Dsport G54B head development
#1
Posted 22 February 2021 - 11:25 PM
I wonder if we might might get a late morsel of goodness.
Suspension upgrades:
Eibach springs
Mookeeh shocks
Looking for bushings of any type Whiteline?
Engine upgrades:
Magna intake
Installing MS2
#2
Posted 23 February 2021 - 09:04 AM
Zoom clutch, Fidanza flywheel, Stedebani shifter, KSport coilovers, ST swaybars, abs delete, a/c delete, cruise delete, JVE, BSEK, TEP steel brake lines, LSP braided cooler lines, CX Racing radiator, MK1 silicone hoses, MK1 pullies, *DM hard pipes & intercooler,14G turbo, ported exh. manifold, MAF Translator, 3.5" GM maf, Turbo XS RFL bov, *DM 3" exhaust, Cusco front strut bar, TEP rear strut bar, Enkei 92's, HKS turbo timer, AEM wideband, AEM boost gauge, AEM oil pressure gauge, SPA fuel regulator, Hallman boost controller
JohnnyWadd, on 04 March 2010 - 10:01 PM, said:
#3
Posted 23 February 2021 - 09:14 AM
Performance Coatings! Pistons, manifolds, bearings and more!
Now a graduate of EFI University! www.efi101.com
ECU Vendor link: http://www.starquest...howtopic=137426
#4
Posted 23 February 2021 - 12:33 PM
And someone else reminding us that our heads suck
The Valencia Project
My Feedback Link
#5
Posted 23 February 2021 - 01:11 PM
Their solution to improve the ports on an old head that was designed without CFD modeling, is to make them look like the ports on modern heads, which were designed with CFD modeling. Go figure.
#6
Posted 23 February 2021 - 01:55 PM
I don't recall the G54 cyl head actually ever having a 'flow' problem.
1st import in the 7s ?
4cylFury on stock head
EIP blue street car, stock head, stock cam 11.2, then 10.6 spraying a 75 shot at launch
Rank red car 721hp, 556tq severly bottle-necked by moded stock exhaust manifold
Quality camshaft developement always seem to be the prob, from my observation
Even if u get some magical head or even a dohc one...... there will still be the same cam problem, so.......
#7
Posted 23 February 2021 - 03:41 PM
#8
Posted 23 February 2021 - 03:49 PM
#9
Posted 23 February 2021 - 03:58 PM
As stated in the article the problem does not show on the flow bench and though I am not familiar with those specific builds I seem to remember most people having problems getting north of 350 hp, most with more torque than hp (torque wins races...blah blah).
Regardless of the outcome it is fun to see people still thinking about our humble engine.
Also if a new head were designed it seems like cam options would open up (solved), just select a cam from another engine with fresh blanks to grind, maybe an adapter for timing chain sprocket.
Eibach springs
Mookeeh shocks
Engine upgrades:
Magna intake
Installing MS2
#10
Posted 24 February 2021 - 05:31 AM
Quote
Is the hotside choking ? Cam ground correct and in sync ? Valvesprings killing power and rpm ?
Post above yours, street car 500+hp/500+tq.... same 'crappy' head. An example of when you put in the effort.
They can consult him, or reference other 350+hp builds like their target
One clubmember actaually measured a popular schnieder cam (who does that?) and discovered the grind was off
Made schnider 'get it right'. Result was almost a 100hp gain. Even if a 'happy' dyno, the difference was a tremendous
New head wont get you that, or fix that cam problem
I posted a old stock 2.0 DSM, stock cam, stock head... rev 8600rpm & hit 600hp
A stock head, stock cam 1.6 miata, rev 8800rpm, 547hp. Single item both of em changed was valvesprings
A few got the G54 to rip..... with the same crappy head. They've cracked the code by sweating the details imo
#11
Posted 25 February 2021 - 03:50 PM
Edited by Jonathan, 25 February 2021 - 03:59 PM.
#13
Posted 26 February 2021 - 03:19 AM
....I looked on TEP it cost like 1800-1900 with a stock cam and they dont use AMC now they use a M26 )..Ok back to the subject ,, when chrysler joined in they cast there own head to save money......( bad idea cheap alum with impuritys thats why they break pressure runs to impuritys and flashing spots thats why racers grind off the flashing on there trans to make those flaws go away ... Pressure runs to flashing and impurtys and the heat stays there like a heat sink.. When U solider in new parts on a electric board and removes the heat to save the new part from burning up..Since the heat runs to the flaws in your stock manifold they grind them off ,,so the heat can flow to the heat sink exhaust gasket thats why there made out of 3 pieces of sheet metal to remove heat from manifold....!!! and take up the pressure off the expanding alum that breaks your exhaust bolts......
) ......I have a chysler head ,,a carvan head (over sized cam bearings to support the smog pump bolted on back side of cam ) and a AMC MARNEL ...IM a tool and die maker since i was 18 .. ( 40 years )..U can see the diffrence in the casting ..The AMC MARNEL head has nice ad sharp water ports with very little flash and the grade of alum is good alum not like the aftermarket ones ...i heard good things about the M26 head ,but i would grind all the flashing off the water ports to get MAX antifreeze flow.........If u want to make a good head U need to start with good ALUM like 6061 T6 aircraft alum and machine it from a solid block not a casting....even the JVE is no good ,,because the metal the bolt is made out of expands more that alum when heated ....If U over heat your head u need to make sure the exhaust flange didn t warp...The best thing to do with after market head is to tap the m6 bolts to standard 3/8 - 16 ..when the bolt is stripped u take a 5/16 .3125 drill and drill 1/8 0r .125 deeper on exhaust bolt holes and tap 3/8 -16 and bottom tap it to fit the bigger 3/8/16 to fit and use 1.750 set screws made out of 4130 chromoly metal.........Open up all exhaust holes up to 1/32 over 3/8 to allow it to move with out breaking bolts.....when the bolt is stripped out the hole is .310 a 3/8 - 16 thread tap drill is .3125 .0025 bigger its the next bigger size to go to because its so close to .3125...U cant make some thing better than the metal it was made out of ??? if u can get a marnel njv head.........I watched a show call forged in fire and they let contestents make a blade and they dont even tell U what kind of metal they use..........what a JOKE lets make it out of a old cresent wrinch !!!! METAL IS EVERYTHING just like the right kind of oil...........
Edited by markhansenconquest, 26 February 2021 - 04:46 AM.
#14
Posted 03 March 2021 - 09:11 PM
Where the rubber meets the road is what matters imo. Seen anyone drive a flow bench lately ?
You want a quick entertaining ride or prefer to get off writing a useless techno-babble paper ?
Praise the 4G63 as mitsu best ever, in contrast to mitsus G54 flop. Horse5hit
They run very close oem 1/4 mile times. 54 the 1st 4cyl in the 7s, 4G63 1st in the 6s. Both look great to me
Several full street 54s gone 12s on TBI/stock ecu, stock head, stock bottom end. A couple still on stock cam
The article should start off by explaining how bad those 54 struggle to perform
#15
Posted Today, 11:09 AM
#16
Posted Today, 01:45 PM
Don't ever change, SQC.
#17
Posted Today, 01:46 PM
