G54B MPI EFR 7670 with T-56 Magnum build (w/ megasquirt)
49 replies to this topic
#21 damannm
damannm
  • 62 posts
Posted 14 April 2017 - 10:50 PM
So I got a 24"X12"x1/4" sheet of acrylic and cut its shape to the instrument cluster. I have it marked up (not in this picture) for the holes for the connectors and mount holes.
#22 damannm
damannm
  • 62 posts
Posted 15 April 2017 - 10:23 PM
Got the stock ECU harness out today (in one piece). As well I pulled the fan relays as I will be installing a different setup. I also got the harness ready for the battery​ relocation and the installation of the bus bars.
The MS2 harness pulled through the firewall.
Relays removed. New steering gear installed and new brake booster. I have a new master cylinder too. As well we got the front steel braided lines in.
The old harness coming out.
#23 damannm
damannm
  • 62 posts
Posted 15 April 2017 - 10:24 PM
Oh and on a side note, Bill texted me that everything is done. So next week the trans should be going in.!
#24 GINASQ
GINASQ
  • 942 posts
Posted 16 April 2017 - 01:06 PM
Please provide as much detail as possible when putting this in.
-James
#25 damannm
damannm
  • 62 posts
Posted 16 April 2017 - 06:25 PM
I intend to.
#26 damannm
damannm
  • 62 posts
Posted 17 April 2017 - 09:40 PM
So dash is pretty much ready to mount! Just need to get the holes ready for the turn signals, high beam, alternator light, and fuel low switch light.
#27 damannm
damannm
  • 62 posts
Posted 27 April 2017 - 09:05 PM
Bellhousing arrives tomorrow. More to come after Sunday.
#28 Blackmount
Blackmount
  • 78 posts
Posted 01 May 2017 - 12:27 PM
Cool stuffl
#29 damannm
damannm
  • 62 posts
Posted 02 May 2017 - 04:28 AM
Ran out of time. I was working the car the whole day Sunday. We put the trans up 4 different times marking out where it hit. So far we have more sheetmetal to move in a few places. It looks good for it not needing to be cut to fit. I'll post some pictures after I get to work today.
#30 damannm
damannm
  • 62 posts
Posted 02 May 2017 - 09:18 PM
https://imgur.com/a/nDyRM
So here are some pictures. Bills motor mounts moved my motor forward about an inch.
The area on the passenger side front of the tunnel required some massaging of about an inch and a half in (this is soft sheetmetal so easy) to accommodate room for the sensor and tabs.  (Looks like 3 fingers sticking off the side).
The area between the stock trans mount is equal to where the tailhousing mounts to the body of the transmission. The area needs to be taken out on both sides. It's pretty stout but it can move about an inch in. This needs to be done on both sides the entire height of the tunnel.
Given that I have a T-56 mag trans also anyone who is getting a TR-6060 will have to raise the top of the tunnel as well. I ran out of time and do not know exactly how much yet. So far no cutting is required.
My transmission has extra tabs that the TR-6060 and LT1 T-56 do not have. I will need to get the useless tabs taken off.
The shifter lines up to exactly 2.5 inches behind the front of the opening.
#31 GINASQ
GINASQ
  • 942 posts
Posted 04 May 2017 - 02:30 AM
Thanks for the pics. I might go this route if I break my transmission.
-James
#32 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
  • Interests:Lots of boost!
Posted 26 May 2017 - 03:29 PM
I have broken a few transmissions. It's not fun. I would have liked to go this route, and if I ever get another SQ, I would. Probably first mod.
#33 damannm
damannm
  • 62 posts
Posted 29 May 2017 - 02:23 AM
Just a heads up I will not have any updates till the beginning of September. I am out of the country for work till the end of August.
#34 damannm
damannm
  • 62 posts
Posted 02 April 2018 - 08:13 PM
Alright folks I know I went off the radar. Work sidelined this project for a while. The car is being moved tomorrow to a shop to get a few brackets, exhaust and down pipe, and intercooler piping made. Iíll grt some pictures up of the turbo and intake mounted. I hope to be finished in the next month or so since I have time again.
#35 autotr8er2
autotr8er2
    Out of my Cotton Pickin' Mind
  • 993 posts
Posted 10 May 2018 - 07:51 PM
Joe and I were just talking about this build
#36 damannm
damannm
  • 62 posts
Posted 13 May 2018 - 05:11 PM
So I have a fun update for you all. I got my new wiring in (replaced those pesky fuseable links) and added a bus bar (500a). Battery had been relocated to the back with 1 gauge wiring. The second box is additional relays that are to run the fans, coil packs, O2 controller, and an extra for a boost controller later. The first picture is the AIM MXS Strada powered up.
https://imgur.com/a/GCUl7GU
I will be reassembling the car now. So expect some more updates next week.
Edited by damannm, 13 May 2018 - 07:40 PM.
#37 importwarrior
  • 18,295 posts
Posted 13 May 2018 - 05:55 PM
Awesome. Canít wait for the pics.
#38 damannm
damannm
  • 62 posts
Posted 19 May 2018 - 08:38 PM
So today was focused on finishing up wiring getting the ECU and dash wires cleaned up. Next week the engine is going back together!
The LED lights on the left are for turn signal, charging light, high beams, ebrake, and the check engine light is the low level switch in the gas tank.
I believe the engine bay is self explanatory.
#39 tsi_tom
tsi_tom
  • 2,284 posts
Posted 19 May 2018 - 09:11 PM
Looking good bro!
Engine
20 over forged pistons
Stock injection system
#40 importwarrior
  • 18,295 posts
Posted 20 May 2018 - 02:17 PM
Yeah looks good! That display is awesome.
