noticing power drain at stop signs
10 replies to this topic
#1 allen405
allen405
    No comment
  • 1,626 posts
  • Interests:family/ conquests
Posted 15 May 2011 - 09:15 PM
I've noticed that last week now when I am sitting at a light with my blinker on my volt gauge drops to 8 volts and my blinker stops blinking. Also I've always noticed when my blinker is on the volt needle really jumps around, I know some is expected because of the way its wired but even my friend Jesse noticed how bad it jumps. Any help is appreciated. Is this a clean the gounds thing, or is it something else?
"the average man dies at 25 and is buried at 65" Ben Franklin
"Dude, is that a Nissan?"
Don't crush'em, restore'em
Posted Image Latest pic 8/11/11>> Posted Image
#2 Blue
Blue
    THAT Young'n
  • 2,429 posts
  • Interests:StarQuests. Guitars. Metallica.
Posted 15 May 2011 - 09:23 PM
This volt meter going crazy is normal for our cars, from what I've seen and heard. Just crappy wiring from the factory.
Disclaimer: I know enough to know I don't know nearly enough!
1997 BMW 328is - S52/6Speed/3.91 swapped, M3 brakes, TMS sway bars, CAI, Solowerk coilovers, Powerflex poly bushings(everywhere), HMS fender flares, ESR SR02 18x9.5/10.5, etc.
Always on the hunt for another 1987 TSi in Atlantic Blue.
Quote
12:24 AM [Technology] yeah, eventually, and I wish I was reading this for the hair joke.
Happiness is a click away My Photobucket
My Feedback Thread
#3 Bag-O-Chips
Bag-O-Chips
    Too close for missles, switching to guns!
  • 1,250 posts
  • Interests:welding toothpicks to battleships.
Posted 15 May 2011 - 10:07 PM
Relpace the Flasher to an EL12 iirc, and clean up the contacts and grounds associated with the turn signals. Or clean up the grounds for everything. You'll be surprised what clean grounds will do.
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
E85, GT4088R, Dual Synapse 50mm wastegates, Apexi AVC-R, Griffin Radiator, 2G Eclipse Flexalite fans, AEM 30-1300, HKS 301 cam, LSP built Marnel head, Del West 1mm oversized Titanium valves, Del West Titanium Valve lock/retainers, LSP Valve Springs, 1600cc injectors, SX AFPR, Fuelab Prodigy 140gph pump, Fuelab Filter, Bag-O-Chips  Twin scroll header, Chad's MPI Manifold, 70mm Throttle, 4.62 gearset, Wiseco .030", R&R Aluminum billet Rods, ARP everything, Toyo R888's.
#4 The Rabbit1
The Rabbit1
  • 2,943 posts
Posted 15 May 2011 - 10:42 PM
I used the EL-12 and still had some issues with my blinker working correctly for long periods with my brake lights on, I switched to the LL-552 and haven't had the issues anymore at all.
I also took all the wiring at the fusible links apart and cleaned every connection with a nail file and added some  die-electric grease. I then replaced all the links with new ones from dad for peace of mind.
Replaced: vac advance, Delphi injectors, all vac lines, tees and check valves, all brake hoses and pads, Master cylinder, flex plate, torque convertor, T-stat(180), CTS, TPS, both fan switches to primary, rear speakers, door speakers
Overhauled: Distributor, TB, wiper system, electrical ground connections, dash switches, auto seat belt tracks, entire auto trans, entire fuel system, A/C system
Upgraded: 1st gen Mas, HKS bov, Walbro 255lph pump, S16G Turbo and increased boost to 15psi, Aeromotive rrfpr 13105, MSD 8910 Tach adapter, Comp Cams Fireball digital ignition system, 35 watt HID headlights (6000k) 1000w 4ch amp, 100A alternator, engine to chassis to battery ground (4ga), charging wire from Alt to Batt (6ga), 2.5" Catalytic converter, Magnaflow muffler, R134 A/C, Yellow top optima battery
Added: AEM wideband, rail mounted fuel pressure gauge, dual alternator fusible links
Eliminated: Cruise, ABS, Emissions, Vac pump
#5 allen405
allen405
    No comment
  • 1,626 posts
Posted 16 May 2011 - 12:06 AM
I will run to the advance auto parts tomorrow and pick up an LL552 and clean gounds. Thanks alot for the info.
#6 Komeuppance
Komeuppance
    Amused.
  • 13,590 posts
Posted 16 May 2011 - 04:13 AM
Haha... no, that's not normal.
Read this: http://www.starquest...pic=92298&st=20
-Robert
#7 Starfighterpilot
Starfighterpilot
    Dirty Old Man
  • 4,368 posts
  • Interests:Keeping my Starion reliably scootin' down the road
Posted 16 May 2011 - 09:43 AM
-Robert
Robert, Thanks  :) for posting that reply of mine. However guys, be sure to read page 1 of the post too, where I describe what was going on electically, what readings I initially took and how I cleaned everything electrical in the engine house prior to moving on to page two of the post. ;)
I would also suggest that - if the voltage is jumping around, as you described on the dash meter, with the turning signals blinking - that you remove, clean and inspect the alternator, alternator wiring harness and it's pivot mounting (which is the factory alternator ground) as described in this link   http://starquest.i-x...2bf08840a71ec7d
Also remove,clean & check the grounds IAW this link   http://starquest.i-x...topic.php?t=916 so the ENTIRE electrical circuit is squeeky clean.
Remember, with the exception of starting, and momentary current surges when you have a piece of large electrical equipment initially turn on such as the HVAC motor, it's the alternator which is powering your Starquest. Not the battery. ;)
For What It's Worth.
KEN
Edited by Starfighterpilot, 16 May 2011 - 10:07 AM.
88 Starion ESI-R SHP BSE/stock original owner 495K Miles
84 Starion ES RIP in 1987
66 Dodge Charger, Modified Original OEM 383/ 365 HP, 4-speed, Sure Grip, original owner, 113K HARD miles - Being Restored
76 Dodge PU, Modified 440/ 425 HP, 4 speed, Posi Dana 60 DIF, 675K Miles
#8 Coke
Coke
    Member Since January 2003
  • 5,643 posts
Posted 16 May 2011 - 10:30 AM
This is some good stuff. My black 88 TSi has some serious charging issues, when sitting at stop lights, and even sometimes while driving. When I'm at a light, brake lights on, headlights on, blower motor on, my volt gauge reads in the neighborhood of 9 volts. Once I leave the light, it slowly creeps back up to 11-12. If I turn the blower motor off, it gets a LOT BETTER. If I turn it on, it gets a LOT WORSE. The blower motor appears to be pulling a lot of juice. Is this normal?
#9 Starfighterpilot
Starfighterpilot
    Dirty Old Man
  • 4,368 posts
Posted 16 May 2011 - 12:45 PM
The HVAC blower motor in fast is one of the biggest electrical loads in the 'Quests. Consider cleaning the ignition switch if all of the engine house electrical metal connectors and the grounds ar clean. ;)
To see what voltage is coming out of the ignition switches IG1 and IG2 contacts do the following:
To actually see what the actual voltage is that's being supplied down stream of the ignition switch via the IG 2 circuit, get a multimeter and check the voltage to the radiator primary fan relay at the blue with black tracer power wire going into the electrical connector A-07. Ya gotta stick your positive probe from the multimeter into that wires connector slot so it's touching the metal terminal, and of course ground the multimeters' black wire.
If that voltage is more than one volt lower than battery voltage, with various other car electrical loads on, go back to connector A-33 or 34, depending on your Starquest's year, and probe it the same way to see what your voltage is at the outlet wires connectors' metal terminals of the connector and the inlet wire to the connector. This connector is located under the battery tray. Take the battery & it's tray out. hook up jumper cables to the battery terminals to get power to this connector cuz the battery has to be removed to get to it.
If ya got low voltage to or out of A-33/34, turn the car off, pull that connector apart and clean the metal terminals. Start the car and check your voltage again.
If ya still have low volts to A-33/34, then go back to 1 & 3 fusible links better yet - all of 'em- and test their voltage on either end of the fusible link metal terminals. If ya got good voltage in but bad voltage out turn the engine off - clean all of the fuse box connector's metal terminals. Pull the fusible links and check 'em for zero ohms. If ya ain't got zero replace 'em. See what you have for voltage now with the engine running.
To test the IG 1 circuit, check the voltage going to the ignition coil's positive pole.
If you have good voltage out of connector A-33/34 but greater than one volt less at the primary rad fan rely connector and/or to the coil than what battery voltage is, then it's time to pull the ignition switch and either replace it or tear it apart and clean & grease it.
I hope that this makes sense.
BTW - Ya should have your lady running when taking these various voltage readings, even with the jumpered battery, so you actually see "real world" what's going on where in the various electrical circuits when your Lady is running under various electrical loads. ;) And turn on things like the HVAC fan in fast, headlights, watch voltage as your rad fan motor cycles on and off, etc.
And as you are taking these readings with the multimeter keep an eye on the dash volt meter so you have a rule of thumb for how far out of calibration the dash voltmeter is.
KEN
One more thing. Make sure that all of the fuses in the fuse block underneth the dash are clamped tightly in their connectors and that the connectors aren't corroded.
Edited by Starfighterpilot, 16 May 2011 - 02:02 PM.
#10 Raider 2.6
Raider 2.6
  • 102 posts
Posted 16 May 2011 - 01:04 PM
Seems like I've read other threads stating the voltmeter will bounce with the blinker on no matter the condition of the connections involved. People mentioning trying different gauges and supplying an extra ground to the voltmeter. Apparently that is wrong?
#11 JAinsworth
JAinsworth
  • 16,904 posts
Posted 16 May 2011 - 01:20 PM
Here is an old post from mikec on the bouncing voltmeter and blinkers:
Quote
Dash voltmeter has long wires hooking it to the battery:
battery + post ---> IGN fusibile link ---> ignition key input ---> ignition key ON position ---> fuseblock --*-> fuse ----> dash voltmeter.
A whole slew of things tap into the circuit at the "*" in the diagram: lots of fuses actually.  These include the turn signals, engine cooling fans, interior fan, etc.  Lots of high-amperage items.  And wires to the alternator that enable it to work...  Any voltage loss (caused by poor wires, bad connections, etc.) between the battery post and the "*" will affect everything as a result.  Turning on the turn signals causes a lot more current to flow, making the problem/voltage loss worse.  Your problem is typical old wiring issues.  Cleaning the IGN fusible link contacts and all connectors to/from the link box helps a bit but sometimes you just have to run new (beefy) wires in parallel with the original factory wires.
The turn signals quit flashing because StarQuests use a thermal style flasher unit: current through the turn signal bulbs heats up part of the flasher until it literally bends inside - this opens a switch cutting power.  The lights go out, the flasher cools down, and the switch un-bends and the cycle starts over.  If the voltage going into the system ("*" again) is too low, the flasher never heats up enough.  Thus your blinkers don't blink.
mike c.
p.s.  You'll notice the dash voltmeter doesn't bounce much when you run the HAZARD lights though... even though that's like running both sets of turn signals together - it ought to be twice the load, right?  The hazards are powered through other fusible links and not through the ignition key so they don't affect this circuit.  The entire IGN circuit is under-strength on most StarQuests.
