Hard starting
I having hard time to start my 88 conquest I have 32 psi on the fuel line from the tank to the tb and have power to the new coil and to the plug and wire . The injector had been clean by rc injector I even have my ecu checked and they say nothing wrong with it and my knock box jump went I try to started. Sometime I can started the quest but once I have it running for couple mins and turn it off than it will not started again. I need help cause I'm try to get my quest smog I have a new head on it. Thank you
Edited by Conquest 1988
  • 1 month later...
the last pic shows the ground from the EGR pic and what it connects to.
The others are from the intake to the harness.
http://i35.photobucket.com/albums/d182/Professor-Quest123/Batt%20Grd/GR-15B.jpg
http://i35.photobucket.com/albums/d182/Professor-Quest123/Batt%20Grd/GR-15F.jpg
http://i17.photobucket.com/albums/b71/questmanual/pro-cu/CU-46.jpg
Edited by importwarrior
you cannot really see it but the blue wire is goes straight down barely visible on right side of coil.
i believe this car in the pic is an 86.
http://i17.photobucket.com/albums/b71/questmanual/pro-cu/CU-45.jpg
I need to replaced my head on my 88 quest it's crack, so I have Detroit gasket for my head that I'm going to put on. Do anybody have the torque spec on an arp head both and crankshaft bearing cap so I can reused. Where is the best place to buy a new head that will not hurt my pocket$$$$. Did anybody buy any head on eBay? I'm looking at Odessa cylinder head! I want some reference about this company. I'm hoping there will be good referral. Thank you
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 2 months later...
I have check everything in my quest and I even have power from the battery to my plug, sometime it will started at the first time and other time it will not started at alI I have 40 lbs fuel pressure.and I have gas in the tbs. I even try to change the ecu and the knock box to test it but it still have no solution to my problem. I need help cause I'm trying to get my quest back on the road, so I can smog. Thank you hope to get some information from other member. Can I used 225/55/16 on the front wheel ? Will it have any problem with the spring. Edited by Conquest 1988
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
