Finally got this turd to idle a bit
7 replies to this topic
#1 tux
tux
  • 1,790 posts
Posted 01 May 2020 - 02:13 PM
https://imgur.com/j1nKEgq
Had issues getting timing setup w/ the AEM EPM as you have no way to know where it's pointing.  AEM recommended a finger over the Cyl1 spark plug hole and watching spark to try and get it close.
I found it was easier to manually spin the engine with a wrench and have someone watch for the cam tooth count to increase.  Once I knew the whereabouts of the the cam I was able to set it in the AEM software and try starting with starter fluid.  Didn't start so I was on the wrong stroke.  Adjusted by 12 teeth (for the aem puck) and was able to start on starter fluid.  Then turn on injectors, get someone to try and keep the car idling with gas pedal and sync the timing.
I've got some things to do while she's in the air so she stops at this point until I can bring her outside and not die from exhaust fumes :)
list of mods for the MPI part
AEM EMS-4 ECU
AEM EPM using a broken Magna Distributor to drive it
AEM Wideband
AEM FPR
AEM 5 BAR MAP (will decrease to something smaller)
Bosch044 Pump
Dodge Neon SRT4 Stage 2 Injectors
LQ9 Chevy Coil Packs
GM AIT
GM CTS
Ford TB
Ford TPS
Trilogy Fuel Rail (need to grind it to clear the rearmost vacuum port on the manifold)
#2 TexasQuest
  • 9,236 posts
Posted 01 May 2020 - 08:01 PM
Awesome. Post some pics of your setup B)
88 Fiji Blue -TSi
#3 tux
tux
  • 1,790 posts
Posted 02 May 2020 - 01:51 PM
It's a horrid mess right now.
I need to find a way to mount my lq9/d585 coils to valve cover, finish some wiring and get the exhaust connected.  Once done I will
#4 psu_Crash
psu_Crash
  • 7,497 posts
Posted 03 May 2020 - 10:20 AM
I like the disaster pics too! We've all been there :)
The Valencia Project
My Feedback Link
#5 tux
tux
  • 1,790 posts
Posted 04 May 2020 - 01:54 PM
Craftsman fender protector to hold my coil packs
Under the fender protector
and until I finish running wire to the trunk and get a battery that fits nice back there, I have this disaster providing power
#6 tux
tux
  • 1,790 posts
Posted 09 May 2020 - 11:30 AM
Valve cover modified for coil pack mounts
Turbo out due to broken wastegate bolts and a bent an fitting (swivel seized). Only summit fitting, I don't recommend it lol
#7 tux
tux
  • 1,790 posts
Posted 24 June 2020 - 08:22 PM
Got idle dialed in better.  Mostly all back together.
I'll have to plumb the IAC into the intake piping at some point, for now I have just a filter... I think that's ok for now.
Noticed no oil pressure on factory and autometer gauge, but I think that's because the autometer sender grounds through the body, which is screwed into an anodized fitting.  So I'll try and ground it another way.  Factory sender is original from 1987, so that one is probably dead and why the factory gauge doesn't work.
#8 tux
tux
  • 1,790 posts
Posted 24 June 2020 - 08:28 PM
