Beast Quest 1989 Conquest GTX3071R TBI G54b
143 replies to this topic
#1 Mach 5
Mach 5
  • 510 posts
Posted 21 August 2016 - 08:01 PM
Howdy! Figured I would share my Conquest finally. ill needs to be tuned. which will happen next week at VTR
https://www.youtube....h?v=lRW6WdKrSbU
build
G54b
Wiseco .020 over bore
ARP Head Studs/ locating hats/ tq to 90ft/lbs /heat cycled and re-torqued
ARP Rod Bolts
AJUSA Head Gasket
Balance Shaft Delete
Balanced Assembly
Colt Cam mechanical rocker
Mookeeh Adjustable Cam Gear
M8 head RRRM Ported
5 angle valve job/ back cut
Caravan Intake Manifold
RRRM billet spacer
LSP 60mm Big Mouth Throttle Body
RRRM welded/ ported mixer housing
JDL header and downpipe
Precision 46mm wastegate
Turbo XS dual stage boost controller
Gtx3071r
RRRM 3inch downpipe / Mookeeh 3inch B pipe/ apexi N1 Evo
Greddy Type S BOV
Derale Oil Cooler
LSP oil cooler lines
CX Racing Radiator
Maradyne dual 12inch fans
CX Racing Intercooler
RRRM 2.25inch intercooler pipes
oil seperator
K&N airfilter
Trilogy 950cc primary Delphi 1450cc injectors
MS2 v3 scott87star built/ GM 3 bar MAP/ GM IAT/ stock locked dizzy
SPA Turbo adjustable fuel regulator
Boostinmini Mazda TPS kit
Walbro 255 Fuel Pump/ hard wired/ Aeromotive Fuel Filter/ Banjo Delete
Falcon Clutches Custom 4 puck clutch disc modified pressure plate
Baffled Oil Pan
Relocated Oil Drain to Pan
NX Meth injection kit not hooked up
Modified P/S Pump Valve
BC 99 Steering U joint
Eibach Springs
Mookeeh Struts
Slotted Rotors
Porterfield R4-S Brake Pads
Sparco Steering Wheel/ Momo adapter
Bridgestone Potenza RE-11 225/45/R16 245/40/R16
Autometer EGT Pyrometer/ Coolant Temp/ Oil Pressure/ Boost Gauge in IPC
Battery Relocation behind Passenger seat in Taylor Aluminum Battery Box
0 gauge battery cable
-Jarek
Edited by Mach 5, 06 September 2016 - 05:51 PM.
Owner- Radical Revs Auto- Jarek-
-Rides-
-1987 Starion -Midnight Star - FORD BARRA GTX4508r Build Progress see link
http://www.starquest...howtopic=152434
-1989 Chrysler Conquest-Track Beast Mode gtx3071r TBI 365hp 407tq @19psi/ 401hp 430tq @ 24psi sold
http://www.starquest...ic=151885&st=40
-1989 Pontiac Grand Prix Turbo SE- 3.1 gtx3582r getrag284 Tilton twin disc
-1991 Toyota Hilux Pickup 1uz itb cp pistons kelford cams TripleR head porting/ long tubes
-1986 AE86 20v.. 171hp@ 8200rpm
#2 TexasQuest
  • 9,126 posts
Posted 21 August 2016 - 09:24 PM
Nice work! How hard is it to modify the caravan intake to work? I like those fans, man they sound beast!
88 Fiji Blue -TSi
#3 Mach 5
Mach 5
  • 510 posts
Posted 21 August 2016 - 09:47 PM
It was a little bit of a pita. once I figure out posting pix ill post them. I shaved and welded the egr passages and cut out the entire section where the carb would go... fabbed up a flange with help from my friend who operates cnc and welded it on. no idea how its going to perform
the fans scream.. no doubt! you can hear them from the other side of the house!
-Jarek
Edited by Mach 5, 21 August 2016 - 09:47 PM.
-Rides-
#4 bubsinsc
bubsinsc
  • 299 posts
Posted 21 August 2016 - 10:06 PM
Question when you were reving it up sounded like it was cutting out around 3500-4000 ?
#5 NikoFab
NikoFab
    Go Blue Fan
  • 9,941 posts
Posted 21 August 2016 - 10:56 PM
Looks good Jarek!
#6 Mach 5
Mach 5
  • 510 posts
Posted 21 August 2016 - 11:01 PM
bubsinsc- "Question when you were reving it up sounded like it was cutting out around 3500-4000 ?"
its not tuned. the old tune was for stock compression and the stock intake/ tb mixer setup..tip in way lean.. going on the dyno this week
Nikofab- Thank You!
-Jarek
-Rides-
#7 freebird
freebird
  • 2,936 posts
  • Interests:time is of no moment, but only what your doing
Posted 22 August 2016 - 09:00 AM
Very good work...thanks for sharing your hard work.
U got a nice starquest bro!
#8 Mach 5
Mach 5
  • 510 posts
Posted 22 August 2016 - 09:08 PM
Thank You!! The body is rough but I got it with a blown motor for $650 so I cant complain.. I cant wait to drive it. Thursday I have the appointment to get it tuned
-Rides-
#9 TexasQuest
  • 9,126 posts
Posted 22 August 2016 - 09:18 PM
Hell yeah. Post up the results if you don't mind. B)
88 Fiji Blue -TSi
#10 Mach 5
Mach 5
  • 510 posts
Posted 22 August 2016 - 09:27 PM
Edited by Mach 5, 22 August 2016 - 10:06 PM.
-Rides-
#11 Mach 5
Mach 5
  • 510 posts
Posted 22 August 2016 - 09:48 PM
this is the dyno of the old setup with stock pistons and stock intake/48mm tb/mixer setup
Edited by Mach 5, 22 August 2016 - 10:05 PM.
-Rides-
#12 Mach 5
Mach 5
  • 510 posts
Posted 22 August 2016 - 10:10 PM
RICE CANNON!!!!!!!! hehe
-Rides-
#13 Mach 5
Mach 5
  • 510 posts
Posted 22 August 2016 - 10:11 PM
-Rides-
#14 Mach 5
Mach 5
  • 510 posts
Posted 22 August 2016 - 10:34 PM
I had a hard time trying to get these to upload... many more pix but Ill have to leave it for another night..... I picked up the car from a kid who bought it from a junk yard.. doesnt have a salvaged title but is rusty and banged up.. Im happy with it for what it is.. Car was broken in to... looked like it hasnt been ran in years.. kid pulled the motor and in the process cut all of the wiring up rather than unbolting or disconnecting so I had to go through everything.. fun fun... also when the car was broken in to door got mangled and the radio was busted up... yuck!! I believe the car was from Virginia in case anyone recognizes it.
so..
The fun began. I decided to build on a budget...Everything was either Ebay used or custom fabbed to stay within budget... and tried to spend the money on the more worthy stuff.. ECU, Tires, suspension... fabbed up all the intercooler piping port and chamber work on the cylinder head.... Got it running and had it tuned.. Well.... I didnt realize my banjo fittings on the fuel lines were a huge restriction. While tuning i had detonation with the stock pistons and intake setup. cylinder #3.. fuel pressure was dropping higher up in the powerband.. after I fixed the fuel issue didnt realize there was damage till after but it was done.. I asked my tuner to correct some minor fueling concerns as I started noticing issues had no idea that the motor was about to go.. So we tuned it and after I left I felt like something was wrong... it actually made less power the second time around.. (dyno graph pictured) and was starting to smoke.. got home pulled the plugs to find #3 was saturated... compression says all... 1-4 (120,120,60,120) 1st crank 1-4 (80,80,15,80)... I wanted to cry...so I decided to build further.. I had already built an engine for my Starion (The Shredder) thats getting restored and figured I should just use the bottom end from that since it was ready to go.. with Wiseco Pistons...and all new fresh internals... swapped my head from the Beast Quest on and fabbed up a manifold for it from a Chrysler 1986 Caravan.. Hopefully this will help with fueling... we shall see!!
-Jarek
-Rides-
#15 TexasQuest
  • 9,126 posts
Posted 23 August 2016 - 07:34 PM
Great side by side pics of the intake manifolds. I don't think they've been documented in the same picture for comparison before.
88 Fiji Blue -TSi
#16 Mach 5
Mach 5
  • 510 posts
Posted 23 August 2016 - 11:06 PM
-Rides-
#17 TexasQuest
  • 9,126 posts
Posted 25 August 2016 - 08:35 PM
I bet AFR's are alot more stable with the caravan intake.
88 Fiji Blue -TSi
#18 Mach 5
Mach 5
  • 510 posts
Posted 25 August 2016 - 09:28 PM
it was as the tuner described at first very finicky. he said it was a down grade.. but then he started to get some where with it and the torque dropped horsepower increased and the rpm band stretched. made 40 more hp and 20 more tq
Il be posting videos soon
-Rides-
#19 Mach 5
Mach 5
  • 510 posts
Posted 25 August 2016 - 10:23 PM
352hp 381tq tuning.. @20psi
https://www.youtube....eature=youtu.be
sadly my brand new freshly installed alternator died on my way home :(
-Jarek
-Rides-
#20 TexasQuest
  • 9,126 posts
Posted 26 August 2016 - 08:59 PM
Nice numbers man! Yeah those remaned alternators can be a crap shoot.
88 Fiji Blue -TSi
