fresh build having an issue
14 replies to this topic
#1 Vanebecker
Vanebecker
  • 145 posts
Posted 11 June 2016 - 04:40 PM
Ok soon I just rebuilt the engine and I'm having an issue when I crank it after sitting over night it cranks rite up but sounds like a freaking dirt track car with open headers (the way it chops, not hoe loud it is) and revs itself up and blows raw fuel out the back till I pat it for a bit and then it lvl out and stops blowing, I think it's flooding itself but don't know how beings just before I rebuilt it I checked and cleaned the injectors myself and they seemed fine....help please i dont have $200 for new injectors
#2 tsi_tom
tsi_tom
  • 2,268 posts
Posted 11 June 2016 - 05:12 PM
Need a video of that.
Engine
20 over forged pistons
Stock injection system
#3 scott87star
scott87star
  • 4,971 posts
Posted 12 June 2016 - 09:15 AM
Check the resistance of the coolant temp sensor (the two prong one) and compare it to the spec in the FSM.
#4 Vanebecker
Vanebecker
  • 145 posts
Posted 13 June 2016 - 07:28 AM
There is 2 of the 2 prong ones and one small 1 prong one on the thermo house
#5 cyberquest
cyberquest
    Power Poster
  • 4,963 posts
Posted 14 June 2016 - 05:11 AM
1. coolant temp sensor for gauge (88-89 used a two prong sensor)
2. EGR valve
3. engine temp sensor for ECU (this is the one scott is suggesting to test)
4. a/c shut off sensor (in the event the motor is overheating this sensor will shut down the a/c compressor)
2005 Acura RL SH-AWD
#6 Vanebecker
Vanebecker
  • 145 posts
Posted 14 June 2016 - 09:17 AM
Sweet thanks man
#7 Vanebecker
Vanebecker
  • 145 posts
Posted 14 June 2016 - 09:18 AM
Umm is that on an 89? Mine looks different
#8 Vanebecker
Vanebecker
  • 145 posts
Posted 14 June 2016 - 09:21 AM
Nvm lol didn't read it and #3 is brand ne and is there a pic of the wire colors that go to what sensors?? Also I noticed that the little black resistor thing buy the coil that has a blue and a black wire doesn't have the black wire going to anything...where does that go?
#9 cyberquest
cyberquest
    Power Poster
  • 4,963 posts
Posted 14 June 2016 - 11:18 AM
that black resistor is just a noise suppressor for the stereo and goes to the negative post on the coil.
i think if you go over this thread it should tell you which color wires go where.
http://starquest.i-x...opic.php?t=1097
#10 Vanebecker
Vanebecker
  • 145 posts
Posted 13 July 2016 - 05:03 PM
Hey guys here's an update, I figured the wireing out but I'm having a new issue...maby....Soooo I smelled my oil yesterday and it kinda smells like gas....I have less than 200 miles on the new pistons and rings....could they just not be sealed yet or what? Should I worry?
#11 Dad
Dad
  • 8,140 posts
    87 White Quest
    87 Shetland
    83 Starion- Chevy powered
    ___________________________
Posted 13 July 2016 - 08:02 PM
Sounds like leaking injectors,  run the pump with ovcp pipe off and engine off of course. See if injectors are still putting fuel in intake, there is a fuel pump jumper wire by air filter housing
#12 Vanebecker
Vanebecker
  • 145 posts
Posted 16 July 2016 - 04:35 PM
If that's the case, are my brand new rings gone already?
#13 G54Bstore
G54Bstore
    SQC Commander
  • 5,148 posts
Posted 17 July 2016 - 11:54 AM
No. Leaky injectors cause gas in oil if they leak bad enough.
Like carbs with bad needle valve or seat. You end up with gassy oil.
W18 Rocky White Starion
Daily Driver
#14 Vanebecker
Vanebecker
  • 145 posts
Posted 17 July 2016 - 12:10 PM
Whew ok good I was worried that the leaking injectors washed out my new rings
#15 mstieg
mstieg
  • 6,172 posts
Posted 05 August 2016 - 12:36 AM
It happens, but.....Might get more response yet if this thread were moved to Basic or Advanced Virt. Mechanic forum where it belongs.
Engine and Performance Mods
**NOT A Q/A FORUM** What you did or added to your engine. How it was done or How much it costs.
Edited by mstieg, 05 August 2016 - 12:38 AM.
In Progress: breakin & tune
