My MPI project....has restarted! new pics
can anyone tell me what else I can eliminate from my engine bay by looking at the picture
http://i43.photobucket.com/albums/e394/XLR8N/DSC00291.jpg
http://i43.photobucket.com/albums/e394/XLR8N/DSC00289.jpg
Edited by PDodson
  • Replies 73
  • Created
  • Last Reply
Top Posters In This Topic
You know, the fuel rail will work with the banjo fittings like on top of the fuel filter, it's the same as the rail.
As for that barbed nipple, just get a block off cap for that and tap in someplace else for vacuum (it looks like that is vacuum).
It's all fun and games, this MPI business! good luck :)
I took another look at that fuel rail picture, You are going to have to do several things there, block off the old thermostat housing, move the heater core hose and install a good sized nipple on that top hole for coolant going to the heater core.
I switched the heater core hoses going onto the firewall nipples. If you do that, it gives you more room, though some people have said that the heater might not work the same because there is a valve inside the heatercore. But actually I don't think so. It'll work the same.
Also, a set of injectors generally costs 295 dollars, no matter what size they are, so get some bigguns, then you can always have room to add boost, or use e85 if that's available.
for fuel control I will be using this
FIP:
FC-PRO-4 kit. We program it so it will be ready to run. Just tell us you injector size ,type, and any other mods to your engine. Includes: * FC-1 fuel injection controller. This is programmed ready to go, but changes can be made with software or optional hand held TD-1(tuner display). * Wiring harness made for the Conquest. * Water temp sensor. * Air temp sensor. * Standard map sensor (good to 20 psi). * TPS sensor. * Instructions. Price $495.00 If you have the stock ignition system you will also need the IAM-1 also. (not needed with MSD 6AL,BTM)
MSD 6A for Ignition
65 or 75lb injectors
mod my stock intercooler
Magna Cyl head
20G turbo
what do you guys think about this list I have mentioned above
oh I almost forgot I have a wideband also
Why do you want a magna cyl. head? The stock one or aftermarket replacement will work fine. Magna is just another used head, unless you are looking for more flow, in which case, maybe you do want it (you could just send the stock head to get worked over for big flow, weld up the jet valve holes, and get it checked for flatness).
You'll need to buy tubes for I/C pipes. You should mod your intercooler first, because unless you do it yourself, it might take a while.
A 20g will be good for bolt-on-ability and make some ok power but get the biggest exhaust housing you can. See if you can port the exhaust manifold as well.
Also, try to get all the stuff before you start, that way it'll be easier.
  • 1 year later...
well it has been a while since I posted here
Here is a list of stuff I aquired for my MPI swap
Motor:
Magna M6 Cyl head w/HD Valve Springs, SS Valves
FIP FC-4 for Fuel
MSD 6A for ignition
Walbro Fuel Pump
Magna MPI manifold w/75 lb injectors
65mm Throttle Body
Auto Tranny:
Stage 3 Valve body mod from Balt TSi
Completely rebuilt tranny
  • 1 month later...
I have 1 of the earlier magna manifolds I have to do something about this
http://i43.photobucket.com/albums/e394/XLR8N/trouble2.jpg
How much space is between the fuel rail and the firewall?
I was thinking of using a npt to -6 AN fitting then a 90 degree bend when i did mine, i am not to the stage you are though.
you can use the -6 metric banjo fitting, that is what a lot of people do. You can tap it for NPT though for a 90* fitting, many have. It will fint just fine either way.
  • 2 months later...
well I brought my Durban with me to Colorado after Nationals
http://i43.photobucket.com/albums/e394/XLR8N/DSC00198.jpg
http://i43.photobucket.com/albums/e394/XLR8N/DSC00199.jpg
started working on it
removed the oil cooler lines to make way for my SS oil cooler lines
http://i43.photobucket.com/albums/e394/XLR8N/DSC00222.jpg
removed header panel and intercooler
http://i43.photobucket.com/albums/e394/XLR8N/DSC00221.jpg
let the work begin!
did some cleaning a few days ago
http://i43.photobucket.com/albums/e394/XLR8N/DSC00275.jpg
http://i43.photobucket.com/albums/e394/XLR8N/DSC00277.jpg
did some more work this afternoon
removed the stock wiring harness
http://i43.photobucket.com/albums/e394/XLR8N/DSC00279.jpg
I think I will use this hole for the new harness
http://i43.photobucket.com/albums/e394/XLR8N/DSC00281.jpg
the hole where the stock harness used to be
http://i43.photobucket.com/albums/e394/XLR8N/DSC00280.jpg
looking over some stuff I got from Dave at Nats
A EDIS 4 setup
http://i43.photobucket.com/albums/e394/XLR8N/DSC00282.jpg
this is everything I will be running
FIP FC1S, MSD 6A, and EDIS 4
http://i43.photobucket.com/albums/e394/XLR8N/DSC00283.jpg
Edited by PDodson
hows it going?
if ur gonna to sell the 6A, how much with shipping to 35633?
i'm gathering parts for MPI swap and this is one i need since i bought Megasquirt1 in combination with modded Magna on ebay and will be using stock ignition to begin with.
well anyway, good luck with your swap. looks good.
i should be making a thread as soon as the madness ensues. :wacko:
please let me know if you want to get rid of your 6A.
have a good one
more progress, more cleaning
http://i43.photobucket.com/albums/e394/XLR8N/DSC00287.jpg
what it is gonna look like sort of
do I need this?
http://i43.photobucket.com/albums/e394/XLR8N/DSC00292.jpg
I dont see a spot for the Air temp sensor?
http://i43.photobucket.com/albums/e394/XLR8N/DSC00290.jpg
whole front shot
http://i43.photobucket.com/albums/e394/XLR8N/DSC00293.jpg
Hey, is the cruise control wire part of the driver side harness or was it part of the engine harness? Dang, I might have to go look at mine, if I have it, by golly I'm reinstalling cruise control tomorrow.
Ditch the FIP computer it is junk. Buy a ms2 v3 board. Or decide to run a 6al with a distributor.
The edis will run at 10* btdc if you have the VR sensor 9 teeth after the missing tooth. The edis box that says motorcraft recieves a 5v signal (to advance or retard the timing, the signal comes out on pin 36 of on the db37 connector for ms2. The box also outputs a 12v signal every time it fires. Megasquirt interprets this and uses it for your rpm reading.
I may have some if the information incorrect, I have been drinking a bit, but that is the general idea of what edis 4 is and does.
The problem is that you do not have full control over the timing. Thus is why eventually I will run COP wasted spark with megasquirt for sweet anti-lag.
Edited by Casey_L
