89andBlue Posted November 7, 2015 Report Share Posted November 7, 2015 (edited) Hey, I received many suggestions for doing a 1uz swap on my conquest. I would love to know what all I'd need to get in order to make it a successful project, things like the transmission, rear end, what turbos would go best with it, etc. If there's a guide to this swap please pass it my way, if not I always love reading what you guys have to say, this community is incredible. Max Edited November 7, 2015 by 89andBlue Link to comment Share on other sites More sharing options...
BC_99 Posted November 7, 2015 Report Share Posted November 7, 2015 Those engines are almost always paired with auto trans. You will need a flywheel clutch bell housing from a jz motor and an r154 trans. The one from a soarer has the correct shifter location. The rear diff on you car should be fine. They can handle a lot of abuse. Start with getting the engine and all in there and running etc. Then start figuring your turbo setup. BC_99 Link to comment Share on other sites More sharing options...
GINASQ Posted November 7, 2015 Report Share Posted November 7, 2015 (edited) http://collinsadapters.com/index.php/adapter-plates/toyota.html Has a few options for using the 1UZFE with a manual trans. The 240sx KA/SR 5sp trans fits perfectly in the StarQuest with the 1UZFE. You can use the transdapt LS universal engine mounts from Summit Racing just have to drill a few holes in it (I have an extra set), look at Pancakes swap thread. You'll make a custom trans mount an driveshaft. Wiring the 1UZFE is easy. Doing a single turbo shouldn't be too hard if you can weld. Edited November 7, 2015 by GINASQ Link to comment Share on other sites More sharing options...
GINASQ Posted November 7, 2015 Report Share Posted November 7, 2015 Use an early motor (pre-95'), they have a more stout bottom end. The LS400 1UZFE' are front sump and that's what you'll need to fit in these cars. Also, the 1UZFE can handle from 5 to 9psi on a stock ecu. There's no off the shelf standalone or turbo kits for these engines. There's really not much aftermarket parts for these motors too. Kelford makes cams for like $1400 though. This forum has a lot of 1UZFE engine http://www.lextreme.com/forums/ Link to comment Share on other sites More sharing options...
Mech Posted March 27 Report Share Posted March 27 Does anyone know if you have to cut the transmission tunnel to get a manaul R154 and 1uzfe to fit? Link to comment Share on other sites More sharing options...
