Stock coolant temp gage on dash question
4 replies to this topic
#1 croquest87
  • 1,525 posts
Posted 17 December 2018 - 06:41 AM
There are 2 bungs on my intake manifold for temperature sensors. I have a stock temp sensor for the ECU w 3/8 npt in one and it works good.
I would like to install another sensor in just for the stock temp gage on dash but it needs to be 3/8 npt to screw in properly and also work w stock gage on dash. Any recommendation on which sensor is in range w stock gage w 3/8 npt is appreciated.Thought about making/buying adapter from npt to metric but figure one of you had to have figure this one out already.
I have a couple of stock sensors for the temp gage but threads are metric (not on npt)
Thank you
Dra
Edited by croquest87, 17 December 2018 - 06:58 AM.
#2 ucw458
ucw458
  • 11,554 posts
Posted 17 December 2018 - 06:10 PM
All pipe fittings on SQs and BSPT (British Standard Pipe Taper).  You can find adapters online.
My 87
#3 croquest87
  • 1,525 posts
Posted 17 December 2018 - 06:49 PM
Thank you for the response.I am using Chad's velocity stack intake.Sender for the stock gage is what l am after  stock is M16 x1.5   my manifold has 3/8 npt hole  l would like to avoid using the adapter and shooting for sender w 3/8 npt that will screw right in and work w the stock gage. Possible aftermarket  one.
Edited by croquest87, 17 December 2018 - 06:54 PM.
#4 kev
kev
    Moderator
  • 4,992 posts
Posted 20 December 2018 - 10:07 AM
Even the aftermarket stock sensors donít usually work.  They typically arenít calibrated the same.  I just recently pulled out my new aftermarket sensor because it was reading 3/4 at ~180 degrees. I tossed in a 30 year old original sensor and it works fine.
Btw this gauge is not a tapered thread.  It is a metric flat faced o ring boss. M16-1.5 ifmemory serves me correctly.  Itís very similar in size to a 3/8 npt but I dont believe youíd be able to tap your tapered thread hole to the metric o ring boss
#5 croquest87
  • 1,525 posts
Posted 20 December 2018 - 06:16 PM
http://imgur.com/a/Afo7iXt
This should work.
