Total width of rear suspension?
7 replies to this topic
#1 AustinTSI
AustinTSI
  • 414 posts
Posted 08 April 2014 - 06:38 PM
Does anyone have the total distance of the rear suspension from the right rear hub/spindle to the left side. Basically, how far is it from where the wheel mounts to the other side?
Thanks.
#2 patra_is_here
patra_is_here
  • 8,358 posts
  • Interests:86 starion
Posted 08 April 2014 - 11:23 PM
just measure from the centerline of the left tire to the centerline of the right tire and then subtract off the wheel offset.
#3 patra_is_here
patra_is_here
  • 8,358 posts
Posted 08 April 2014 - 11:24 PM
its about 54" inches moreorless iirc
#4 aknorthstar
aknorthstar
    FarNorth Member
  • 1,362 posts
Posted 09 April 2014 - 02:34 AM
about 57.7 on the front and 57.3 on the rear
Edited by aknorthstar, 09 April 2014 - 02:34 AM.
#5 aknorthstar
aknorthstar
    FarNorth Member
  • 1,362 posts
#6 AustinTSI
AustinTSI
  • 414 posts
Posted 09 April 2014 - 12:31 PM
I have the books and didn't even think of that. Thanks.
So if I have this correct then the rear tires have a -10mm offset each so that would be 20 added to 1455mm actual width for the rear for a total of 1465mm or 57.67" for the Starion
The s13 240sx has an offset of 40mm each and a rear tread dimension of 1460mm so it should then be 1540mm actual width or 85mm wider.
FYI, I'm working on putting an S13 front and rear suspension in my Starion and right now it is looking like most everything will cross over with a couple of brackets/adapters.
#7 patra_is_here
patra_is_here
  • 8,358 posts
Posted 09 April 2014 - 10:42 PM
no you subtract 20mm. the center of the wheels sits further out than the hub face
#8 patra_is_here
patra_is_here
  • 8,358 posts
Posted 09 April 2014 - 10:44 PM
rear "tread" (track) is listed as 57.3 , which is the measurement to the centerline of the wheel. so hub distance is 57.3 minus 20mm or around 56inch (i was close!)
