Polyurethane Subframe Bushings
40 replies to this topic
#21 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 04 November 2013 - 12:11 AM
Yeah these are quite difficult to replace.  This is the walkthrough......READ THIS THREAD FIRST!  http://starquest.i-x...er=asc&start=50
If you don't have a login...it is a good idea to make one.
Edited by Laodicea, 04 November 2013 - 12:30 AM.
Gnothi Seauton 515 rwhp/527 Lbs.@21psi....nuff said.
2JZ-HX40 Na-T swap Conquest.  FAST Classic ECU, dual walbros -8an PTFE, stock NA pistons & Turbo HG, Arps, Custom FFIM for 1200cc injectors ..93 oct. daily driven.
http://i156.photobuc...ct/DSC01364.jpg
#22 RonnieJ
RonnieJ
    Gchat ronni3jay@gmail.com
  • 1,853 posts
Posted 05 November 2013 - 12:03 AM
Sent my payment
#23 RonnieJ
RonnieJ
  • 1,853 posts
Posted 08 November 2013 - 12:09 PM
PIcs not showing up. So I need to create an account to see them? I see the broken img icon
#24 schaffman
schaffman
  • 182 posts
Posted 08 November 2013 - 07:03 PM
I am down for a set of poly as well. I am in need of some rear subframe bushings
20140704 144225 resized 2
#25 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 10 November 2013 - 11:06 AM
Yes that is why I said it is a good idea to make a login...LOL
Edited by Laodicea, 10 November 2013 - 11:07 AM.
#26 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 10 November 2013 - 11:08 AM
I will have some ready in the next few days.
#27 stariondreams
stariondreams
  • 420 posts
Posted 28 December 2013 - 07:04 PM
Are these still for sale?
#28 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 29 December 2013 - 11:15 AM
   Yes they are...I can make them anytime.
#29 screemin eagle
screemin eagle
  • 1,006 posts
Posted 02 January 2014 - 05:45 PM
Are these what cause my car to rear steer? I have the stedbani bushings but after the diff mounts fell apart I fear his products are sub par.
88 TSI 4g63
03 GMC Denali the tow truck
#30 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 02 January 2014 - 06:31 PM
I'm not sure about rear steer...someone else should answer that.  Too bad about them differential mounts.  I will tell you, I have made one pair of diff. mounts for a member on here with over 1000hp and he said he did six passes with them on the track and all seems fine with the mounts I made him.  I made them in a way that they cannot separate from each other unless they totally disintegrate.   They are not glued on so to speak like stock ones.
Edited by Laodicea, 02 January 2014 - 06:32 PM.
#31 sittin-sideways
sittin-sideways
  • 582 posts
  • Interests:drifting,hagging out,and spending time with my son and wife
Posted 03 January 2014 - 12:17 AM
that the price different for poly and the aluminum ?
#32 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 03 January 2014 - 02:04 PM
I still have not made any Aluminum ones because I don't think it is going to be possible.  The poly ones are very stiff and have to be pressed in tight...I cannot seem to be able to make aluminum ones press fit because the inside of the subframe where they go have two rises where the welds bled through from the other side.  This makes the subframe alittle out of round and trying to grind it down and then be consistent with everyone elses subframes will be a problem.   They will all be a little different and for me to try try to get it to be an almost press fit...not sure how to do it.
Edited by Laodicea, 04 January 2014 - 06:10 PM.
#33 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 03 January 2014 - 06:08 PM
The rear arm bushing usually cause that. Check for play in the long bolt that holds the lower arm to the hub.
#34 DMNDSTAR87
DMNDSTAR87
    THERMONUCLEAR WARRIOR
  • 1,373 posts
  • Interests:Handguns,Darts,
    Mopars and the NFL
Posted 22 February 2014 - 09:14 AM
Still available?
gig out
Posted Image  Posted Image
87 ESI-r--Ported/Polished Marnal Njv head,ARP studs,JE 040pistons,+1mm S/S valves,H/D valve springs,match ported intake to T/B and head,52mm ported T/B and inj mixer,850cc/1600cc injectors powered by Acceleronics Versafueler,Degreed 274h cam w/adjustable custom camgear,Spearco 3.5" intercooler w/custom  2.25" hardpipes,MSD 2222 RRFPR, HKS Turbo XS bov mounted in I/C pipe,MBC,H/V oil pump,Walbro F/P,HRC TD06 "super" 20G compressor mated with a TD05H 10cm T3 turbine,Gato T3 header,Innovative Lc-1 wdbnd,3"GM MAS w/MAF-T,AEM filter,MSD6AL ignition box,Bosch coil,BSE kit,lightened flywheel,TEP race clutch,Tep frontstrut bar,S/S hoses,A/C delete,ABS delete,EGR delete,Cruise delete,battery relocated to trunk,relay relocation,Whiteline bushings all around,MK1 adj. camber plates front/rear,ST lwr springs front/rear,ST swaybars front/rear,slotted rotors front and rear,s/s lines and bla bla bla--
#35 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 23 February 2014 - 10:10 PM
Yes I have the molds so I can make them when ever anyone wants them...
Edited by Laodicea, 24 February 2014 - 04:34 PM.
#36 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 31 October 2014 - 01:48 PM
Guys I have 5 pair available.
#37 screemin eagle
screemin eagle
  • 1,006 posts
Posted 08 November 2014 - 02:56 PM
Great product here guys! Buy them while he makes them.
88 TSI 4g63
#38 bryanstaz
bryanstaz
  • 74 posts
Posted 11 November 2017 - 02:03 PM
Hi are you still making these? I'm after a full set forward the rear of my Starion need the subframe bushes, and rear control arm bushes, please advise if you can help, Cheers
#39 bryanstaz
bryanstaz
  • 74 posts
Posted 11 November 2017 - 02:04 PM
#40 bryanstaz
bryanstaz
  • 74 posts
