white quest ky Posted March 2, 2012 Report Share Posted March 2, 2012 Me an estimate on the cost for a mitsu dealership to replace the clutch in my montero Link to comment Share on other sites More sharing options...
leesfer Posted March 2, 2012 Report Share Posted March 2, 2012 Every place charges a different price, my guess is it will be something around 700-800 dollars for parts and labor Or you can do it yourself if you're up to it, I made a walk-through not too long ago on this forum for this exact purpose Link to comment Share on other sites More sharing options...
white quest ky Posted March 2, 2012 Author Report Share Posted March 2, 2012 You have a walkthrough for doing it on a montero? If so can i see a link please and thank you Link to comment Share on other sites More sharing options...
Dad Posted March 2, 2012 Report Share Posted March 2, 2012 Should not be too bad... didn't you just buy it? Link to comment Share on other sites More sharing options...
leesfer Posted March 2, 2012 Report Share Posted March 2, 2012 You have a walkthrough for doing it on a montero? If so can i see a link please and thank you The walk-through is for a Starion but if your Montero has the G54b then it's basically the same thing http://www.starquestclub.com/forum/index.php?showtopic=126303&hl=&fromsearch=1 Link to comment Share on other sites More sharing options...
white quest ky Posted March 2, 2012 Author Report Share Posted March 2, 2012 Yes sir randy the clutch was weak when i first bought it it was only a matter of time and thanks leesfer i really appreciate it Link to comment Share on other sites More sharing options...
Indiana Posted March 2, 2012 Report Share Posted March 2, 2012 Its easier to pull the engine and do it not drop axles and transfer case and tranny parts under the car that will take three times longer. Drive it up here you're about 3hrs away. I'm 2hrs exactly from Lawerenceburg. Link to comment Share on other sites More sharing options...
jeph_tsi Posted March 2, 2012 Report Share Posted March 2, 2012 If those take the same clutch parts as sq's I have a stock clutch that hasn't even been out of the box for cheap, I need to see if its 220 or 240mm though. Seems like it should be an easy job if you follow Indiana's advice, at least a lot less time under the truck that way. Link to comment Share on other sites More sharing options...
white quest ky Posted March 2, 2012 Author Report Share Posted March 2, 2012 Indiana i appreciate the offer but the thing wont even move lol and jeff how much do you want for the clutch and stuff if it actually goes to the monty Link to comment Share on other sites More sharing options...
TainterRacing Posted March 2, 2012 Report Share Posted March 2, 2012 Pull the motor I think you right there Indiana. That how I have doneboth i had in the past. Link to comment Share on other sites More sharing options...
jonboyb Posted March 2, 2012 Report Share Posted March 2, 2012 (edited) Yep.....yank the engine in a Montero. WAY easier. On another note, my tranny still waiting for winter to end Matt???? Edited March 2, 2012 by jonboyb Link to comment Share on other sites More sharing options...
white quest ky Posted March 2, 2012 Author Report Share Posted March 2, 2012 I guess if you guys say thats easier thats what ill do Link to comment Share on other sites More sharing options...
jonboyb Posted March 2, 2012 Report Share Posted March 2, 2012 (edited) It's just so tedious pulling everything to get the tranny/transfer case out from the bottom when you can un-do a few coolant hoses, a couple fuel hoses, the exhuast, the 2 engine mounts, and a few wires and yank the engine. This is all assuming you have a hoist Worst part of the whole ordeal is getting the fan shroud loose (if you still have a mechanical fan). I did pull my radiator to give me plenty of forward movement to slide the engine on/off the tranny shaft. Not sure you have too if you pull the fan blade off. Just remember to put a jack under your tranny Edit: Forgot a couple things. Just pull the PS pump and leave it where it lays and if you have AC like I did I had to wire it up against the driver's fender well to keep it out of the way. Engine slides under the upper AC hose without issue. It's a GREAT time to do the oil pan gasket too while you have the engine out unless you're CERTAIN it's good to go with a long life left. Edited March 2, 2012 by jonboyb Link to comment Share on other sites More sharing options...
jeph_tsi Posted March 2, 2012 Report Share Posted March 2, 2012 50 for the clutch set, just checked and its a 225mm. Link to comment Share on other sites More sharing options...
Komeuppance Posted March 2, 2012 Report Share Posted March 2, 2012 Please use the appropriate forum section for your threads, I moved all 4 or 5 of them for you out of the Engine and Performance Mods section. -Robert Link to comment Share on other sites More sharing options...
