Maft help
28 replies to this topic
#21 aruggs15
aruggs15
  • 75 posts
Posted 09 August 2019 - 06:05 PM
Coolant temp sensor reads 260 ohms when the engine is fully warmed up forgot to test it when it was cold will do that later when it cools down
#22 aruggs15
aruggs15
  • 75 posts
Posted 09 August 2019 - 06:36 PM
And also are the fans switched from a different sensor than the one for the ecm ?
#23 TexasQuest
  • 9,059 posts
Posted 09 August 2019 - 09:42 PM
Yes they use thermo sensors at the bottom of the radiator. When they ground, the fans activate.
88 Fiji Blue -TSi
#24 aruggs15
aruggs15
  • 75 posts
Posted 14 August 2019 - 08:34 PM
So I tested pretty much every sensor theyíre all within specification from the service manual. I played with the timing and the translator to try and tune. No such luck with anything same problem. I also did a tps isc reset did not help. I also changed the maf with a brand new one. I donít understand why the green light on the maft is on in ďdimĒ mode when itís at an idle is this normal ?
#25 TexasQuest
  • 9,059 posts
Posted 17 August 2019 - 02:51 PM
Do you have the instructions for the maf-t? It will tell you if the green light is normal.
88 Fiji Blue -TSi
#26 aruggs15
aruggs15
  • 75 posts
Posted 21 August 2019 - 07:44 PM
I found out that the green light is normal at an idle
#27 aruggs15
aruggs15
  • 75 posts
Posted 30 August 2019 - 06:58 PM
So I found that in order to adjust my tps I had to sort of force it apparently without knowing I was do so, so when you crack the throttle the tps goes back down to like .25 to .3 volts. Iím assuming the throttle position sensor is bad since I just adjusted the isc. So basically I canít get my tps to stay at .5 volts and repeat this after opening the throttle blade.
#28 techboy
techboy
  • 3,487 posts
Posted 30 August 2019 - 07:55 PM
You might want to consider upgrading to a Mazda TPS.
#29 aruggs15
aruggs15
  • 75 posts
Posted 30 August 2019 - 08:42 PM
where can I get one ?
