Got Any MITSU Tips or Tricks To Share?
20 replies to this topic
#1 Starfighterpilot
Starfighterpilot
    Dirty Old Man
  • 4,368 posts
  • Interests:Keeping my Starion reliably scootin' down the road
Posted 12 September 2006 - 11:06 AM
All of us that have been wrenching the Starquest's for a while have some tricks that we use  :wink:  biggrin.gif  idea.gif  8)  O:) when removing/installing, disassembling/reassembling the Starquest's to make it easier or to prevent a screw up. :cuss:  ](*,)  :-({|=  #-o
88 Starion ESI-R SHP BSE/stock original owner 495K Miles
84 Starion ES RIP in 1987
66 Dodge Charger, Modified Original OEM 383/ 365 HP, 4-speed, Sure Grip, original owner, 113K HARD miles - Being Restored
76 Dodge PU, Modified 440/ 425 HP, 4 speed, Posi Dana 60 DIF, 675K Miles
#2 Maxzillian
Maxzillian
    Car Shaman
  • 2,650 posts
  • Interests:Autocrossing, atv riding, general tinkering, machining, a few other things.
Posted 12 September 2006 - 11:30 AM
*When removing the rear struts, I found that the strut is just a tick too long for it to slide all the way out from the rear hub carrier when the suspension is resting on it's own.
A simple piece of wood or a prybar wedged under the hub between it and the suspension arm with you foot on top of it does wonders for gaining that last inch of movement you need. biggrin.gif
*When installing cylinder heads, put the intake and exhaust manifolds on first. They're a royal pain to install once the head is in the car. :roll:
*If you do install an intake manifold after the head has been bolted to the block, remove the a/c pump and you'll gain a lot more room to reach those lower studs. (Helps if your system wasn't charged like mine was)
*When installing an engine, remove one bolt from the passenger's side engine mount and rotate it up. Then drop the engine in, stab the driver's side mount and secure it loosely with the nut. Then rotate the passenger's side mount into place to stab it.
*On manual transmission cars without an engine, a piece of baling wire can be used to hang the bellhousing from the line clip attached to the firewall that holds the a/c, abs, and other various lines in place. Now the car can be rolled around without a jack holding the transmission up.
What's the fun in making something simple?
'87 TSI - StarOrion braided brake lines, StarOrion radiator, StarOrion alternator, StarOrion 2.5" stainless exhaust w/Magnaflow muffler, 1G MAS, Competition Clutch 15 lb flywheel, Competition Clutch Stage 4 clutch, Mookeh polyurethane bushings, ABS elimination, 8:1 Wiseco Pistons, TD05 14G turbocharger, Axiss ceramic rear brake pages, Hawk HP+ front pads, heat wrapped and ported exhaust manifold/turbine housing, Accusump oil accumulator, remote oil filter, NJV head, EVO intercooler, remote battery, D2 coil over struts, flatty front struts and control arms, 8" non-SHP wheels all four corners, 12.75"x1.25" front rotors with 4 pot Wilwood calipers, manual brakes using dual master cylinders and balance bar, gutted (deleted) brake proportioning valve and modified steering pump speed sensitive valve.
#3 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 50,164 posts
Posted 12 September 2006 - 10:19 PM
i've always like'd Pennick000's advice
#1 undo battery cable
88TSI Silver
89TSI red auto
#4 burtons_wife
burtons_wife
  • 4,383 posts
  • Gender:Female
  • Interests:Cooking & Grilling
Posted 12 September 2006 - 10:31 PM
Where elbow length gloves when applying Por 15 to the insides of doors. #-o
#5 Truth
Truth
    Incredibly Sexy Member
  • 9,319 posts
  • Interests:Cars, Women, Music, Food
Posted 13 September 2006 - 07:23 AM
before you own a mitsubishi:
buy the service manual
buy a tool set
-A.J.
2004 Honda S2000
#6 indy_85stariones
indy_85stariones
  • 3,639 posts
  • Interests:Keep her running just one more day!
Posted 13 September 2006 - 09:53 AM
Using my car as an example...
Replace timing and balance shaft chains and guides -- ASAP.
#7 DJpowerHaus
DJpowerHaus
  • 2,393 posts
  • Interests:If that has a Spoon engine, mine's got a Shovel.
Posted 13 September 2006 - 10:21 AM
label all electric plugs that you unplug.. both male and female sides.
:: Project 0G ::
www.ProjectZeroG.com
#8 Shelby
Shelby
    Rookie
  • 50,164 posts
Posted 13 September 2006 - 10:32 AM
DJ that is realy a good piece of info  right there,, also  take pics,, draw pics make diagrams etc  , what ever you need to do to enable you to  come back  1 yr later and  put it  all togather , of course we don't  want to wait a yr,, but   just incase you had to do it
i do this all the time and i have done most of this crap  100 times befor
88TSI Silver
89TSI red auto
#9 JAinsworth
JAinsworth
  • 16,871 posts
Posted 13 September 2006 - 11:08 AM
When pulling the timing cover, draw a diagram on a piece of cardboard and stick the bolts in it accordingly when removing.
I use zip-lock sandwich bags, a marker and post-its.  As I a pull a part off, I label the post-it and put all the bolts for that part in a bag and zip it shut.
Both of these come in handy when you go to put stuff back together.
Stock the refrigerator with beer before hand..don't hit it heavy til the job is done :wink:
When you finish using a tool, put it back where it belongs, don't just lay it "somewhere".
Jimmy
#10 Mazarin
Mazarin
    Is so oldschool, he datalogs with an Apple IIe
  • 3,693 posts
Posted 13 September 2006 - 11:09 AM
REPLACE EVERY BOLT YOU TURN. EVERY ONE.
I did it on my Galant, and I'm doing it on my Quest. All I did was repaint some panels and heat sheilds, and I switched out every bolt. The ones on my Galant were litteraly made out of marshmallows and i couldn't tell you how many I had to drill out. So if you get a bolt out clean the first time, REPLACE IT!
P.S. And it makes the engine pretty!
First one: Red 88 - 245whp/312wtq - HIN: Nightshift - Chicago '07 WINNER
Second one: Durban 88 - Buckskin - SHP - Auto - Sold to to capable hands
Third one: White 84 Flatty - T3/T4 - GM MAS/MAFt - VELNAS - Sold to local capable hands
"...Remember: Don't crush 'em, restore 'em!"
#11 Kougar
Kougar
  • 1,041 posts
Posted 13 September 2006 - 12:22 PM
Don't go into the garage to wrench unless you're dressed to do so.  I don't know how many times I was wearing nice clothes, went into the garage to look at something, then ended up wrenching a bit and staining my clothes  :roll:
#12 73Charger
73Charger
  • 313 posts
Posted 13 September 2006 - 12:38 PM
kouger i just go around places in my town and i do that cause every bodys house i stop at goes face and we break alot so i dirty all my cloths
Tip
If there is something wrong with your car dont replace random things you end up with a bigger problem
'89 Conquest broken.
'86 Fatty stock and going :)
#13 MainstreaM
MainstreaM
    Tech Spec LCO
  • 4,746 posts
  • Interests:Splittin' atoms
Posted 13 September 2006 - 12:50 PM
CLEAN YOUR TOOLS
Clean tools are happy tools,
and
Happy tools work better.
Kane
#14 JAinsworth
JAinsworth
  • 16,871 posts
Posted 13 September 2006 - 01:13 PM
QUOTE (73Charger)
Huh??????
#15 73Charger
73Charger
  • 313 posts
Posted 13 September 2006 - 01:16 PM
haha that was suppose to say go fast and we break our cars alot due to we drive them like we stole them and we break s*** alot so every one of my friends house i stop at atleast one of them is wrenching and i cant let just one man wrench i have to help
#16 Starquest86
Starquest86
  • 617 posts
  • Interests:Mitsubishi's, Honda's, Subaru's, and any Japanese bikes, Family, Painting(automotive), Music..
Posted 13 September 2006 - 01:24 PM
Im going to have to go with dito on putting tools back when your done using them. When i did the head replacement on my laser i dont even know if i can count on fingers and toes how many sockets and screwdrivers i lost.
Also unless your rich a good rule is "if it aint broken it doesnt need fixin"
Dont smoke dope when you work on your car it makes it real hard to remeber where you put stuff. (clean for 8 months)
1986 Dodge Conquest LO5 (sold) Trying to reacquire
1987 Chrysler Conquest X15 (sold) Trying to reacquire
1995 Honda Civic Dx (dd)
1994 Honda Del Sol Si (Project)
1999 Subaru Legacy L Wagon (my car, lady dd)
1999 Toyota Camry (For Sale)
2009 Crf 230M (80mpg)
1983 Suzuki Fa50 (83 mp half gallon)
Turbo For Life
God created turbo lag to give V8's a chance.
"If life throws you a curve, pop the clutch and drift it."
#17 73Charger
73Charger
  • 313 posts
Posted 13 September 2006 - 01:27 PM
i Smoke pot but never work on cars high im always worried while high ill mess something up and dont care to take the chance. Only time ill do it is if im at the 1/2 mile and im driveing my own car ill be high and had to put a new drive shaft in her to get her home haha good night
#18 Burton
Burton
    Addicted Starquester
  • 11,811 posts
  • Interests:Hold up wait a minute let me put some pimpin in it
Posted 13 September 2006 - 05:00 PM
QUOTE (Starquest86)
  I hear that. I'm always putting my tools someplace that at the time I will think is the perfect place for it, but later can't find it. I'm bad about not putting tools back, but have a very good organization for when I do. Every tool has its place, my sockets are organized in my drawers- I used sheets of plywood, then got 1/4, 3/8, and 1/2" wood dowels, drills of the same sizes and some wood glue. Now I have a socket rack where you can label which socket is what so you can grab the right size without looking at the socket. All the tools that hang on the walls have a special hanging place and then I traced around every tool, so if something's not there I know what tool it was. I go through a cycle tho....
   I have about three of everything as far as basic tools go, so I usually do a project, dirty the garage and throw tools everywhere. Then another project gets worked on and everything gets worse. Eventually I will need a socket or wrench and I can't find any of the 3, and that is when I pull the cars out and spend half a day cleaning and finding everything, only to start the whole process as soon as I'm done. You'd think I'd learn  :roll:
QUOTE
   Congrats on your sobriety. I don't ever plan to stop, but I admire you as I can imagine it would be a hard thing. Anyway, I won't smoke dope whenever I do any mechanical or serious electrical work, but when I'm doing audio and bodywork/paint stuff I will. I've found it helps with my ability to feel the bodywork as I'm sanding, and also works wonders when I'm doing "creative" stuff like custom bodywork/audio stuff. Deffinately helps with the "vision" of a car- Its when I get some of my best design ideas.
   My SQ tips- I'll start in the front and work my way back....
When removing the front bumper from the car, remove the grille and header panel. Then undo the airdam to fender bolts. Once those are off, there are only 4 main bolts to worry about to get the bumper off. 3 of them are easy to get at but one, not so much. Luckily the bad one to get is the rear passenger side bolt, and both rear bolts only have to be loosened. The front two bolts need to be removed all the way and then the whole asembly will slide out. The rear passenger side bolt is kinda hard to get at with all the IC pipes going thru that area, but if you have a swivel and/or knucle socket extension, its a piece of cake- especially since you just have to loosen it a few turns. For those just looking to swap out an airdam, its best to follow this too as the airdam is easier to remove when the bumper is off the car.
   The outside door handles were a pain for me to remove the first time I did it- even broke one of them. The problem was that I could get the nuts off, but couldn't get the handle rod clip undone so I couldn't get the rod out. I have since heard of somone else who had the same problem when they went to sell the handles out of a parts car- they couldn't get them unhooked either so they took a set of air shears to get them out and ruined a perfectly good door. Anyway, after fussing and fighting with it I realized there is an access hole just for this purpose. Its an oblong looking hole/slot thing in the inner door frame pretty much right behind the key cylinder- this hole is often covered with silvery metal foil tape. Once you find that hole you get a fairly large flated screwdriver and you will have the proper angle to use the tip of the screwdriver to pop off the clip. Once the clip is off you can use the same screwdriver to kinda pry the rod where it hooks to the handle to pop it off. The location of the access hole gives you the perfect leverage.
   If you have to remove the majority of the rear axles/suspension/diff., its way quicker to drop the whole assembly, but be advised that it is not easier to put in that way. You'll have to plan on putting it together one piece at a time.
    Rear bumper- This one's pretty easy, but I've heard some people get stuck. There are two bolts in the trunk pan going down into it- one on each side- those are the easy ones. There are also two that screw up from the bottom, but those are also like the rear bolts of the front bumper in that they only have to be loosened.
I guess that is all for now.
Mark
88 Starion
87 TSI Custom (wife's)
85.5 Starion
98 Mercedes-Benz S420
11 Kia Surento(wife's)
93 Nissan 300ZX 'Vert
http://www.26liter.us/
21 chapter online Body/Paint/Detailing manual
Best SQ virtual GARAGE on the net
Stuff to make your SQ look cool!
Burtonscustoms.com
#19 Starquest86
Starquest86
  • 617 posts
Posted 13 September 2006 - 05:12 PM
Well my sobriety is because my gf was like you choose me or dope. At the time the girl seemed smarter and now im sure i should have chose dope. It would have been cheaper then she is lol.  Im sure when she passes i will start again cause i planned on never stoppin (plus i still have all the parifinalia{sp}).
Also at school we organize the sockets on the rails. I used to just throw sockets everywhere but now i find it better to know exactly where it is rather than searching through 100's of socket.
Check and see if bolts are torque to yield bolts. Its kinda a pain when you are trying to torque head bolts and they just wont tighten all the way.
If your car is hybernating or sitting for whatever reason (for a period of time) TAKE THE E BRAKE OFF. Itll help when you decide to move it or drive it again.
Turbo For Life
#20 UlrichWolf
UlrichWolf
    Mayhem....it's WHAT I DO
  • 7,087 posts
Posted 13 September 2006 - 05:24 PM
I'll say it because it can't be said enough.....
Clean all of your fusible links, and grounds at least once a year.  So many electrical gremlins are exorcised by this alone.  Make sure to not forget the ground at the ECU.
Always use a Mitsubishi exhaust gasket, the slice-your-a** three layer metal job.  While we're talking exhaust, replace the nuts every time you have to take it off.  Those copper nuts are actually one time use.
When changing the framerail fuel filter, it's much easier to remove the fuel lines at the injection mixer, and at the junction just at the firewall, and pull the filter and hoses as an assembly.  Just pay attention to how it goes when you reassemble it.
For '88-'89 model cars, restore the gloss to your A/C control panel by cleaning with NON-CHLORINATED brake cleaner.
I have found that changing thermostats every 3rd or 4th oil change is a wise move.  Seems like they become compromised fairly quick.
Use only dealership PCV Valves, and oil filters.
Tim
Oh what a tangled web we weave, when first we practice to deceive.
