could show you how I am fixing that issue as well.
2) When you welded your adjustment sleeve for your tie rods I noticed you didn't sleeve them. I would highly recommend that only just so you are certain you didn't create a weak point. If that weld fails it would be really bad.
#49 jmswltn
jmswltn
  • 68 posts
Posted 02 April 2018 - 03:06 AM
well hello everybody!
the car has been fully assembled for some time now. Over this last winter I cut out all the rust in the rear quarters and grafted in a front and rear widebody. Its wrapped in roaring thunder color flip from avery. lots of other little stuff done but as with all these "projects" it never ends  I'll try and get some pictures posted soon if I can find another image server because photobucket sucks.
#50 jmswltn
jmswltn
  • 68 posts
Posted 02 April 2018 - 03:14 AM
I ended up using a bearing I mounted to a removable ring at the firewall. I had to add another join to the line and it ended up floppy..oh ya I also converted it to electric power steering using a prius column and wheel. then used an arduino to run the steering wheel buttons to output to my pioneer radio.. I left a few options for other uses but havent used them yet.
I made a multipass weld with a 45 on each side of the butt. It's plenty strong for that situation
#51 mbruneaux
mbruneaux
  • 1,431 posts
Posted 03 April 2018 - 03:40 PM
https://imgur.com/ is good for posting pics.
Canterbury, CT
1998 BMW 528i 5 Speed because the Suburban gets 10 MPG
#52 jinx
jinx
  • 1,896 posts
Posted 05 April 2018 - 02:35 PM
s366 turbo?  this UZ swap is fussy. Good u stuck with it
