silverarrow89 Posted May 21, 2015 Report Share Posted May 21, 2015 See photos... I have them wrapped now, drivers side..just below the TB and on the firewall: Link to comment Share on other sites More sharing options...
BuGG Posted May 21, 2015 Report Share Posted May 21, 2015 That port on the intake connects to the port in the other picture. Its brake booster vac connection. Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted May 21, 2015 Report Share Posted May 21, 2015 I'm not entirely sure what specific thing you circled on the second picture, but if you're talking about the ports that enter/exit the firewall to/from the inside of the car, they're for the heater core. Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 21, 2015 Report Share Posted May 21, 2015 (edited) Do not drive it with just duck tape on there. They are for the power brake booster. Edited May 21, 2015 by StarquestRescue Link to comment Share on other sites More sharing options...
silverarrow89 Posted May 22, 2015 Author Report Share Posted May 22, 2015 (edited) And hence..Do not drive it with just duck tape on there. They are for the power brake booster. ...and hence why when driving around the block and without installing the new front rotors, calipers and pads, I said "Wow.. thats some serious wear on those original front brakes"... What does everyone use to replace the hose - part # MB277702? Edited May 22, 2015 by silverarrow89 Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted May 22, 2015 Report Share Posted May 22, 2015 Wow...I'm blind. Or I just can't see crap on my phone. NOW I see the ducktape in the second photo now that I'm on a computer. It's not really a special type of hose. It's just for vacuum. I just used some correct sized hose from the local part store to replace mine. Just buy a foot or two and you should be good to go. A whoppin' $2. lol - Charles Link to comment Share on other sites More sharing options...
silverarrow89 Posted May 22, 2015 Author Report Share Posted May 22, 2015 I'll head over and pick some up this weekend. Does it get clamped, or no need? Thanks Charles. Link to comment Share on other sites More sharing options...
BuGG Posted May 22, 2015 Report Share Posted May 22, 2015 Im pretty sure it IS a special hose from factory. Someone on here most likely has it. I wanna say its like a double hose, two hoses in one. Link to comment Share on other sites More sharing options...
silverarrow89 Posted May 22, 2015 Author Report Share Posted May 22, 2015 I think you're correct. I remember seeing it in my garage before the rebuild, it has a 6" black second sleeve over a portion of it, probably to protect it from the heat in the area. I'm looking into a braided steel line for $15. I'll post my findings. Link to comment Share on other sites More sharing options...
ucw458 Posted May 23, 2015 Report Share Posted May 23, 2015 That hose requires a check valve between the booster and manifold. It's essential to keep a vacuum supply inside the booster and keep turbo boost pressure out of the brake booster. Your brakes will not work right, or not at all without the check valve. The line also Ts and goes over to the ABS canister if you still have that. Link to comment Share on other sites More sharing options...
BuGG Posted May 23, 2015 Report Share Posted May 23, 2015 That hose requires a check valve between the booster and manifold. It's essential to keep a vacuum supply inside the booster and keep turbo boost pressure out of the brake booster. Your brakes will not work right, or not at all without the check valve. The line also Ts and goes over to the ABS canister if you still have that. You can see in his second picture on the bottom that the check valve is there and you can see that the line is going to the ABS canister. Link to comment Share on other sites More sharing options...
silverarrow89 Posted May 23, 2015 Author Report Share Posted May 23, 2015 Advance Auto was out of stock on 5/32" vac hose, since the check valve is in place, the only thing I need still is the hose correct? The OEM is long gone. Link to comment Share on other sites More sharing options...
tsi_tom Posted May 23, 2015 Report Share Posted May 23, 2015 That hose is no longer available. I wonder if the booster is bad causing a huge vacuum leak. Maybe that is why it was disconnected? It needs to be clamped on both ends. Link to comment Share on other sites More sharing options...
silverarrow89 Posted May 24, 2015 Author Report Share Posted May 24, 2015 TThat hose is no longer available. I wonder if the booster is bad causing a huge vacuum leak. Maybe that is why it was disconnected? It needs to be clamped on both ends. It was cut off when we pulled the motor... some 5+ years ago! I saw your build thread Tom... that was great work.. nice ride. I have a 3/8" brake boost hose and clamps going on today. Link to comment Share on other sites More sharing options...
tsi_tom Posted May 24, 2015 Report Share Posted May 24, 2015 Great! That is what I did. Link to comment Share on other sites More sharing options...
silverarrow89 Posted May 27, 2015 Author Report Share Posted May 27, 2015 Ok... back again. For those who may have an issue with this hose in the future, its not as simple as buying a 11/32" brake hose, you need the check valve, on the OEM its in the hose.. the photo of the intake is not the check valve.. so, now I'm in search of: A. An alternative brake boost line from a DSM, Evo, STI, BMW, etc., which fits the application OR B. Taking the standard 11/32" hose I purchased and adding an aftermarket check valve If anyone has thoughts on which is better above (A or or if you're using a check valve on this or another car, could you recommend which check valve is best to hold the PSI needed? Link to comment Share on other sites More sharing options...
ucw458 Posted May 27, 2015 Report Share Posted May 27, 2015 The plastic part above the booster should be the stock check valve. Link to comment Share on other sites More sharing options...
Funky Phil Posted May 27, 2015 Report Share Posted May 27, 2015 repurpose the ABS hose Link to comment Share on other sites More sharing options...
Funky Phil Posted May 27, 2015 Report Share Posted May 27, 2015 I use FI hose on mine. Link to comment Share on other sites More sharing options...
silverarrow89 Posted May 27, 2015 Author Report Share Posted May 27, 2015 The plastic part above the booster should be the stock check valve. Am I correct, the red circled plastic piece is the one way valve? Link to comment Share on other sites More sharing options...
ucw458 Posted May 27, 2015 Report Share Posted May 27, 2015 I've always assumed it was but never verified it for myself. Easy way to test is to pull it off and blow through it. Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted May 27, 2015 Report Share Posted May 27, 2015 Yes, that is the check valve you circled. Yes the hose should be clamped. And yes, it's a 'special' hose in that it's a molded hose from factory, but you don't have to replace it with that special hose. Theres not enough heat on that side to cause a threat. The stock hose is simply double walled just from design. Otherwise, the vacuum hoses and the AC lines would have a sleeve on the outside like the hard AC line, PS feed line, oil cooler lines, etc. Just a regular straight piece of hose will and does work. Have had it on mine for years and not one problem. That thing you circled is the check valve. They're actually strong enough that you can get two extras and make your own crank vents out of them You should be perfectly fine with what you've got. Everything is there. Call that task done! - Charles Link to comment Share on other sites More sharing options...
