Preludedude Posted July 25, 2014 Report Share Posted July 25, 2014 Put in a new slave and clutch wont bleed. Pump and pump and cant get fluid to get to the slave cylinder...car has been sitting for years...Got an 88 and it Looks very tight...does anyone have a write up? It looks like brake master cylinder has to be removed? Link to comment Share on other sites More sharing options...
dmyers151 Posted July 25, 2014 Report Share Posted July 25, 2014 (edited) Sorry, I completely mis-read your post. Edited July 25, 2014 by dmyers151 Link to comment Share on other sites More sharing options...
markhansenconquest Posted July 25, 2014 Report Share Posted July 25, 2014 There are tiny holes in cyl that get pluged from sitting and they are pluged....rebuield or get new. Link to comment Share on other sites More sharing options...
ucw458 Posted July 25, 2014 Report Share Posted July 25, 2014 Open the slave bleeder then attach a hose to it running to a bottle. Then use some wood to hold the clutch pedal to the floor. That will start a gravity bleed. Stand by the resivour and refill as needed. After filling the resivour around 5-6 times it should be bled so top it off then tighten the bleeder screw. Then check for proper dis-engagement. Link to comment Share on other sites More sharing options...
importwarrior Posted July 25, 2014 Report Share Posted July 25, 2014 I reverse bleed mine takes longer to hook I up than to bleed it. I don't eve touch the clutch pedal at all Link to comment Share on other sites More sharing options...
Preludedude Posted July 30, 2014 Author Report Share Posted July 30, 2014 I'll try bleeding again but I have already bought a new one. Anyone got a write up? Does brake master cylinder need to be removed? It looks hard to get to from engine bay.... Link to comment Share on other sites More sharing options...
tsi_tom Posted July 30, 2014 Report Share Posted July 30, 2014 I had the same problem. I used a vacuum pump on the bleeder screw that was opened. Link to comment Share on other sites More sharing options...
