Well this time is for real. Kicking myself for not already having the v8 swap done now!! The motor i purchased turned out to be a turd and has at-least some burnt valves and i got it as is. Not even interested into tearing into it honestly. So Its either v8 or im selling the whole car. Parts all for sale below! Make me a kick tail offer so i can move these parts!!! Shipping not included with these prices!! Paypal is Detriuch@gmail.com PM me if interested!!!!
1. 20g Tdo5h turbo. Has silver powder coated exhaust housing (inlet housing has a hairline crack about 2 inches but doesn't leak and still boost fine. Could swap out a housing if you really wanted to for around 100ish bucks) bolts right up to our manifold and down pipe. only about 4k miles!! $400 OBO
2. LC1 Wide-band 02 Sensor with Gauge and wiring. Just needs a new bung to weld in your pipe $ 110 OBO
3. Boost gauge (reads vacuum and up to 30lbs i think) $20.00 OBO
4.Safc 2 Controller with extended Harness $200.00 OBO
5. 2 Distributors. One with new rotor cap and new vacuum advance $ 60.00 OBO each
6. 2 factory style Fuel Pressure Regulator. One is pretty new! $30.00 obo for the newer.$ 15.00 for older one.
7. 88-89 ecu in 1987 case $60.00 OBO
8. Starter $35.00 OBO
9.Alternator $60.00 OBO Only a few months old
10. powder coated stressed relieved Factory Turbo Manifold $100.00 OBO
11.2gen dsm turbo air flow meter with filter adapter and Factory plug $70.00 OBO
12.Factory Front Mount Inter cooler $50.00 OBO
13. (1) 1987 Starquest Knock control Box $40.00 OBO
14. Accel Ignition Coil $20.00 OBO
15. 1987 5 spd transmission. Shifts decent $150.00 OBO
16. 1987 Starquest flywheel (needs resurfacing) $20.00 OBO
17. NGK Spark Plug wires $12.00 OBO
18.Hard-pipes for factory inter-cooler (Upper/lower with couplers Type S style bov and clamps) $200.00 OBO
19. Trilogy injectors with spacers 850/950. (only used for about 2 months)Need new o rings at the top though from pulling them out!! (fuel filter and pump/strainer was changed before install!!!$80.00 OBO
20. 2.5 inch down pipe with 2 bungs and with turbo gasket $ 55.00 OBO
21. Intake Manifold without sensors $ 25.00 OBO
22. Intake Manifold (Silver powder-coated without sensor) $40.00 OBO
23.Tps Sensor $45.00 OBO
24.ISC $55.00 OBO
25. Conquest Taillights in ok shape $40.00 OBO
26.I have 2 G54B engines. one has bad compression.( I think due to a burnt valve or 2) comes with arp studs. and more than likely other goodies inside. the other Has the rocker towers removed and needs either rings or valve stem seals. It smoked on Deceleration. Had great compression when pulled though!! No accessory's on either!!!. $250.00 OBO Takes them both!! (WILL NOT SHIP THESE!!)
Edited by gottraction
  • Like 1
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
