86 starts then dies nightmare :)
86 tps boost sensor map sensor bad starts then dies dies
35 replies to this topic
#21 iGSR_VR
iGSR_VR
  • 212 posts
Posted 02 October 2013 - 07:48 PM
UPDATE****
I figured out my problem it was the injectors she is know screaming like beast Boosting 7 Pounds
All Original Conquest ( )
#22 importwarrior
  • 18,212 posts
Posted 02 October 2013 - 08:03 PM
what was the problem? clogged?
#23 87Jassic
87Jassic
  • 164 posts
Posted 08 October 2013 - 09:55 PM
were they clogged or was the resistor bad?
86 starion esi-r,hks 2.5 downpipe, hks highflow cat, hks cam, hks pfc-fcon, hks super sequential, hks turbo timer, megan racing muffler
85 conquest drift slut
89 mitsubishi mighty max stock... for now
91 mazda mx6, centerforce stage 2 racing clutch, 35 mpg
#24 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 50,164 posts
Posted 12 October 2013 - 03:11 PM
inj resistor was good I walked him thru testing that over the phn
88TSI Silver
89TSI red auto
#25 87Jassic
87Jassic
  • 164 posts
Posted 26 April 2014 - 09:42 PM
okay so after a busy year of all kinds of nonsense i am on the path to fixing my quest. will keep this thread alive if it will help anyone else.
#26 87Jassic
87Jassic
  • 164 posts
Posted 10 May 2014 - 11:58 PM
okay so i just worked on my quest and i took off my throttle body only to find that the two vacuum ports on the manifold were weled shut. the passages that i speak of are under the throttle body but on top of the intake manifold surface that mounts to the tb. what are these for and what happens if they are plugged??
#27 87Jassic
87Jassic
  • 164 posts
Posted 13 May 2014 - 01:46 AM
anybody????
#28 87Jassic
87Jassic
  • 164 posts
Posted 16 May 2014 - 08:37 PM
i still need help.
#29 mbruneaux
mbruneaux
  • 1,429 posts
Posted 17 September 2018 - 08:36 PM
Take a picture.....
I found this threat because I am having the same problem
Canterbury, CT
1998 BMW 528i 5 Speed because the Suburban gets 10 MPG
#30 sheepdog2142
sheepdog2142
  • 21 posts
Posted 10 February 2019 - 04:32 PM
I think I am having the same or a similar problem.
When I start the car unless I hold the throttle at 1500RPM or above for a good 5 minutes the car wants to die. Once it's warmed up it seems to run just fine. Any advice would be appreciated!
#31 pcristquester
pcristquester
  • 2,377 posts
Posted 10 February 2019 - 09:03 PM
CTS
#32 sheepdog2142
sheepdog2142
  • 21 posts
Posted 14 February 2019 - 12:16 AM
View Postpcristquester, on 10 February 2019 - 09:03 PM, said:
CTS
Excuse my Stupidity but I have no idea what CTS refers to.
#33 croquest87
  • 1,369 posts
Posted 14 February 2019 - 01:15 AM
Coolant temp sensor. One pointing straight up. It talks to the ecu so that the ECU knows how much fuel to send. There is a test you can perform on it w hot water and multimeter on cold water/coolant it should read around 2200 ohms and starts to drop slowly down to around 300 ish or so when water/coolant is at full temp around 185 deg or so. If it doesn't read right or wiring from it to the ecu is bad =issues.
It acts like choke to add extra fuel to start the car adding extra fuel.Unlike carburated engine that closes choke. It squirts extra fuel in to keep it running when needed and adds less fuel as car warms up. You need lots of fuel on startup when car is cold or slightly warm. If sensor is off on reading and not in proper range at certain temp your ecu is confused.
Edited by croquest87, 14 February 2019 - 01:30 AM.
#34 93 GSX TURBO
93 GSX TURBO
  • 465 posts
Posted 14 February 2019 - 11:07 AM
I had a similar issue and also thought it was a bad CTS.  Before swapping it out I decided to try a known working set of injectors from my dads 88 and car went back to running fine again, idle and all.  But I had same issue you are having where it wouldnt run correctly until it was warm.
Edited by 93 GSX TURBO, 14 February 2019 - 11:08 AM.
93 ECLIPSE GSX - S16G, VRSF FRONT MOUNT, APEXi TURBO BACK, RC750s, DSM  LINK V3, HKS 272s, CROWER VALVES-SPRINGS-RETAINERS, ARP'S, EIBACHS ON KYB'S,HALLMAN MBC
88 CONQUEST TSI - 5 SPEED SWAP, REBUILT 12A, TEP DOWNPIPE, 2.5'' TURBO BACK, PORTED TURBO MANIFOLD & EXHAUST HOUSING, GFB BOOST CONTROLLER
89 CONQUEST TSI SHP -5SPD, STOCK
2010 JETTA 2.5 - DD
2005 SEQUOIA SR5 -Family Mover
88 CONQUEST TSI- 5SPD, LEATHER, SUNROOF, STOCK ---  SOLD
89 CONQUEST TSI - 5SPD, STOCK --- SOLD
89 Conquest TSI SHP -White, 83k Miles, Tan-Black leather --- SOLD
88 CONQUEST TSI SHP - 5SPD, STOCK ---- SOLD
#35 freebird
freebird
  • 2,878 posts
  • Interests:time is of no moment, but only what your doing
Posted 14 February 2019 - 04:44 PM
put your finger on the end of the idle air control motor.
should be able to feel it running the end in or out.
if its not working till engine warm or closed loop then that would be a problem.
also 86 tbi dont have the idle adj. screw like the 87 and newer have. maybe something needed if you have changed the injector sizes.
ebay has a wet fuel pressure gauge for dsm eclipse....the kit comes with a banjo bolt.
if you take the top of your fuel filter banjo off this guage will bolt right on. i have a few and love them very handy. somewhere less than $50 is what i paid
even if your fuel pump has enough pressure to start the car it may not have enough to run drive. you can easily verify this by reving the engine and watching the pressure drop. pressure should stay at 35 even after reving into a little booost.
#36 sheepdog2142
sheepdog2142
  • 21 posts
Posted 15 February 2019 - 10:37 AM
Thx for the advice yall. Mine is an 87 so that might change things just a bit.
Also tagged with one or more of these keywords: 86, tps, boost sensor, map sensor, bad, starts then dies, dies
