vanillagorilla Posted May 24, 2015 Report Share Posted May 24, 2015 I took out a good portion of my interior the other day. No carpet on the floor. I noticed my passenger side floor drain plugs are completely rusted it. Should i keep the functionality of these and replace them with good ones, assuming one could even find them, or just cover up the holes and keep it moving? I purchased this car already with an engine swap and i can see several holes about an inch long on the trans tunnel. I assume i should try to get this patched and not just cover them up right? Link to comment Share on other sites More sharing options...
Turbo Cary Posted May 25, 2015 Report Share Posted May 25, 2015 The holes in the trans tunnel are probably from material being drilled out to make room for a larger trans. I believe the trans tunnel is "two layered" and one layer can be cut out to fit a larger trans. I would fill them in on both sides then repaint. As for the holes you see that are rusty, get a good wire wheel and clean the rust off. Primer and paint them. Then buy new body plugs. Measure the size and get the ones you need. They are pretty much universal rubber pieces. Link to comment Share on other sites More sharing options...
87starionkid Posted October 6, 2015 Report Share Posted October 6, 2015 Do you have any pix of the dash removed? I think I have rust behind there and I Wana kno whats behind there before I pay someone to take it down. Link to comment Share on other sites More sharing options...
vanillagorilla Posted October 16, 2015 Author Report Share Posted October 16, 2015 Sorry no pictures. Dash is still currently in. I just removed the carpet, seats, console, hatch area. I really think you could do the dash yourself. Did you do a search on the process? Link to comment Share on other sites More sharing options...
importwarrior Posted October 16, 2015 Report Share Posted October 16, 2015 rust usually at the base of the front window. Link to comment Share on other sites More sharing options...
importwarrior Posted October 16, 2015 Report Share Posted October 16, 2015 http://www.starquestclub.com/forum/index.php?showtopic=119250 Link to comment Share on other sites More sharing options...
