NEVER Seen Swap Attempt
iGSR_VR
After so many years am frankly tired of the G54B,
It cost me almost $2000 to go MPI last time that's without the tuning and Dyno time...
I thought about the 2JZ swap but too mush money $$$$
So I was thinking of swapping the 2RZ what is the 2RZ??? Great Question its is the 2JZ cousin...
2RZ is a 2.4
3RZ is a 2.7 Both are still 4 Cylinders and whip hell of power STOCK factory head gasket handles 30lbs of boost
My car only has 52K, me and frined are going to do the swap here is the my car and below is the engine
It is currently doing 438HP on 16 Lbs of boost but we need a wide Band sensor to tune it better with Mega Squirt...Enjoy
Forged Rods from a ( secret Car you can find in the junk yard )
Crank Stock ( make over 1000 HP on the stock CrankShaft )
Stock Cams
Stock Timming Belt
Garret T60
ARP Headstuds
1st GEN Supra Celcia MAS
Stock Headgasket
Tweaked Oil Pump
I keep you guys posted
http://i620.photobucket.com/albums/tt284/in_line_motors/Conquest/IMG_1070_zps13cf6a2f.jpg
2RZ
http://i620.photobucket.com/albums/tt284/in_line_motors/AE86%20GT-S%20PART%20OUT/DSCF7172.jpg
Edited by iGSR_VR
This is the 22re replacement. How did it make 438 without a wideband?
Got to ask my homeboy that I believe he had one when tuning but not when they went back to fine tune it
I will verify for you and get back to you with the answer.
From what I read these are in Toyota trucks . Did they make turbo versions or did u half to make it turbo?
Yes Tacoma 2RZ
Toyota T100 3RZ
I see TRD makes a super charger for them but I do not believe they came Turbo Charge from the Factory
The turbo Manifold you can get from Gato or from Thread stone Performance.
Can't you use w59 Bellhousing and run a w58 trans? Though they don't standup to much power, it'll work.
Perhaps there is way too use a r154?
Okay I dont know mush but my friend has been racing his car for a while now his T50 came from the Supra Celica he said it bolts right up.
He also told me that's what guys with the 22R use to run back in the days its like steel hard transmission
Again I can only go by what he tells me ( i doubt he's wrong ) he built this motor himself and he wants to put in my car.
My buddy had a taco with the TRD supercharger, 7th injector kit, and dang near everything else TRD on it and it rolled out. He never had it tuned either(ya I know, not smart). Fast little truck!
NICE, do you have a picture
in those long threads where all the dreamers were fantasizing about DOHC head on the 54, this exact motor i suggested
seeing as adapting some off brand head, you will no longer have a mitsu motor anyway, with "hopeful" perfomance at best.
Go RZ and get it over with. Hell. put "mitsubishi" on the valvepan covers
way back in the 90s heavy 3500# 10sec full street GNs were tuned on O2 volts and scan tool
They lasted years without ever seeing a widebahd or a dyno
t50 tranny is a weak pos rolla 5spd.... you must mean the W50
oops wrong link
Edited by jinx
