CXRacing Radiator......Help!!!!
11 replies to this topic
#1 Ethan
Ethan
  • 57 posts
  • Interests:My main interest is learning more about my car right now. So if you can let me know what you guys know. Share your knowlage with me.
Posted 12 June 2016 - 10:52 PM
Okay I recently came into ownership of a cxracing radiator. And am now at an issue of its to big and the hood will not shut. If you have installed one and had this same issue any help would be greatly appreciated. Thank you in advance. Meant to grab a picture before I left but after working on it and my dads Isuzu I was warn out from this Florida sun.
#2 techboy
techboy
  • 3,434 posts
Posted 12 June 2016 - 11:02 PM
Don't have a CXR radiator, but if they bolt in like the stock one it should be held in with 4 bolts.  2 on the left, 2 on the right.  If it's sitting up too high and the and hood won't shut can you just enlarge or drill new bolt holes in the mount flange to move it down?  Or, is the problem that it's bottoming out and it's still to tall?
#3 chassispuke
chassispuke
  • 744 posts
Posted 13 June 2016 - 09:48 AM
Did u remove the bottom craddle that is used with stock radiator.  If not u have to get rid of it and also u might not be able to use the type of radiator  cap that has the pressure  relief  lever on it.
#4 techboy
techboy
  • 3,434 posts
Posted 13 June 2016 - 09:55 AM
Yeah, that's right ... there's a little C-shaped piece that bolts on the bottom with a rubber inset in it.  I think it's held in with two bolts.  Easily pops out.
#5 Ethan
Ethan
  • 57 posts
Posted 13 June 2016 - 01:54 PM
Yeah that piece has been taken out. And as far as I know its as far down as it will go its just about a half inch taller then the stock radiator from what my dad measured.
#6 techboy
techboy
  • 3,434 posts
Posted 13 June 2016 - 03:01 PM
Sounds like the wrong radiator to me. I did search on here through the advanced search tool and I couldn't find anyone else that had a CXRacing radiator fitment issue.
#7 chassispuke
chassispuke
  • 744 posts
Posted 13 June 2016 - 03:05 PM
I currently  have two *DM aluminum "CXRacing" radiators  installed  in 4 my cars and didn't  have any fitment issues at all. Take a measurement  from the bottom of tha radiator  to the center line of either side mounting  hole on the radiator  and compare it it to the stock one see if any discrepancy there. Has ur car ever been  in a front end collision??
#8 TexasQuest
  • 9,021 posts
Posted 13 June 2016 - 08:06 PM
I installed one a couple of months ago with no fitment issues.
88 Fiji Blue -TSi
#9 Ethan
Ethan
  • 57 posts
Posted 13 June 2016 - 09:22 PM
front end im not sure but I know the driver door has been replaced due to some kind of accident. that im sure wasn't reported.
#10 BC_99
BC_99
    Plays in traffic
  • 5,233 posts
Posted 13 June 2016 - 10:32 PM
If the car was wrecked bad enough for this to be an issue, there would be obvious signs of the damage. Take some pictures of the radiator and the car etc...and post them up, so we can see what you're dealing with.
BC
#11 Preludedude
Preludedude
  • 3,168 posts
Posted 14 June 2016 - 10:44 AM
I have one and installed with no issues.
Post pics so we can help....
#12 importwarrior
  • 18,313 posts
Posted 14 June 2016 - 06:28 PM
I got a cxracing 3 row and had it modified by bc99
Not the KDM cxracing one.
It fits perfect.
It is from a 240SX s13 1989 1994
