Flat sheet metal
tsi_tom
20 ga or 22 ga mild steel for body panels depending on how much shaping and welding you intend to do with it. For a fuel cell, stainless or aluminum.
BC_99
Edit, I get mine from one of 2 local metal suppliers, stock car steel or race city steel. You need to search your area for suppliers.
Edited by BC_99
I have read that some of the sheet metal is aluminized. For example:http://continentalsteel.com/Carbon-Steel/sheet-and-coil-steel.asp
Do you use the aluminized sheets?
By the way the stock tank is steel, so why not make it out of that?
Edited by tsi_tom
BC_99
Britt,
http://www.stockcarsteel.com/
That is a nice site. I like how it give the example for use. Thanks!
Are you using the Cold Rolled 1008 Steel Sheet?
Edited by tsi_tom
Yes mostly but it depends on the application. We never use aluminized steel because it's nasty to weld. It's used for heating and air duct work in houses mostly. I recommend aluminum or stainless for a fuel cell (assuming you are building a full custom cell) because it's corrosion resistant, where as mild steel will rust. Plus a stainless or aluminum tank hanging out from under the back of a car just looks bad tail.
BC_99
