Need Help In Orlando MPI Megasquirt Start
MS
25 replies to this topic
#1 Ptracy262
Ptracy262
  • 130 posts
Posted 21 November 2020 - 10:48 PM
Hi,
Allow me to introduce myself,  into this car and it won't start.  WHO wants to help?
Well had to edit this as it was rough ask,   but thanks for responses so far.
Edited by Ptracy262, 30 November 2020 - 11:33 AM.
#2 Ptracy262
Ptracy262
  • 130 posts
Posted 21 November 2020 - 11:00 PM
https://www.youtube....h?v=rptSLeX_Vzk
#3 tux
tux
  • 1,710 posts
Posted 22 November 2020 - 02:07 AM
Scott, most likely.
Do you have spark, fuel, air?
What's it do?  Does timing light show the same as the megasquirt software?
#4 Ptracy262
Ptracy262
  • 130 posts
Posted 22 November 2020 - 09:15 PM
Scott is assisting as he always does.
Sorry My car is not with me in Jax but with a mechanic in Orlando that needs local help?
Why I'm asking for Orlando Help,  if not ok,   But great to reach to you all
Edited by Ptracy262, 25 November 2020 - 05:39 PM.
#5 Ptracy262
Ptracy262
  • 130 posts
Posted 22 November 2020 - 09:19 PM
I want to say,  from the video
Spark and Fuel test fine
Then Start???????.
Seems one spark then nothing what he tells me
#6 Funky Phil
Funky Phil
    Super Pooper
  • 6,488 posts
Posted 22 November 2020 - 10:51 PM
Rpm signal issue
#7 lionbull
lionbull
  • 3,291 posts
  • Interests:DUH
Posted 23 November 2020 - 09:27 AM
Does it have as a distributor, coil pack or individual coils?
just trying determine how is the ecu is getting consistent rpm signal. What are you using as an ignitor?
If distributor, is it indexed to the cam properly?
make sure VR sensor wire are not switched. Its possible for the car to start, but timing can drift if left like that, not good.
View Postvettekiller593, on 09 September 2011 - 10:20 AM, said:
Lol you guys must be blind. He would of won if the supra didn't give him a 1/8 mile start. Lol you guys kill me.
View Postlionbull, on 07 September 2011 - 02:26 PM, said:
ALSO this is not a HP race. It is a race. You dyno queen guys need to remember this. I am not speaking to anyone in particular but you know who you are!
#8 Ptracy262
Ptracy262
  • 130 posts
Posted 23 November 2020 - 03:52 PM
Its a MS setup for Locked distributor, so sent out my ECU/Distributor/KnoxBox,   scott does the rest.
Battery was relocated to trunk for the install
MPI
High Imp Injectors
#9 Ptracy262
Ptracy262
  • 130 posts
Posted 25 November 2020 - 05:19 PM
View Posttux, on 22 November 2020 - 02:07 AM, said:
Scott, most likely.
Do you have spark, fuel, air?  "Yes"
What's it do "nothing,  it won't turn over" ?  Does timing light show the same as the megasquirt software?  "the response I got for this,  is that the engine needs to run 800rpm,  and it hasn't turned over"
#10 Ptracy262
Ptracy262
  • 130 posts
Posted 25 November 2020 - 05:24 PM
View PostFunky Phil, on 22 November 2020 - 10:51 PM, said:
Rpm signal issue
verbatim "No it's definitely reading RPM - when I'm starving at the RPM on the computer  move in so does the on on the speedometer"
And when in Test mode it shows plenty of spark"
#11 Ptracy262
Ptracy262
  • 130 posts
Posted 25 November 2020 - 05:27 PM
" Oh yes,  because the distributor is bolted down (which I assume means locked) and is turning like normal"
"wires on the VR are color coded as designed was advised as well,  but in the end it never starts only cranks"
#12 tux
tux
  • 1,710 posts
Posted 26 November 2020 - 01:18 AM
Is the distributor 180 out?
#13 Ptracy262
Ptracy262
  • 130 posts
Posted 28 November 2020 - 12:35 AM
Sorry no, but I also asked should it be.  But response was it would still spark,  but again to answer not 180 out
Thanks guys for following up,  it helps
#14 importwarrior
  • 18,403 posts
Posted 29 November 2020 - 08:22 PM
is your distributor a stock distributor?
did you lock it down so the advance does not move at all.
if the advance mechanism in the distributor is not locked down then it can cause big problems.
check this link...
I Lost My Mind Racing - Howto
#15 Ptracy262
Ptracy262
  • 130 posts
Posted 29 November 2020 - 09:51 PM
Distributor is stock,
3 parts sent to Scott
ECU
Distributor
Knock Box
ECU MS stock harness
Scott locked the distributor
as well as adjustments to the knock box sensor
I checked the link out,  thanks.  I would assume this has been done as well since I paid a fee for this type of setup.
Edited by Ptracy262, 29 November 2020 - 09:55 PM.
#16 Funky Phil
Funky Phil
    Super Pooper
  • 6,488 posts
Posted 30 November 2020 - 10:32 AM
What does you timing light show?
#17 Ptracy262
Ptracy262
  • 130 posts
Posted 30 November 2020 - 11:11 AM
Can't get a timing light on it, as its never turned over.
Its starting to point to your previous comments  "RPM signal",  we have logs now and its leaning that way.
He's going to check his wiring specifically around there or related too.   I have the pic of the log and I'll post in a bit.
#18 Ptracy262
Ptracy262
  • 130 posts
Posted 30 November 2020 - 11:33 AM
IMG 3319a
Album: MS Tuner Studio
1 images
#19 scott87star
scott87star
  • 5,116 posts
Posted 30 November 2020 - 04:19 PM
Quote
Rpm signal issue
Ding, ding!  Funky Phil wins.  Fixing it now.
#20 tux
tux
  • 1,710 posts
Posted 30 November 2020 - 04:51 PM
Checking this would have led him to the rpm signal issue... :)
Also tagged with one or more of these keywords: MS
