alp247 Posted April 18, 2012 Report Share Posted April 18, 2012 So when i switch from OD to ON or OFF it takes time to show on the cluster panel. I can tell the OD is working since i can see the RPM change when i am driving. What can i do to solve this problem? Is there a sensor i need to clean or something and that is causing the delay? Link to comment Share on other sites More sharing options...
TexasQuest Posted April 18, 2012 Report Share Posted April 18, 2012 Probably a dirty connection. Clean all the connections. Link to comment Share on other sites More sharing options...
alp247 Posted April 18, 2012 Author Report Share Posted April 18, 2012 TexasQuest,Sorry i'm a newbie to the Auto stuff. Can you point me in the right direction...maye with some links if possible, thanks. Link to comment Share on other sites More sharing options...
scott87star Posted April 20, 2012 Report Share Posted April 20, 2012 http://www.starquestgarage.com, go to electrical and find the 4 speed auto transmission circuit. It will show all the wire colors and connectors. The connector location map is towards the front, look at the numbers next to the connectors on the transmission circuit and then go to the connector map and they will tell you where they are, verify with the wire color. Take them apart, clean, use bulb grease or battery protectant, reassemble. Link to comment Share on other sites More sharing options...
