GLHS Posted October 28, 2012 Report Share Posted October 28, 2012 wonder if you guys could tell me will a 14b bolt to a stock exhaust housing. Link to comment Share on other sites More sharing options...
conquestador89 Posted October 28, 2012 Report Share Posted October 28, 2012 i think you have to machine the hotside of the turbo...its $75 from forced performance...was gonna do it but i put that project on the back burner since my turbo hasn't crapped out yet Link to comment Share on other sites More sharing options...
GLHS Posted October 28, 2012 Author Report Share Posted October 28, 2012 Thought that was for the 14g?way i am asking thanks for any help Link to comment Share on other sites More sharing options...
ucw458 Posted October 28, 2012 Report Share Posted October 28, 2012 It should as long as it has a TD05 turbine. The 14b was a factory upgrade turbo. Link to comment Share on other sites More sharing options...
GLHS Posted October 28, 2012 Author Report Share Posted October 28, 2012 (edited) Thank you,thats what i thought i had read on another site,just needed a pro to confirm.no offense to any one and thanks for all the help Edited October 28, 2012 by GLHS Link to comment Share on other sites More sharing options...
Skullzaflare Posted October 28, 2012 Report Share Posted October 28, 2012 It should as long as it has a TD05 turbine. The 14b was a factory upgrade turbo.14g was the factory upgrade turbo, 14b is the factory eclipse turboboth can come in td05 and 05h, if the 14b is off an eclipse its a td05h Link to comment Share on other sites More sharing options...
spadey Posted October 28, 2012 Report Share Posted October 28, 2012 14g bolts up. You have to run a different exhaust flange on the down pipe. And I made a pipe coming off the turbo so I could bolt it right up to factory piping. I had a little under that $100 including the turbo to get it running on the car. Link to comment Share on other sites More sharing options...
Skullzaflare Posted October 28, 2012 Report Share Posted October 28, 2012 14g bolts up. You have to run a different exhaust flange on the down pipe. And I made a pipe coming off the turbo so I could bolt it right up to factory piping. I had a little under that $100 including the turbo to get it running on the car.your talking about bolts up to the manifold, of course anything t25 will, you can make t28 fit as well.we are talking out pulling the v-band, and sliding in the 14b/g cartridge, in which case the hotside needs milled out Link to comment Share on other sites More sharing options...
spadey Posted October 29, 2012 Report Share Posted October 29, 2012 O yea sorry miss understud I thought he ment manifold side. Link to comment Share on other sites More sharing options...
GLHS Posted October 29, 2012 Author Report Share Posted October 29, 2012 K so my 14b will slide in the stock conquest hot side our do i have to get it machinened.got my a little confused. Link to comment Share on other sites More sharing options...
movin on Posted October 29, 2012 Report Share Posted October 29, 2012 No, a 14b is a td05H (exhaust wheel) and is bigger than the stock td05. Both the 14g and 14b will need to have the exhaust side machined. Link to comment Share on other sites More sharing options...
traps Posted October 29, 2012 Report Share Posted October 29, 2012 Hmmm I thought my 14B was my 12a hot side with 12a cartridge and 12a shaft hot wheel with the eclipse cold side with cold wheel and welded on tabs for accuator? Had my 14B made for me from a different forum moderator Link to comment Share on other sites More sharing options...
Skullzaflare Posted October 29, 2012 Report Share Posted October 29, 2012 Hmmm I thought my 14B was my 12a hot side with 12a cartridge and 12a shaft hot wheel with the eclipse cold side with cold wheel and welded on tabs for accuator? Had my 14B made for me from a different forum moderatori didnt understand your post, however, you can put a 12a td05 shaft in a 14b td05h, converting it to a td05 Link to comment Share on other sites More sharing options...
traps Posted October 29, 2012 Report Share Posted October 29, 2012 thats the turbo on the right. I believe Skull you explained it better than I. This built turbo fit stock mani perfect. Link to comment Share on other sites More sharing options...
GLHS Posted October 29, 2012 Author Report Share Posted October 29, 2012 K so i used my exhaust Wheel in the 14b and keep my hot side.mow how do i hpok up the wasetgate Link to comment Share on other sites More sharing options...
Skullzaflare Posted October 29, 2012 Report Share Posted October 29, 2012 K so i used my exhaust Wheel in the 14b and keep my hot side.mow how do i hpok up the wasetgateyou have to make a bracket, or have the 12a cold side housing milled for the 14b wheel to use stock bracket Link to comment Share on other sites More sharing options...
GLHS Posted October 29, 2012 Author Report Share Posted October 29, 2012 Would any one have pics of said maid bracket Link to comment Share on other sites More sharing options...
conquestador89 Posted October 30, 2012 Report Share Posted October 30, 2012 cool...think a bracket would be easier...always thought you had to make tabs,thread them and weld them on the compressor housing... Link to comment Share on other sites More sharing options...
traps Posted October 30, 2012 Report Share Posted October 30, 2012 Would any one have pics of said maid bracketYou can barely see it on that pic I have but ley me find anotherWould any one have pics of said maid bracket When I hit the house for lunch I will taker a pic Link to comment Share on other sites More sharing options...
GLHS Posted October 30, 2012 Author Report Share Posted October 30, 2012 Thanks will be waiting lol,this is the only part keeping the quest from the street Link to comment Share on other sites More sharing options...
Skullzaflare Posted October 30, 2012 Report Share Posted October 30, 2012 You can barely see it on that pic I have but ley me find another When I hit the house for lunch I will taker a picyour compressor housing has tabs, so pics wont help them. they need to made a bracket 1 Link to comment Share on other sites More sharing options...
hippynerd Posted October 30, 2012 Report Share Posted October 30, 2012 Here are a couple pictures of how I did it. the housing on the right is stock 12a intercooled clocked housing, and on the left is the newer style housing (like you find on eclipe/evo.)Below, on the left is the old style, right is my modded new style. Link to comment Share on other sites More sharing options...
hippynerd Posted October 30, 2012 Report Share Posted October 30, 2012 BTW, I got these parts from skullz The turbo on the right is actually a modded 14b (with td05 wheel, it came with a tdo5h). I do have a 16G that Im saving for my red/white car, I could sell it, its freshly rebuilt, but I dont really want to sell it. Link to comment Share on other sites More sharing options...
GLHS Posted October 30, 2012 Author Report Share Posted October 30, 2012 I think that's my problem I need to get the matching waste gate I'm trying to still use the stock one on the 14b, thanks so much for taken the time to get the pics. Link to comment Share on other sites More sharing options...
hippynerd Posted October 30, 2012 Report Share Posted October 30, 2012 You are welcome buddy. Thanks to skulls throwing in a couple extras, i was able to cobble this together, which has worked great, but doesnt look stock. Link to comment Share on other sites More sharing options...
