questme87 Posted January 2, 2014 Report Share Posted January 2, 2014 i need some forged pistons for my g54b i stupidly bought the wrong set now im paying for it any help would be nice and im on a very tight budget please help Quote Link to comment Share on other sites More sharing options...
mr-starion Posted January 3, 2014 Report Share Posted January 3, 2014 What pistons did you buy that were not correct? Dad has them on his website for the going price. Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted January 3, 2014 Report Share Posted January 3, 2014 Hi, We would also need to know what size you need. Tom Quote Link to comment Share on other sites More sharing options...
MotoCam360 Posted January 3, 2014 Report Share Posted January 3, 2014 If I had a dollar for everytime I've heard "On a tight budget" lately.... I could probably buy a new EVO Quote Link to comment Share on other sites More sharing options...
mr-starion Posted January 3, 2014 Report Share Posted January 3, 2014 Ya building one of these motors is expensive i could of had an evo with the money i spent on the whole car! But then again, it cant equal out to the drive a starion gives you! Quote Link to comment Share on other sites More sharing options...
questme87 Posted January 3, 2014 Author Report Share Posted January 3, 2014 I know it but I was hoping someone had some used ones lol Quote Link to comment Share on other sites More sharing options...
questme87 Posted January 3, 2014 Author Report Share Posted January 3, 2014 Mr starion I bought a set of vs mahle air cooled 94mm pistons which I thought where forged and also they exceed the deck height Quote Link to comment Share on other sites More sharing options...
Dad Posted January 3, 2014 Report Share Posted January 3, 2014 so your lookîng for pistons 94mm? you know thats like .112 oversize going ti be a custom make only. Quote Link to comment Share on other sites More sharing options...
questme87 Posted January 3, 2014 Author Report Share Posted January 3, 2014 I bought vw mahle pistons which are to big for the stroke and are not forged so I dont want to use them Quote Link to comment Share on other sites More sharing options...
Dad Posted January 3, 2014 Report Share Posted January 3, 2014 Would help to know what size you want. Std. 020. 030. Etc Quote Link to comment Share on other sites More sharing options...
questme87 Posted January 3, 2014 Author Report Share Posted January 3, 2014 30 over would be nice but I want flat tops Quote Link to comment Share on other sites More sharing options...
Funky Phil Posted January 3, 2014 Report Share Posted January 3, 2014 hahaha, gonna cost ya! Quote Link to comment Share on other sites More sharing options...
questme87 Posted January 3, 2014 Author Report Share Posted January 3, 2014 I know Quote Link to comment Share on other sites More sharing options...
Funky Phil Posted January 3, 2014 Report Share Posted January 3, 2014 why flattops? Quote Link to comment Share on other sites More sharing options...
mr-starion Posted January 3, 2014 Report Share Posted January 3, 2014 Flat tops Sounds like alot of compression for a turbo motor, someone on here did that, i wonder what the outcome was. Has your block been bored before? You wanna go the least oversize possible so that you can have room to rebore in case of catastrophic failure. The gain by goin of goin oversize for no reason is little to none and higher in machining costs. Quote Link to comment Share on other sites More sharing options...
questme87 Posted January 3, 2014 Author Report Share Posted January 3, 2014 No it has not been boerd before and I want flat tops to run a higher compression ratio and I probably can get away with going with standard size Quote Link to comment Share on other sites More sharing options...
Malykaii Posted January 3, 2014 Report Share Posted January 3, 2014 Here's the 4x4wire consensus on 8.7:1 flat top pistons, as in the ones that come stock in the n/a truck motors. Plenty of people have tried to bolt on the turbo intake/exaust manifolts onto their truck blocks and go. The fuel map is slightly off. It will run, but it will detonate. One guy went as far as to build a hybrid distributor using the truck timing spring to compensate for the detonation. It helped but at certain speeds on downhill it still detonated. Unless your using premium or racing fuel AND a standalone ecu to control spark timing... it won't work. (The distributor just doesnt have the advance to work with that setup so I'm willing to bet maft cant even save you. It will help with adjusting the fuel map but not timjng advance) If your on a budget, DONT do it. Its been tried. More compression isn't usually a good thing for turbo cars. Quote Link to comment Share on other sites More sharing options...
nomad Posted January 3, 2014 Report Share Posted January 3, 2014 http://www.starquestclub.com/forum/index.php?showtopic=137730&hl=wiseco These are mine, still for sale. Hit me up. Quote Link to comment Share on other sites More sharing options...
questme87 Posted January 3, 2014 Author Report Share Posted January 3, 2014 Nomad sounds tempting could you hold off on them until I get my taxes back thats when ill be in full swing on my build Quote Link to comment Share on other sites More sharing options...
mr-starion Posted January 3, 2014 Report Share Posted January 3, 2014 phew! Another g54b turbo block saved! Quote Link to comment Share on other sites More sharing options...
Funky Phil Posted January 3, 2014 Report Share Posted January 3, 2014 Flat tops Sounds like alot of compression for a turbo motor, someone on here did that, i wonder what the outcome was. Has your block been bored before? You wanna go the least oversize possible so that you can have room to rebore in case of catastrophic failure. The gain by goin of goin oversize for no reason is little to none and higher in machining costs. depends on the chamber but Joe and I love ours. Quote Link to comment Share on other sites More sharing options...
questme87 Posted January 3, 2014 Author Report Share Posted January 3, 2014 I am honestly looking so sell the pistons I bought and buy the correct set 92mm is what I want im confused and torn between lol Quote Link to comment Share on other sites More sharing options...
questme87 Posted January 3, 2014 Author Report Share Posted January 3, 2014 Phil what pistons are you using Quote Link to comment Share on other sites More sharing options...
Funky Phil Posted January 4, 2014 Report Share Posted January 4, 2014 (edited) Wiseco flattops from Randy @ www.Enginemachineservice.comIf you dont have ignition control, forget about it. Stock curve is too gnarly. Go full-on EDB, a programmable 6AL2, or even an old MSD BTM. Edited January 4, 2014 by Funky Phil Quote Link to comment Share on other sites More sharing options...
