What Racing-Style Seats Fit?
#1
Posted 22 June 2016 - 06:10 PM
Finally got the bugs out of the tune on the car so it's time to start thinking of the next section of the project for the car. At this point that'll be moving on to the interior and getting stuff crossed off that list. My stock seats are getting a little tired and I want to use this opportunity to do a little research on seats. I looked around a bit on this sub-forum and did not find a stickied thread (or otherwise) that lists the brand and model of seats that will fit. Please feel free to post any rigid seats in here as well as I want it to be a solid database for people, but here are my requirements:
-Reclines (my car isn't a track car, mostly a summer car and occasionally gets tracked)
-Narrow enough to fit between the factory door cards and center console
-Same seat height or lower than factory seats (I'm 6 feet tall with a shorter inseam and long torso, my head just about touches the ceiling...)
-Seat brackets: I would like to find something that slides and utilizes the factory mounting points, not a universal setup.
Thanks in advance,
Matt
'89 Starion SHP...FIP MPI, 3" Exhaust, TEP Cam, Turbonetics 11021-BB T3/T4 Turbo, Treadstone Manifold, 75# injectors, Mookeeh Sway Bars, GC Coilovers, Saleen Replica Wheels, the list goes on...AND IT FINALLY RUNS!!!
#2
Posted 22 June 2016 - 08:01 PM
My Feedback Link
#3
Posted 22 June 2016 - 09:47 PM
Zoom clutch, Fidanza flywheel, Stedebani shifter, KSport coilovers, ST swaybars, abs delete, a/c delete, cruise delete, JVE, BSEK, TEP steel brake lines, LSP braided cooler lines, CX Racing radiator, MK1 silicone hoses, MK1 pullies, *DM hard pipes & intercooler,14G turbo, ported exh. manifold, MAF Translator, 3.5" GM maf, Turbo XS RFL bov, *DM 3" exhaust, Cusco front strut bar, TEP rear strut bar, Enkei 92's, HKS turbo timer, AEM wideband, AEM boost gauge, AEM oil pressure gauge, Hallman boost controller
JohnnyWadd, on 04 March 2010 - 10:01 PM, said:
#4
Posted 22 June 2016 - 10:30 PM
I have 4 sets now
My Feedback Link
#5
Posted 23 June 2016 - 04:32 AM
Does anyone know if the recaros out of a evo x will fit in our cars?
#6
Posted 23 June 2016 - 06:19 AM
I'm getting a set of Evo X for 800 bucks, I looked at them and they seem pretty easy to swap in. Currently I have some old APC seats on some unknown make brackets. Whenever my buddy gets back from deployment I'll be throwing them in. It should be a simple process. Basically unbolt the seat and slider from the bracket, then maybe drill a hole or two and use flush head bolts with lock nuts and loctite on the bottom.
#7
Posted 23 June 2016 - 06:55 AM
http://www.starquest...howtopic=134069
Insta = @battlemagnet
#8
Posted 23 June 2016 - 07:53 AM
While I'm asking, are there any 4pt cages that have a bolt-in harness bar? It'd be nice to retain the rear seats if at all possible. Got a little one and another on the way, and we like to use the car to go get ice cream
Edited by polarisman14, 23 June 2016 - 07:54 AM.
#9
Posted 23 June 2016 - 01:49 PM
Check out my tutorial for links, the Autopower bar I have has a welded crossbar but it comes with a bolt in crossbar also. Either way you can still fit the seat back there, sitting back there is another thing.
You can grind the rivets off the stock sliders and bolt mounts to them but they won't drop the height. There were a couple of slider kits that were brand specific. Any bottom mount seat can use the universal bottom mounts, which are basically just two pieces of angle stock. May need to drill a couple holes, but it'll look perfect.
Edited by Fuze, 23 June 2016 - 01:52 PM.
#10
Posted 23 June 2016 - 06:32 PM
