Replacing fuel line from Hardline to engine bay filter. Need a clarification on fittings.
6 replies to this topic
#1 varzaman
varzaman
  • 178 posts
Posted 20 April 2019 - 07:50 PM
So while I'm trying (it's still not off) to get my engine bay fuel filter off, I did something to the bottom banjo fitting because now it leaks.
So I'm just gonna replace it with AN fittings and use a steel braided line.
Using this guide
http://www.starquest...howtopic=145612
The very first step is a 5/16 to 6AN fitting. I'm not 100% certain what it means by that.
M12x1.25 to 6AN fitting: https://www.summitra...arts/vpe-16615/
1' ft PTFE hose with fittings: https://www.summitra...fra-60261212bl/
Edited by varzaman, 20 April 2019 - 09:02 PM.
#2 croquest87
  • 1,668 posts
Posted 20 April 2019 - 08:01 PM
You need 2 washers for each banjo bolt.Put one on the bolt and slide it through banjo and put the other one on the bolt after.Both sides of banjo need to seal.
Hope this helps
Edited by croquest87, 20 April 2019 - 08:05 PM.
#3 Preludedude
Preludedude
  • 3,063 posts
Posted 20 April 2019 - 08:06 PM
I have that exact stock fuel line if you need a replacement.
The hose that goes from hard line to bottom of fuel filter.
PM me if you are interested.
#4 varzaman
varzaman
  • 178 posts
Posted 20 April 2019 - 08:07 PM
It's alright guys I just wanna switch everything over to AN fittings.
The entire rest of the fuel system is steel braided (just not installed yet). I might as well make this section also that lol.
It's just the front Hardline to engine bay fuel filter that needs to be changed.
I modified my post with the fitting and hose I would use. Now I just don't know what fitting for 6AN to hardline.
Edited by varzaman, 21 April 2019 - 03:45 PM.
#5 varzaman
varzaman
  • 178 posts
Posted 20 April 2019 - 08:51 PM
So further research tells me that the Hardline on the fuel tank side is m14x1.5 INVERTED FLARE.
Can I assume the front is the same?
What does inverted flare mean anyways.
Edit:got the correct adapter. It is just the m14.5x1.5 inverted flare.
Edited by varzaman, 20 April 2019 - 10:43 PM.
#6 varzaman
varzaman
  • 178 posts
Posted 20 April 2019 - 10:03 PM
Also in addition to the above question, does anyone have any tips on removing the fuel line from the Hardline? Seems to be seized on there really farging well. Been trying to remove it for the last hour -_-.
Just blasting it with pb blaster and waiting at this point. Gave it one last douse and now I'm just gonna let it sit overnight.
#7 varzaman
varzaman
  • 178 posts
Posted 21 April 2019 - 03:44 PM
I did it, I got the damn thing off!!!!!
Quick question though..... Is the fitting in the Hardline supposed to spin?
