mrvwbug Posted May 25, 2013 Report Share Posted May 25, 2013 I think my clutch is going. It's starting to spin in forth gear but just on and off only on the highway at high speeds. It does not do it in any other gear. I thought also about turbo lag. I was thinking about doing the maintenance on the rear differential and change the gearbox oil as well. This is not my area of expertise in diagnosing. I read when your clutch start to go it starts in the highest gears first? Does anyone have any other ideas or thoughts? Please let me know. Thanks Slim Jim Link to comment Share on other sites More sharing options...
Speedy2222 Posted May 25, 2013 Report Share Posted May 25, 2013 pull your inspection cover and see if there's oil on the flywheel, also i am local to you and could give you a hand if you need it. i'm free all weekend. Link to comment Share on other sites More sharing options...
vbrad511 Posted May 25, 2013 Report Share Posted May 25, 2013 When the disc starts to wear, or the pressure plate starts to get weak you'll notice it in the higher gears first. If you notice it in fifth now, you may soon notice it in fourth as things get weaker. Link to comment Share on other sites More sharing options...
