Replace the oil pressure sender without draining oil??
5 replies to this topic
#1 kepico
kepico
  • 40 posts
Posted 21 July 2019 - 02:55 PM
Most recent oil change I went to replace the oil sender but it wouldn't budge so I'll need a different tool, thinking open end crow foot (my standard open ends were too long to fit in there)
I went ahead and did the rest of the oil change anyway as I have since decided to order an OEM sender instead of the aftermarket one I got + I'll need to find a suitable tool to remove.
So question is can I replace the oil pressure sender without draining the new oil? Seems like it might pour out as it sits in the oil filter housing?
Edited by kepico, 21 July 2019 - 02:56 PM.
#2 croquest87
  • 1,744 posts
Posted 21 July 2019 - 03:20 PM
Sure thing. Just hurry up and screw it back in quick to stop the leak.lol
You are going to spill some but minimal amount if you are quick. O yeah  make sure you do it  while engine/oil is cold.
#3 TexasQuest
  • 9,079 posts
Posted 21 July 2019 - 06:35 PM
They are a booger to get off. I didn't know oem oil pressure senders were still available? Part number?
88 Fiji Blue -TSi
#4 techboy
techboy
  • 3,517 posts
Posted 21 July 2019 - 09:55 PM
It won't leak that much out. I've done this before. I would recommend having an aftermarket oil pressure sender installed somewhere though. The oem unit is not very accurate and doesnt really give you a pressure value. An aftermarket one will be much more accurate.
#5 kepico
kepico
  • 40 posts
Posted 22 July 2019 - 01:59 PM
Texasquest; the OEM P\N is MD092660 - when I ordered it said "in stock" so I hope it is still available.
Techboy; when I meant aftermarket I meant a parts store oil pressure sender (instead of OEM) - apparently per searches on this forum some of the parts store versions fail quickly.
Thanks all for the replies, just wasn't sure if I had to drain it all again to do this.
#6 techboy
techboy
  • 3,517 posts
Posted 22 July 2019 - 10:27 PM
I understood what you meant, I was just making the suggestion of adding an actual aftermarket guage if you don't have one already b/c the stock gauge is not very accurate and doesnt give you a value. A simple Autometer gauge will tell you 60psi at a glance.
Edited by techboy, 22 July 2019 - 10:27 PM.
