DIY Knock headphones for standalone tuning
27 replies to this topic
#1 ucw458
ucw458
  • 11,515 posts
Posted 02 February 2012 - 01:27 AM
I built myself a set of knock headphones.  It took about $20 worth of parts from radio shack.  It works and is plenty loud through my headphones.  The sensor is a nissan sensor for many early vehicles.  Found on ebay for $10 new.
Now I can do some street tuning and play with the timing.
I used "Afrotechmods" video on op amps to build it.  If you want to build one here are a few tips for this application.  You don't need to power the knock sensor so omit that part.  Also since you aren't powering it the filter part can be removed. (The 0.1 uf cap and 100k resistor.)  The knock sensor has a chassis ground and signal pin.  The knock sensor ground goes to the 9v battery ground setup in the video. For the gain resistors just omit the second one.  That sets the gain to max.  In the video the second one I'm talking about goes from signal output to inverting - in.
http://www.youtube.c...u/4/TQB1VlLBgJE
My 87
#2 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
  • Interests:Lots of boost!
Posted 02 February 2012 - 05:30 AM
Awesome! You could wire in an LED with (what I bet is another cheap and easy circuit to build) a threshhold of whatever voltage real knock is, so when it blinks, you could listen even more closely. I think with knock, since it happens quickly, it might even be too quick to tell the difference on headphones between background noise for a single knock.
That's kind of a guess, maybe it'll be super easy. I'm looking forward to your results.
#3 ucw458
ucw458
  • 11,515 posts
Posted 02 February 2012 - 05:39 AM
This is what knock sounds like.  It will be easy to hear.
My 87
#4 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
Posted 02 February 2012 - 06:09 AM
Sweet. They had gain control knobs on that box. sweetness. Probably just a pot where the high value resistor goes in the basic circuit.
#5 Crazy Quest
Crazy Quest
  • 1,233 posts
  • Interests:BOOST!!!!!
Posted 02 February 2012 - 07:25 AM
I need to do this. Is there a way to actually wire in a knock gauge. I know on DSM's when they use dsm link you can turn the factor boost gauge into a knock gauge.
Edited by Crazy Quest, 02 February 2012 - 07:26 AM.
#6 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
Posted 02 February 2012 - 08:38 AM
LEDs that come on at different voltages.
#7 ucw458
ucw458
  • 11,515 posts
Posted 02 February 2012 - 09:02 AM
I'll do a couple tests this afternoon.  I'll let you know what I come up with.
My 87
#8 Crazy Quest
Crazy Quest
  • 1,233 posts
Posted 02 February 2012 - 01:37 PM
sounds good
#9 Elkidmino
Elkidmino
    Polack Mechanic
  • 5,622 posts
  • Interests:Burning Rubber
Posted 02 February 2012 - 02:14 PM
This should be a sticky in the MPI or Engine Mods section.  Good post.
Magna MPI, SDS-3E, 65lb inj, MSD 6AL, Schnieder HD Springs, S16G, ProfecB-Spec 2 EBC
UAS Strut Bags, KYB Struts, BigRed 2-way Valves, 1/2" air lines, PS2 solenoid controller
#10 ucw458
ucw458
  • 11,515 posts
Posted 02 February 2012 - 06:48 PM
I can make up a complete circuit wiring diagram and parts list if anyone wants to build their own.
My 87
#11 Crazy Quest
Crazy Quest
  • 1,233 posts
Posted 02 February 2012 - 07:16 PM
yes yes and hmmm yes please
#12 ucw458
ucw458
  • 11,515 posts
Posted 02 February 2012 - 10:16 PM
Here are the diagrams.
Parts list
2x 220 uf capacitors
2x 1k ohm resistors
headphone jack
LM324 OP AMP chip  (found at RadioShack)
5k ohm audio potentiometer
9v LED
double pole switch
9v battery clips
8-10' of shielded wire
scraps of 24ga wire
bare circuit board (breadboard,  preferably with copper backing)
5"x2.5"x2" project box
Nissan knock sensor
Bosch EV1 injector clip
2 9v batteries
soldering iron + solder
Before making each connection wipe the soldering iron tip on a wet rag.  This cleans the tip.  Also try to get an iron with a small tip around 1/16".
My 87
#13 ucw458
ucw458
  • 11,515 posts
Posted 02 February 2012 - 10:21 PM
I'm going to test this on my car this weekend just to make sure it works on the car.
My 87
#14 Bag-O-Chips
Bag-O-Chips
    Too close for missles, switching to guns!
  • 1,250 posts
  • Interests:welding toothpicks to battleships.
Posted 03 February 2012 - 06:21 PM
Updates? I'm really hoping for your success with this. I've been contemplating this for a LONG time. lol
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
E85, GT4088R, Dual Synapse 50mm wastegates, Apexi AVC-R, Griffin Radiator, 2G Eclipse Flexalite fans, AEM 30-1300, HKS 301 cam, LSP built Marnel head, Del West 1mm oversized Titanium valves, Del West Titanium Valve lock/retainers, LSP Valve Springs, 1600cc injectors, SX AFPR, Fuelab Prodigy 140gph pump, Fuelab Filter, Bag-O-Chips  Twin scroll header, Chad's MPI Manifold, 70mm Throttle, 4.62 gearset, Wiseco .030", R&R Aluminum billet Rods, ARP everything, Toyo R888's.
#15 ucw458
ucw458
  • 11,515 posts
Posted 03 February 2012 - 11:46 PM
I tried it today and got alot of background noise.  I had it bolted to the head and I could hear the valves.  I'm gonna try again with the sensor in the stock location.  I bet that will clear up the noise.  I would have tried it sooner but everything was hot so I couldn't switch out the stock sensor without burning myself.  I'll try again tomorrow.
My 87
#16 polarisman14
polarisman14
    DRIFTIN'
  • 2,157 posts
  • Interests:Cars, motorcycles, snowmobiling, four-wheeling, snowboarding, golf, billiards, bowling, forums, volleyball, Boston sports teams...Anything fun and mechanical.
Posted 05 February 2012 - 09:31 AM
I'd suggest using the stock location for the knock sensor--who better than mitsubishi to know where to put it to begin with? Otherwise it's like having an in-car automotive stethoscope. That's why I just tapped into the stock knock sensor circuit on my Focus. Great write-up and info though and thanks for posting your method. When I get my car back from paint an body work I'll probably try to do what I did before and go through the radio etc for those of you who don't want to use the headphones. If you don't mind, UCW, I'll post it here eventually?
'89 Starion SHP...FIP MPI, 3" Exhaust, TEP Cam, Turbonetics 11021-BB T3/T4 Turbo, Treadstone Manifold, 75# injectors, Mookeeh Sway Bars, GC Coilovers, Saleen Replica Wheels, the list goes on...AND IT FINALLY RUNS!!!
http://i512.photobuc...pg?t=1339849860
#17 ucw458
ucw458
  • 11,515 posts
Posted 05 February 2012 - 01:44 PM
Post it here if you want polarisman.  That will keep all the info in the same place for people to read.
My amp has a headphone jack so it plugs into the radio easily using a tape converter or an aux input.  I'm gonna do a video of it in the car playing over the stereo when I'm done with repairs.  I just have to wire up the new knock sensor and change out my IAC.  The current one isn't working right.  But I have to remove the upper intake to do it.
I would have had it done yesterday but my roommates lebaron had a water pump failure.  I had no idea how buried the water pump is on a 6g72.
My 87
#18 polarisman14
polarisman14
    DRIFTIN'
  • 2,157 posts
Posted 05 February 2012 - 01:51 PM
Does the new knock sensor have the same thread pattern as the stocker does? I'd gladly switch one out for the other seeing as how all the wires in my car are junk and I'm gonna have to pretty much re-wire the whole thing.
#19 ucw458
ucw458
  • 11,515 posts
Posted 05 February 2012 - 03:05 PM
No, my new knock sensor doesn't have threads.  It just has a hole.  Many cars use this sensor.  Some have different connectors but the sensor is the same.
Our stock sensor has m10x1.25 threads.  My new sensor only fits up to M8
This is the nissan version and can be found on ebay for $10 new.  It's also the same sensor that professional built knock headphones use.
Edited by ucw458, 05 February 2012 - 03:07 PM.
My 87
#20 psu_Crash
psu_Crash
  • 7,148 posts
Posted 05 February 2012 - 05:17 PM
Ucw have you tried this with the stock sensor? Since you are running the signal through an op amp anyways the amplification should be enought to do the trick just fine
My Feedback Link
