Fuel pump help!
26 replies to this topic
#21 G54Bstore
G54Bstore
    SQC Commander
  • 5,180 posts
Posted 06 August 2019 - 11:12 PM
Open up the fuel flow.  It's restricted. You'll be boosted. Also walbro is poop.
W18 Rocky White Starion
Daily Driver
#22 bthotrod
bthotrod
  • 99 posts
Posted 07 August 2019 - 02:58 PM
Let me explain my fuel system wiring.
I have my own seperate igniton-on relay wired in, and instead of running a new wire all the way to the pump I just used the test wire since I knew it fed the pump. No, it doesn't have a control relay in the mix and while it would be safer I prefer simplicity - good suggestion though!
I fixed the line so it was no longer sucking air.
I actually poked a hole in the baffle in case that was an issue as well. I took apart and rebuilt my regulator and checked it, regulator is working great. Took apart and cleaned out my carburetor, it's basically brand new and I set all the mixture screws. Completely cleaned out the fuel tank. Put everything back together and it seemed to do great, I unhooked the fuel line at the carburetor and it has a nice steady stream of fuel.
Went for a test drive, drove great about 3 minutes then broke down again, spitting and sputtering to a stop. Let it sit 5 minutes, cranked back, drove back and it started breaking down as I coasted back into my garage. So frustrated.
1988 Chrysler Conquest V8 302 Swap
- Rear 8s with 225/50 and 245/50 tires
- Ford 302 with XE262H-10 Cam, ported heads, performer RPM intake
#23 bthotrod
bthotrod
  • 99 posts
Posted 07 August 2019 - 03:09 PM
Update: Just pulled the relay now that I thought about it and it seems as though one pin on the relay has become blue-ish and discolored, looks like it had got VERY hot at some point. Going to try out a new relay too, although I would think a bad relay would either work or not work, not go bad after a certain period of time... I could be wrong though.
#24 bthotrod
bthotrod
  • 99 posts
Posted 12 August 2019 - 11:16 AM
Didn't fix it. Now I'm completely lost... Ugh.
#25 G54Bstore
G54Bstore
    SQC Commander
  • 5,180 posts
Posted 12 August 2019 - 01:44 PM
Is the fuel pressure where it needs to be when it starts spuddering.
Daily Driver
#26 bthotrod
bthotrod
  • 99 posts
Posted 12 August 2019 - 02:20 PM
After weeks of frustrating and money thrown at it, the coil was getting hot when driving and cutting out EXACTLY like fuel starvation. Even my Dad who's been a mechanic 35 years drove it and thought it was a fuel problem.
New coil. Drives great. Thanks for all the help!
#27 G54Bstore
G54Bstore
    SQC Commander
  • 5,180 posts
Posted 12 August 2019 - 04:41 PM
Cool. Was gonna mention a coil or if ignition module next . Glad to hear it's back.
Daily Driver
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
