Bill Hincher Posted July 28, 2010 Report Share Posted July 28, 2010 I gotta build some driveshafts using the 1350 universaljoints http://www.billsautofab.com/images/driveshaft1.jpghttp://www.billsautofab.com/images/driveshaft2.jpghttp://www.billsautofab.com/images/driveshaft3.jpg drive shaft tubing comes in many sizes, it aint like you can buy it at Midas Muffler, I looked up the different rule books to find the required wall thickness, this is 3 in D.O.M. seamless http://www.billsautofab.com/images/driveshaft4.jpghttp://www.billsautofab.com/images/driveshaft5.jpg Link to comment Share on other sites More sharing options...
Convette Posted July 28, 2010 Report Share Posted July 28, 2010 Bill, I need one... Can you build one for my set up? Link to comment Share on other sites More sharing options...
supturbo Posted July 28, 2010 Report Share Posted July 28, 2010 Thats what I'm talking about. Link to comment Share on other sites More sharing options...
cyberquest Posted July 28, 2010 Report Share Posted July 28, 2010 (edited) i would be interested in a upgraded one for a stock quest drivetrain. http://i22.photobucket.com/albums/b343/vcyberbob/track/track2008.jpghttp://i22.photobucket.com/albums/b343/vcyberbob/track/track2007.jpg Edited July 28, 2010 by cyberquest Link to comment Share on other sites More sharing options...
Bill Hincher Posted July 28, 2010 Author Report Share Posted July 28, 2010 the best front yoke i can get for the r 154 converts the yoke to 1310 dana u-jiont, but a u joint is a avalable to convert the 1310 to a 1330 in the front driveshaft , in other words, one side of the u joint is a 1310 and the other side is a 1330 anyway, I got a hold of a friend that owns a splining factory nearby and he can build me some straight stock splined to the R 154, then I gotta mount a flywheel onto the splne and place a 1330 flange on that to get a bullet proof set up sooooooooooooooooo as it stands, I can build the 1310 to a 1330 and build the 1330 into the rear of the shaft and build the coupler needed to connect the 1330 at the torque tube set up Now, that is a 3 inch drive shaft, and it will build much better torque speed, but you should us a loop because of how much momentum the size material will build with RPM i priced a drive shaft lathe at $24000.00 and I didnt think that was too bad but for all the trouble I can build the lathe no problem on the GM drive shaft John Link to comment Share on other sites More sharing options...
Funky Phil Posted July 28, 2010 Report Share Posted July 28, 2010 i would be interested in a upgraded one for a stock quest drivetrain. http://i22.photobucket.com/albums/b343/vcyberbob/track/track2008.jpghttp://i22.photobucket.com/albums/b343/vcyberbob/track/track2007.jpg Dont use hollow ujonts and that wont happen. Link to comment Share on other sites More sharing options...
Convette Posted July 29, 2010 Report Share Posted July 29, 2010 I'll give you a call this weekend Bill. Link to comment Share on other sites More sharing options...
randyshaw81 Posted November 7, 2010 Report Share Posted November 7, 2010 Type of material? Weight? How much horse/torque power can it with stand? Link to comment Share on other sites More sharing options...
