ALL LOWERED STARQUEST POST PICS!
I recently put some ST springs on my car. Of course i had the common rear sag issues so i cut about a half coil out of the front and it looks a tab better and does not bounce. I wanted to just see how slammed some others starquest owners may be. I will post pics of mine when i finish my lowering.
Bought the car with this stance. I actually need to ask what suspension is on the car lol
Edit - Found out the suspension. ST springs up front Eibach in the rear on Tokiko struts
http://i40.photobucket.com/albums/e214/bboyronnie/StarQuest/Quest_2.jpg
Edited by RonnieJ
Take a picture of your struts and springs and we will be able to tell you
My other set of D2s - kept the car higher because I hadn't installed rear pillow blocks for camber adjustment yet... still need to install them
http://i1210.photobucket.com/albums/cc409/motocam360/Quest%20windows/MC36089FijiD2.jpg
MR2 inserts in shortened housings, Cosmo single spring, with mookeeh pillowball adjustable plates at each corner
http://www.26liter.us/gallery/albums/userpics/10030/PA240104.jpg
I have more suspension travel left than I do ground clearance
Edited by D_Venable
Ven: do your lights still up and down? Do you have a write up on what you did?
They are fixed up in the position, welded the pivot point, and cut and rewelded the face of the assembly on to get the headlight aimed straight, motors are gone. You can go through my resto thread on the car, but it's getting pulled apart for good right now.
I wanna go lowar but I already have 2x12s in front of my driveway.
This is the lowest it ever was, not driveable tho-
http://i177.photobucket.com/albums/w239/johnboy9788/C360_2011-02-2613-00-35.jpg
This is on the daily.
http://i177.photobucket.com/albums/w239/johnboy9788/dragon1.jpg
just put the D2 coilovers in and raised it to align the car
http://i69.photobucket.com/albums/i51/cowcowmoo/low3.jpg
Swapped my buddies 19s on it
http://i69.photobucket.com/albums/i51/cowcowmoo/low2.jpg
Still lower than this
http://i69.photobucket.com/albums/i51/cowcowmoo/low.jpg
i wanted to align the toe and caster since the toe was off 4 degrees on the RR. I couldnt do anything else since there was no way i could get my car on the rack even with long ramps. but i got it pretty spot on and it drives great still
6 coils by my count in this pic:
http://home.comcast.net/~Komeuppance/TheShop.jpg
They're on the tops of the shelves, those are all stock Starion springs haha.
BTW, why is Dale's car bottomed out in 4x4 mode??
-Robert
  • Like 1
