G54B Transmissions that wont need bodywork
14 replies to this topic
#1 eclipse
eclipse
  • 20 posts
Posted 08 October 2015 - 05:19 AM
Hi
I have searched for answer, but haven't found correct one for starion transmission swap.
Car has about 500hp at the moment, plan is to crank it up to 800hp. That is from the engine.
I managed to broke my original fully restored gearbox yesterday.
There ain't much starions in baltic, so cutting body isnt an option.
Is there any stronger gearboxes that will fit without cutting? Many other cars use bmw 530d 6 speed manual from e39 body.
I also had that plan, to cut off both gearbox bellhousing and weld starion housing to bmw gearbox.
Looking forward for new suggestions.
#2 freebird
freebird
  • 2,852 posts
  • Interests:time is of no moment, but only what your doing
Posted 08 October 2015 - 05:59 AM
your g54b will make 800 hp :ph34r:
#3 GINASQ
GINASQ
  • 942 posts
Posted 08 October 2015 - 10:46 AM
Maybe the 420G 6spd from the e39 m5, e46 m3, etc. Very strong transmission. I don't know how big it is though. They can usually be had for $700 to $1000.
Edited by GINASQ, 08 October 2015 - 11:02 AM.
-James
#4 aknorthstar
aknorthstar
    FarNorth Member
  • 1,400 posts
Posted 08 October 2015 - 12:34 PM
My buddy has a w58 Toyota Supra Trans on his 88 4G63 quest
Edited by aknorthstar, 10 October 2015 - 09:39 AM.
#5 GINASQ
GINASQ
  • 942 posts
Posted 08 October 2015 - 03:31 PM
Which?
There's the w58, r154, and v160. I know the r154 and v160 wont fit without working the tunnel and the w58 will not take that power.
-James
#6 psu_Crash
psu_Crash
  • 7,067 posts
Posted 08 October 2015 - 06:42 PM
T56 is a good swap and you can build them to take whatever you throw at them. Adapting it to the stock block is the fun part. IIRC Bill Hincher has a bell housing for that but I can't be sure.
P.S. We would all love to see some dyno sheets from that monster. 800HP is a very tall order
Edited by psu_Crash, 08 October 2015 - 06:52 PM.
My Feedback Link
#7 mstieg
mstieg
  • 6,172 posts
Posted 10 October 2015 - 04:16 AM
Bill's is for the LS1 trans, not the LT1.  His also uses the stock flywheel and clutch.  No way to hold that kind of HP unless double or triple disk clutch.  Bill has another bell to fit the 4G63.
I never got interest to make it worth reproducing my 1 off adapter for the 6 speed LT1.  Installed and will be running soon w/ T56 clutch on T56 Fidanza fly and stock master & slave adapted to LT1 pull style clutch.  Looks like there is still a T56 fly or 2 avail from earlier limited runs:  http://www.ebay.com/...d82251a&vxp=mtr
In Progress: breakin & tune
#8 aknorthstar
aknorthstar
    FarNorth Member
  • 1,400 posts
Posted 10 October 2015 - 09:40 AM
Im sure everyone wants to see the dyno sheet!
#9 eclipse
eclipse
  • 20 posts
Posted 14 October 2015 - 04:50 AM
And i think that everyone can understand it wont happen without working gearbox.
Has anyone fitted bmw gearbox by welding starion bellhousing to it?
6 speed seems to be too long. At the moment there is one 900nm e34 550 that is using 3.0d 5 speed gearbox and seems to be holding fine.
I will get that old gearbox out next month and then i can take measurements.
#10 eclipse
eclipse
  • 20 posts
Posted 15 September 2017 - 05:37 AM
I installed bmw 5 speed diesel gearbox.
Problem is that final ratio is too high. Max speed is about 210kmh.
What options there are for rear diff ratio?
Edited by eclipse, 15 September 2017 - 06:43 AM.
#11 jinx
jinx
  • 1,873 posts
Posted 15 September 2017 - 11:48 AM
one would think that you would have crunched rpm/mph numbers before going thru all the trouble of adapting a bmw 5spd
can't recall seeing anything numerically lower than the 3.54 stock ratio. Old sapparo 3.31 ?
may need; a third member swap + fab mounting + driveshaft + custom axles if u wanna a retain that bmw box....8.8, bmw, etc..
88 nissan 300zxt(sohc V6) full street car gone low 9s, no spray on factory diff and 5spd
dunno what kinda power it takes to pull that off, but must be up there
show some motor pics and specs
#12 scott87star
scott87star
  • 4,959 posts
Posted 15 September 2017 - 05:13 PM
Gear Vendors overdrive.
#13 Turbo Cary
Turbo Cary
  • 1,583 posts
Posted 16 September 2017 - 09:07 AM
The Z31 and Z32 N/A share the same transmissions. However the Z31 turbo uses a Borg Warner T5 I believe. I would use an NA trans as they are stronger and easy to come by.
#14 jinx
jinx
  • 1,873 posts
Posted 16 September 2017 - 10:55 PM
last couple years of the z31 turbos used the same 5spd as the turbo z32 (rb25 too).
a stout smooth shifting strong box
low 9sec z31 mentioned was 88. Early turbo z31 got the T5
#15 Funky Phil
Funky Phil
    Super Pooper
  • 6,423 posts
Posted 18 September 2017 - 09:05 AM
