New update for October. Been working on a few things for this. I grabbed an extra intake manifold to remove the VTCS plates and port/polish. I bought an oil filter conversion kit, front lip, skid plate, and a proper EGR delete kit. I also got a bumper fix kit because they corners near the headlamps dont stay pushed into the plastic retainer.
This past Saturday I installed the oil filter conversion. The 2010 and up model's came with a spin on filter instead of the horrible canister filter that the older models had. Total time changing it was about 20 minutes including changing the oil. I had been having a leak which I thought may have been the rear main, but there was oil around the filter mounting so I wasnt sure. The canisters tend to leak. It could have been my oil sender but I put a new one on just in case.
Old canister housing (the oil is from taking it off)
New filter housing installed and the underside of the engine cleaned off
I really need to get back to working on my Miata but it is in the yard which is soaked from rain. I may have found a built motor to buy so hopefully I won't have to pull the other one and then build that. I'll just have one to drop right in.
I should be getting the front lip painted today at work. Once I get that I'll be able to mount it to the bumper and install the fix kit. I wanted to install the skid plate but whoever had the car before me cut the mounting area off the side water shields. Guess I'll order those too.
