Thinking about a headlight harness for my car
I-W
8 replies to this topic
#1 importwarrior
  • 18,308 posts
Posted 07 June 2019 - 12:07 PM
Thinking about a headlight harness for my car.
might not make a difference but it seems like a good idea.
uses power from battery directly to the lights.
Heavy Duty Headlight Conversion Harness w/Relays
NOTE: Our headlight harness includes a pre-installed diode that allows the high and low beams to emit light at the same time when the brights are turned on. Should you need to disable this feature, simply remove the diode from the wiring harness.
Link:
https://www.tomsbron...ford-bronco-new
Thoughts, opinions ????
https://youtu.be/MoNlhgxV36s
#2 psu_Crash
psu_Crash
  • 7,170 posts
Posted 07 June 2019 - 12:14 PM
Any electrical upgrade to these old monsters is a good idea. I've thought of doing something similar for years... it never happens lol
My Feedback Link
#3 importwarrior
  • 18,308 posts
Posted 07 June 2019 - 12:18 PM
its only 29 dollars just need to verify the
positive high low and negative are the same
as the cars harness wiring.
I used it on my 79 F150 and it was a huge difference on that.
#4 ucw458
ucw458
  • 11,554 posts
Posted 07 June 2019 - 12:56 PM
Wont make a difference on a SQ.  SQ headlight relay gets power directly from the battery through fuse link #4.  That wiring harness only helps on cars that have the headlight circuit run through the ignition switch.
My 87
#5 psu_Crash
psu_Crash
  • 7,170 posts
Posted 07 June 2019 - 03:27 PM
I'd just like to replace the questionable old wiring
My Feedback Link
#6 ucw458
ucw458
  • 11,554 posts
Posted 07 June 2019 - 03:47 PM
That harness is wired to switch the + and have a common ground at the headlights.  SQ headlights and many other Japanese cars switch the ground.  Common positive and switched grounds.
I went through this on my Toyota.  Same setup as the SQ.  OEM is switched grounds and direct battery +.  I wanted to try it but everyone online said the relay kit made little to no difference.  Conversely people with Jeeps love this kit because their headlights run through the ignition switch.
My 87
#7 G54Bstore
G54Bstore
    SQC Commander
  • 5,165 posts
Posted 07 June 2019 - 10:31 PM
I'm all about hardwiring. It's always overboard but works
W18 Rocky White Starion
Daily Driver
#8 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,387 posts
Posted 11 June 2019 - 09:24 AM
i used one similar to this with glass H4 housings and 55w bulbs, works great, because, you bypass the old wiring AND if you wanted to bump up the bulb wattage go for it cuz the twin relays can handle it ;)
          MOPAR POWERED
#9 importwarrior
  • 18,308 posts
Posted 13 June 2019 - 05:23 AM
Good information thank you all for your input.
Also tagged with one or more of these keywords: I-W
